Hauling compost, how full can I fill the bed?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Vrbas, Apr 20, 2019.
  1. Apr 20, 2019 at 3:20 PM
    Vrbas
    Vrbas [OP] Well-Known Member
    2013 4x4 DCSB 6speed
    Stock suspension '13 4x4 DCSB V6.
    Initially I loaded it up almost to the bed rails, but the sag concerned me. So I dropped down to about the top of the wheel wells.
    *I'm visiting family and a good friend has some great mulch and compost on his land that worked wonders in my garden last year. He said "load up" so I need to haul it about 350miles back home one way and wanna know how full I can fill the bed in my double cab without ruining anything. I read the manual and know weight capacity for my truck is around 1,000lbs but I have no idea how to estimate the weight of the soil to be honest.
    Thanks for the help.
    *edited for those asking why I'm road tripping with it.
  2. Apr 20, 2019 at 3:27 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Airbags help if you are worried about squatting. But on a side note, I don’t think I would want compost in the bed of my truck. If I had to I would rather use or rent a small utility trailer
  3. Apr 20, 2019 at 3:33 PM
    fb40dash5
    fb40dash5 Well-Known Member
    People's Republic of MD
    11 V6 AC 4x4
    Well it sounds to me like OP already had the poo in the bed... so once pandora's box is opened, why not again, eh? It's a truck, after all... go pull your fertilizer trailer with a Ridgeline. :p
    My answer is, as much as it'll hold, and still steer and stop safely. GVWR is, like, a guideline, man. I piled dried split oak a little over cab height in my 1st gen once... OK that's a bad example actually, it was lifted, and it definitely had sketchy handling, and lots of people noticing my headlights that were aimed way up.
    My technical answer is I don't have an answer, it's going to depend greatly on how dense and how moist it is.
  4. Apr 20, 2019 at 3:34 PM
    Exracer2
    Exracer2 Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    All depends on moisture content. My Kubota could lift a full bucket of spend mushroom substrate when desert dry but could barely curl the bucket when wet. Same with a load on a friends dump trailer. No problem dumping until we got caught in the rain on one load and we ended up shovelling half the load by hand to get it to lift.
  5. Apr 20, 2019 at 3:38 PM
    Bebop
    Nick
    I think I would rather have the trailer full of poo than the ridgeline
  6. Apr 20, 2019 at 3:40 PM
    Vrbas
    My big concern is the highway for extended distance. Should that be factored in any different?
  7. Apr 20, 2019 at 3:51 PM
    Exracer2
    Colchester Ontario
    You want answers yet have no data. As mentioned above weight is variable. The volume you fill your bed to is only one variable as to the actual weight of your load. The weight per cubic yard or meter is the first thing you need to figure out. Who cares what the actual load capacity of your truck is if you can’t calculate the weight of the load. Without any data a guess is a guess is a guess. I guess you are overloaded. I guess you are within your capabilities. Both are 100% accurate and neither can be proven or disproven because you have no data to make any calculations.
    How long your trip is is irrelevant for the most part.
    Norton, spitdog, SC4333 and 2 others like this.
  8. Apr 20, 2019 at 3:55 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Best answer so far. In my 2015 DCSB 4.0 V6 4WD AT with myself (200lb), some emergency equipment (50lb), sliders and front bar (150lb), and stock tires at 29/32psi, I calculated a "safe" bed weight at around 700ish pounds in order to abide by GVWR.
    whatstcp[QUOTED] likes this.
  9. Apr 20, 2019 at 3:55 PM
    fb40dash5
    11 V6 AC 4x4
    Ah, yes... the old Schrodinger's Truck Bed Full of Cow Poop conundrum.
  10. Apr 20, 2019 at 4:02 PM
    Clearwater Bill
    Billy
    Largo Florida
    As long as you don't have it sitting on the bumpstops, or where you pound the bumpstops if on a bad road, you'll be fine.
    Must be some magical stuff if you want to haul it 350 miles. Most folks I know acquire stuff like this locally, load heavy and creep home 5-10 miles.
  11. Apr 20, 2019 at 4:09 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Highway or country road? Smooth roads you just need to be sure you have not bottomed out. Rough road you need more spring travel.
    Why are you moving mulch 350 miles. Get local crap. Less chance of moving insect pests and fungi not currently in the environment.
    Norton, Blockhead and Clearwater Bill like this.
