Hauling 950lbs worth of stuff?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Canadian144, Apr 26, 2011.
  1. Apr 26, 2011 at 3:57 PM
    Canadian144
    Canadian144 [OP] Well-Known Member
    Toronto, ON
    2016 DCLB Limited
    Hey guys,
    Do you think there would be any issue hauling 950lbs worth of particle board in the back of our Tacoma 4x4 Double Cab long bed 5AT? Sorry, I know this seems like a dumb question, but it will be my first time hauling anything heavy in the bed.
    Need it for grad prank tomorrow... I believe the max it can carry is 1000lbs in the bed. Will only be hauling it for about 10-15 miles. Provided I take it slow I shouldn't have any issues right?
    And when loading it (it's on a skid), should we push it towards the front of the bed or the rear?
    Thanks!
  2. Apr 26, 2011 at 3:59 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    You will probably bottom out on bumps if you havent gotten the TSB done.
  3. Apr 26, 2011 at 4:03 PM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    Push it all the way to the front of the bed. I see you're in Canada and I hear you already have the heavier leaf packs stock up there so it should handle it. It might still hit the bump stops on a big bump but you'll be fine if you take it easy.
  4. Apr 26, 2011 at 4:03 PM
    Canadian144
    Toronto, ON
    2016 DCLB Limited
    I haven't looked into the TSBs, I know there are a few, but the one you are referring to has to do with adding a 4th leaf to the rear suspension, correct?
    I'm pretty sure that I read that all Canadian Tacos come with 4 leafs.
    If this is true, should I be fine? I'm going to search to verify that all Canadian trucks come with 4. If you are referring to another TSB please enlighten me!
  5. Apr 26, 2011 at 4:04 PM
    Pugga
    Massachusetts
    He was talking about the leaf spring TSB and you should already have the upgraded set. Count your leafs and you'll know in a hurry.
  6. Apr 26, 2011 at 4:05 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    You should be ok. Take it slow. I had that much weight for about 10 miles on my all pro leafs with no overload leaf. It squatted but sat fine.
  7. Apr 26, 2011 at 4:10 PM
    ISUGrad05
    ISUGrad05 Public Servant Enemy #1
    Wichita, KS
    2012 4x4 5.7 Tundra DoubleCab
    I hauled 1120 pounds of concrete mix in the back of my 5-lug a couple weeks ago with no problems. The back end was riding way low but it was it wasn't on the bump stops. I assume six lugs have beefier leaf springs and shocks, but what do I know?
  8. Apr 26, 2011 at 4:12 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    you should be fine!
  9. Apr 26, 2011 at 4:12 PM
    Canadian144
    Toronto, ON
    2016 DCLB Limited
    Thanks for all the help guys. I'll go count the leafs to verify.
    Since it is such a short trip I may ask the guy if he can just split the stuff in half, and take two trips.
  10. Apr 26, 2011 at 4:18 PM
    maju
    maju Well-Known Member
    Davenport Fl
    10 DC Silver TRD Sport 4x4
    Undercover tonneau, Scangauge II, Garmin GPS, Michelin LTX M/S2
    Payload of the truck is advertised as 1295 lbs
    But remebr the Payload = The weight of occupants, equipment and cargo that a truck transports.
    If you have the 3 leafs you will most likely be on hitting the stops.
  11. Apr 26, 2011 at 4:18 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    You do have the 4 leaf pack unless you bought an American truck .
    950 lbs is quite a bit , you will probably be fine but if you can split the load it would be better .
  12. Apr 26, 2011 at 5:57 PM
    Canadian144
    Toronto, ON
    2016 DCLB Limited
    Thanks for all the advice and stats guys.
    It will definitely be close to (or AT) the limit. I'll let you know how the truck rides. I'm assuming I will be going slow due to having to pick it up during rush hour, so I should be fine.
    I'll be sure to get picture as well.
  13. Apr 26, 2011 at 6:03 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    Payload is high 1200s. Depending upon your weight as the driver, you should be within spec without any passengers. if you do add passengers, though technically over capacity, you'll still probably be fine.
    And it will ride fine, but it will ride fine like a loaded vehicle does. You will take longer to get up to speed. You will need increased braking distance.
    After owning my truck about a month I went to the local plant nursery and got thirty 40lb. bags of potting soil for my mother. That's about 1200lbs. I weigh about 160. All told, the truck was slightly overloaded. It did fine.
    Edit: This was before installing my lift or any other suspension modifications. I'd probably make two trips now, because armor is eating up about 250lbs. of my payload, and larger tires already decrease my braking efficiency.
  14. Apr 26, 2011 at 6:12 PM
    Canadian144
    Toronto, ON
    2016 DCLB Limited
    Thanks, I will definitely be keeping braking distance in mind.
    I've cleaned pretty much everything out of the truck. It will just be myself (roughly 200), a buddy (who is about 150) and the stuff. Obviously won't have the bed extender or tonneau with me. All in all I think I'll be a little over (assuming that the guy has the weight of the boards spot on) but again, it's a short distance, and I'll just take it really slow.
  15. Apr 26, 2011 at 6:13 PM
    jandrews
    Meh, being a couple hundred pounds over won't hurt the truck. Engineers do build in a margin of safety.
    Just don't go putting a full ton in the bed and you'll be fine.
  16. Apr 26, 2011 at 6:19 PM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    it's a truck fer chrissake just do it! But remember it won't handle worth crap and expect serious jolts as it bottoms. It'll be just fine.
    center load directly over axle.
  17. Apr 26, 2011 at 6:22 PM
    OZ-T
    Peter North
    British Columbia
    OP , you said you were picking up a pallet of particle board .
    Do you mean 4x8 sheets ?
  18. Apr 26, 2011 at 6:26 PM
    gpend5.7sport
    gpend5.7sport Well-Known Member
    Gabe
    Houston
    2010 Toyota Tundra TRD Sport
    too damn many
    pft i put that much weight in my old 01 4door short box and hauled for two hours, youll be fine mang, the trucks almost always can handle more weight than what the dealershit tells you. my tundra's bed cap is 1890lbs and the past two weekends i had easily over 2k back there of bricks bed box and sand, and i never even bottomed out.
  19. Apr 26, 2011 at 6:28 PM
    OZ-T
    Peter North
    British Columbia
    Your bed cap weighs 3/4 ton ?
  20. Apr 26, 2011 at 6:42 PM
    gpend5.7sport
    Gabe
    Houston
    too damn many
