Hauling a BAMF 2nd Gen Plate Bumper in a 2008 Honda Civic?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bbinSF, Feb 23, 2025.
  1. Mar 4, 2025 at 9:12 PM
    Pigpen
    Dan
    Northwest Montana
    But the story is nowhere near as good.
    bbinSF[QUOTED][OP] likes this.
  2. Mar 4, 2025 at 9:31 PM
    tomatogrower
    tomatogrower Well-Known Member
    2013 tacoma crew cab 4x4
    none
    BAMF's new location in Grass Valley is about an hours drive from my house... does anybody know if they offer installation of their rear bumper for an additional fee...
  3. Mar 5, 2025 at 10:44 AM
    TacoTuesday1
    FL
    I moved in a wagon. And picked up a manual conversion kit in the trunk of a non folding sedan using a moving blanket.
    that being said like others have mentioned a steel bumper is big awkward heavy strong and jagged meaning it will be difficult to put into a sedan, if it even fits. And will try to damage the interior.
    you may be better off renting a vehicle for transport. Or Seeing if you can have them install it.
    whether that be a friends truck. Back of your truck. Uhaul. Home Depot truck. You name it.
    the civic can drive with the trunk open and tied secure. Possibly a red flag which Home Depot also gives out for free required by law if the part hanging out extends beyond a certain distance from the back of the vehicle.
    But whether a trunk is open with a flag or not doesn’t really help with the rest of it.
    you may also need a helper. If you have a good easy transport vehicle then you may not have to bring somebody with you and can just have the seller lend a quick hand or anybody nearby.
    when I picked up my ARB front from ORW or somewhere they helped get it to and on my truck bed but it was a bit more simple because it was also well packaged in a big rectangular box making it a little less awkward to grab and position.
    bbinSF[OP] likes this.