  12. Apr 20, 2019 at 4:14 PM
    Slick Taco
    Slick Taco Id Rather Be Airborne
    Lost somewhere in the PNW
    Current vehicles: 2019 Rav4 Lunar Rock. 2018 TRD OR DCSB KD Max tuned. 2010 Tundra Limited Crew Max . 1991 4Runner Crawler. Ivan Stewart Edition
    KD Max Tune, King 2.5 coil overs T.C. UCA's, Deaver leafs, 17x9 Black Rhyno Warlords, 33" Toyo M/T's, Metal Tech rear bumper, Westin HDX drop steps with Bullet Liner coating, K&N CAI, Baja Designs fog pods, Rigid Midnight addition 3" pod ditch lights. Cali Raised brackets and 32" behind the grill mounted light bar, Southern Style Offroad Lopro Stage II front bumper, Warn winch, FACTOR 55 Ultra Hook, FACTOR 55 Hawes Fairleed, full debadge, Cosmetic goodies such as 15% carbon tint, matte black in channel rain guards, interior LED's, Teton Workshop shift knob, Inferno vinyl detailing on the interior, Cali Raised multi rocker switch cubby insert with Mc Tuning LED switches and a few other mods I've probably left out.
    What Billy said...that must be some magical sh!t to justify a 700 mile round trip. What is it and where can I get some?
  13. Apr 20, 2019 at 4:20 PM
    2015WhiteOR
    Gainesville TX
    Loading the bed by the deflection of the leaf springs makes sense on the surface but seems like a bad strategy when you consider how the bed is constructed on these trucks.
    We've seen posts here of guys whose beds were loaded so heavily (and regularly that way), such that the bolts holding the polymer bed to the frame wallowed out the holes in the polymer.
    Not saying this will happen to the OP on his compost haul, but it's something worth considering. If the bed on these Tacomas was made of steel, I'd feel differently on the matter.
  14. Apr 20, 2019 at 4:25 PM
    Troyken
    Troyken Well-Known Member
    NY
    2013 DCSB v6 off road 4x4 6 spd. MT
    Mulch is generally agreed to weigh 6-800 lbs./ cubic yd.
    Dirt about 2000 lbs / cubic yard
    Sand about 2600-3000 lbs. / cubic yard.
    Screened stone about 3000 lbs/ cubic yard.
    I have carried one yard of mulch which filled the bed right to the top of the sides and I could cover it with the roll up tonneau.
    I have also carried about 1/2 yard of screened stone many times. Distances under 10 miles on side roads.
    Wet compost can be very heavy depending on moisture . I would not take that kind of load 350 miles at, I would assume, highway speeds. I try carry about 1200-1300 lbs. as my maximum.... springs, bags, or otherwise. I would say 1/2 yard maximum of anything loose AND dense should be at the maximum payload. That, of course, depends on how your truck has been modified and what it weighs at the curb. My sticker payload is 1260 lbs. I took two full loads of branches and wood from some Bradford pear trees I cut down to the dump. That filled the bed and I used a bed extender too. Weight on scales, 700-800 lbs. each load. This truck is a half ton pickup equivalent to an older F-100. I just saw a parked late seventies early eighties step side F-100 tonight. I looked at the springs just to see. It had a thin main leaf and two thin, shorter leaves, just like what most of us have but without the overload.
    For the safety of others and the longevity of your truck, please follow the posted payload ratings.
    Vrbas[OP], CrustyTaco and 2015WhiteOR like this.
  15. Apr 20, 2019 at 4:30 PM
    Vrbas
    Not magical, just free when visiting family. Just figured I'd load up to re soil my garden. 350mile one way.
  16. Apr 20, 2019 at 4:38 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    It is a lot heaveryer that others will lead you to believe have a look at this, moisture is a big factor mulchstoremn.com/faq.html
    cruxofthebisquit likes this.
  17. Apr 20, 2019 at 4:56 PM
    Vrbas
    I guess a better question would have been what is the estimated volume of a shortbed loaded with low-to-medium moisture compost/mulch? Is the consensus I'm gathering a yard?
    Thanks for all the help and suggestions everyone, I don't do alot of bed loads so it's why I'm asking.
  18. Apr 20, 2019 at 5:03 PM
    computeruser6
    computeruser6 Nuclear Janitor
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
    It would be better to rent a trailer. It would also be easier to load and unload the compost as well.
    4wheelslacker likes this.
  19. Apr 20, 2019 at 5:53 PM
    2015WhiteOR
    Gainesville TX
    And a cheap tarp to put down BEFORE the compost is dropped on. Won't lose any product into the nooks or cracks of the trailer.
    Slick Taco likes this.
  20. Apr 20, 2019 at 6:03 PM
    UKJON
    UKJON Well-Known Member
    Buy a trailer.
    1. Easier to load and unload.
    2. The trailer can be dropped before it's empty if you need to use your truck for something else.
    3. You don't have to worry about somebody crunching your taco with a loader.
    Just my $1.98
