hauling a bike with uhal motorcycle trailer
Discussion in 'Towing' started by franzcars, Jul 19, 2011.
  1. Jul 19, 2011 at 4:20 PM
    franzcars
    franzcars [OP] I'm different, in a different way
    Justin
    ST.louis MO
    08 Base Taco I4
    Plasti-dipped rims, blacked out Taco logos, small interior mods, AFE prodry drop-in, DJM 3/4 drop, Viper alarm, Power locks, Fogs, Viper 305 alarm, Kenwood HU
    we'll im thinking of getting a ninja 250 when i turn 15 1/2 which is when i can get my motorcycle permit. but i would not want to try and ride it home cause i'd proly not have it when i'd buy the bike. so i was thinking i'd rent a u haul motorcycle trailer and hooking it to the ball i have on bumper. i measured the height and its right around 21" to the top of the ball, which would lower a bit cause i dont have the tsb leafs and its a 2wd 4 banger. any ideas?
  2. Jul 19, 2011 at 5:43 PM
    sechsgang
    sechsgang Well-Known Member
    06 DC TRD OR 4WD 6spd
    So what will be the weight of the trailer, with the bike on it? That's the question.
    I'd say chances are you are ok. What is the height of that Uhaul trailer hitch? Most of us probably don't know that either (just like the weight).
  3. Jul 19, 2011 at 5:47 PM
    horwitzs
    horwitzs Well-Known Member
    Seth
    Dayton, WA
    TX Pro
    Supercharger, OME lift w/ LR UCAs, running boards, toolbox, extinguisher mount, skidplate, N-Fab light bar, 40" R.I. LED bar, WO seat covers, TRD intake, Weathertech mats and visors, stubby antenna, hood struts, LED interior lighting, Hella Supertones, and other stuff I'm forgetting.
    Not exactly sure what you are asking for... That bike is only about 425 lbs and the trailer won't weight that much, so you'd have no trouble with weight at all if that is what you are worried about.
  4. Jul 19, 2011 at 5:56 PM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    Is your truck wired for a trailer? If not, that's something uhaul can do for you if you want, but you'll need it done before renting the trailer. Either way, once you're wired up you shouldn't have any problem with the ninja, just make sure you have good tie downs.
  5. Jul 19, 2011 at 6:56 PM
    franzcars
    Justin
    ST.louis MO
    08 Base Taco I4
    i was mainly concerned with the ball ion the bumper, i know i can tow the weight i just dont know if u guys think it is to high. i think thats the high on most hitches . basicly is the ball so high that it will b up at a high angle?
  6. Jul 19, 2011 at 7:04 PM
    WTtoolman
    WTtoolman Facial bones colapse as I crack your skull in half
    William
    Omaha, NE
    2006 Access Cab 4x4 TRD SWB
    5100s at 0, eibachs, 2" toytec AAL,, Moto Metal 951b, BFG A/T
    Call me crazy, but why not just put the bike in the bed of the truck?
  7. Jul 19, 2011 at 7:15 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Call me crazy...but how are you going to drive it home with the truck legally @ 15.5 years old?
  8. Jul 19, 2011 at 7:23 PM
    horwitzs
    Seth
    Dayton, WA
    TX Pro
    Ah, I get what you are saying...
    You want the front tire to have good contact with the front of the trailer to help keep it from moving side to side. A steep angle might make that difficult.
    Have you seen the trailer? Does it have a chock of any sort that secures the front wheel?
    EDIT: Nevermind, I see it on their web site; It does have a notch in the front for the wheel.
    Just make sure the straps are nice and tight so it won't creep backward, and maybe run extra straps from the passenger peg brackets to the side rails and you should be alright.
    Honestly I doubt it will have that much of an angle for you to worry about.
  9. Jul 19, 2011 at 7:26 PM
    trek
    trek the boss man
    California
    2010 tacoma sport TRD
    X2
  10. Jul 19, 2011 at 7:35 PM
    kingston73
    North eastern Ohio
    09 SR5 4.0L 4x4
    You'll definitely be fine height wise, I hooked up one of those uhaul trailers and put my honda cx on it, which weighs about 550lbs, and my truck's a 4x4 and the angle was fine, no issues at all.
  11. Jul 19, 2011 at 7:49 PM
    franzcars
    Justin
    ST.louis MO
    08 Base Taco I4
    i have my permit, so ill have a parent with me? also with the bed, it'd b had and i wouldnt want to ride it into the bed cause i'd b woried it fall off the ramp
  12. Jul 19, 2011 at 8:54 PM
    toysrgood
    toysrgood Well-Known Member
    SC
    2011 4x4 Reg Cab
    Why not walk it up the ramp?
    True though, it was tricky the first few times I loaded my 600rr up, but with practice it was easier. Walking it up in gear seemed easiest for me.
    Don't do this :)
    http://www.youtube.com/watch?v=qmaVlJmHgGc
  13. Jul 19, 2011 at 9:57 PM
    franzcars
    Justin
    ST.louis MO
    08 Base Taco I4
    yeah i'd ratehr not risk that when i'd hav JUST gotten the bike. im not saying i'd rent a trailer everytime but i'd rather make it easy. that would b the first time i've been on a full sized bike. we'd hav my cousin test ride it for us then we'd take it home and i'd take the corse and have fun :)
  14. Jul 19, 2011 at 10:14 PM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    just an FYI. as long as you DON’T think about crashing loading it you wont. now when you are thing about crashing is when you crash. i have loaded atvs and dirt bikes in to the tundra on 6” ramps. tundra+6’ ramps= kinda steep. and every time i was doing it and thinking/ worried about crashing is when i crashed. now when i just set the ramps up and drove up it did fine. and straps the ramps to the truck. you can do it to the bumper they don’t need to be tight just SNUG a nuff they they wont slide back. and don’t stop mid way up.
  15. Jul 19, 2011 at 10:17 PM
    franzcars
    Justin
    ST.louis MO
    08 Base Taco I4
    i know it can b done, but having never ridden a motorcycle b4 it'd b so much easier to use a trailer. thanks for the help guys
  16. Jul 19, 2011 at 10:19 PM
    yotamikez
    yotamikez Street glide or die
    Valrico
    04 civic & 08 Street glide
    What kind of bike is it? Me and my buddy lifted his gsxr600 in the bad of my dakota no problem and didnt strap it in. Why not do that?
    edit: ninja 250 get 2 decent size guys and lift that bitch in the bed end of story.
  17. Jul 19, 2011 at 10:19 PM
    TeamSarcasm
    TeamSarcasm Flawless Escalation to the Ludicrous
    The better coast
    buy two ramps, use one to walk up and use the other the get the bike up, just be gently on the throttle and youll be fine
  18. Jul 20, 2011 at 5:06 PM
    WTtoolman
    William
    Omaha, NE
    Whether it's going into the bed or onto a trailer, you're still going to have to push it up a ramp. A 2wd non-prerunner isn't gonna be much higher than a trailer, if at all.
  19. Jul 20, 2011 at 9:13 PM
    franzcars
    Justin
    ST.louis MO
    08 Base Taco I4
    withe the trailer it's much lower than the bed, aka easy to push up the ramp.
  20. Jul 21, 2011 at 6:02 AM
    macgyver
    Brad
    Canton, GA
    Quit being a puss and put it on your roof like real men do.
    lol j/k
