Hauling drywall
Discussion in 'Garage / Workshop' started by Boring, Jun 13, 2010.
  1. Jun 13, 2010 at 6:08 PM
    Boring
    Boring [OP] This space unintentionally left blank.
    Arizona
    5-lug regular cab
    yarp
    What's the best way to load drywall/sheetrock in the bed? I'm buying 1/2"x4'x8' sheets a couple at a time. I've been debating the best way to load them in the truck FOREVER and I actually have to go buy some now. :rolleyes:
    I just don't want to lose it all over the road or waste it by having it damaged from the trip to the house. My whole justification for buying the truck was remodeling, so I have to get this done myself (no having it delivered). The trip from the store is pretty short, but not too smooth. Top speed limit is around 40-45 MPH depending on which store I buy from.
    I have the longer bed, but no hitch or trailer. Straps? Rope? Net? Tarp?
    Thanks!
  2. Jun 13, 2010 at 6:11 PM
    Vidman
    Vidman Protected by Sig
    Rick
    central Mass
    2024 Trailhunter
    Not Enough
    Just put it in the truck and go have fun. you have the long bed and with the gate down you will be fine....just don,t tip her over
  3. Jun 13, 2010 at 6:12 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    I dont think they fit between the wheel wells right? If they do just slide them in and leave the tailgate down and strap em.
    If not, I would lay them in like this / Just more lower. Put the left against the floor and wheel well and the right against the top of the top. Then strap them in.
  4. Jun 13, 2010 at 6:18 PM
    AK27
    AK27 Well-Known Member
    i just put them in and rest them on the top of the tailgate. if your really concerned, get two 8' 2x4s and use them to support the drywall
  5. Jun 13, 2010 at 6:18 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Buy a sheet of 3/4 ply at the same time as the drywall , put a 2x6 across the notches in the bed walls above your wheel wells . Put the plywood on the 2x6 , leave the gate up and stack the drywall on the plywood . As long as you aren't stupid about how many sheets of gyproc you take in one trip this will work and the drywall will be supported by the plywood and won't crease or crack .
  6. Jun 13, 2010 at 6:23 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    This is what I did.
  7. Jun 13, 2010 at 6:30 PM
    getaway
    getaway New Member
    Birmingham, AL
    2010 DC TRD Sport 4WD
    I keep a piece of plywood (4' x8') and take it to the supply store to support the drywall over one of the wheelwells. As above, I still load it on an angle /, tailgate down, and I just put the plywood on bottom. As always the drywall is in two packs with back sides facing out, but if you separate the sheets make sure one of the back sides is facing the plywood. I have put a strap over the end for piece of mind but the load is very heavy and I doubt would shift but you never know who may cause you to make a sudden move on the road. Good luck, makes me tired just thinking of hanging drywall. Also if you are new to drywall and jointing check out www.drywallschool.com I found it pretty helpful.
  8. Jun 13, 2010 at 6:45 PM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    this works great
  9. Jun 13, 2010 at 6:51 PM
    Boring
    Arizona
    5-lug regular cab
    yarp
    Man, you guys are fast. They don't fit between the wheel wells and they hang just over the end of the tailgate with it down.
    I've taken MDF and plywood home on top of the closed tailgate, but I didn't think the drywall would survive the trip.
    I was considering having the gate down and making some kind of "ramp" to help support it. I know if I buy 2x4s just for the drywall it will seem like a waste and I'll have to haul them to the store every time.
  10. Jun 13, 2010 at 6:54 PM
    AK27
    i've carried 6-8 sheets of 8' at a time for a decent distance and never had any issues :)
  11. Jun 13, 2010 at 7:07 PM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    the sheets aren't light, it'll take a lot to get one airborne
  12. Jun 13, 2010 at 7:14 PM
    Boring
    Arizona
    5-lug regular cab
    yarp
    Well, I guess I risk $14 (2 sheets) and try the AK27 method. Thanks guys. I post if it doesn't work out. ;)
  13. Jun 13, 2010 at 7:14 PM
    OZ-T
    Peter North
    British Columbia
    I'm not sure about lumber prices where you are but 2 or 3 , 8' 2x4's are going to cost about $10 . Return them when you are done if your budget is that tight , but if you are remodelling , some spare lumber is always handy .
  14. Jun 13, 2010 at 7:32 PM
    AK27
    i am not responsible for any damage! :D :p
  15. Jun 14, 2010 at 4:40 AM
    kris77
    kris77 Born in the Backwoods
    West Virginia
    08 DC TRD Sport Speedway Blue
    In channel Vent Visors, AVS Bug Shield, Hankook Dynapro RF10 265/70/17
    I usually do this, but a little different. I put 2 screws in each board to hold the plywood, and leave the tailgate down. Use the D-Rings and ratchet strap everything down in the front and rear.
  16. Jun 14, 2010 at 8:23 AM
    Burns
    Burns Excellent Member
    17 DCSB Off-Road
    Bilstein 5100's @ 2.0", Wheelers 1.5" AAL, 265/75/16's
    This is what I do, 2x4x8s are less than $3 each. I also secure the whole load with tie downs.
  17. Jun 14, 2010 at 11:31 AM
    BuckNakedBooda
    BuckNakedBooda There's no place like 127.0.0.1
    Woodbridge, Virginia
    2013 Toyota Tundra Crewmax Limited 4x4
    I have a bed extender in my Tacoma and what I've been doing lately is placing three 2x4s from the front of the bed going over the extender at an angle then laying the drywall down. Throw on a couple of straps and it works great.......
  18. Mar 14, 2011 at 6:16 AM
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    Old post but a tip from another DIY'er. I put 2x4 rails across the bed in the notches designed in the bed, usually there are three and then lay the drywall over it. I have hauled 12 sheets like this in my Dakota. Use a strap at the back going fom under on the left to over on the right to hold it in the back.
    This method makes UNLOADing a hell of alot easier compared to having it all resting on the tailgate on an angle. As for you 5ft bed guys, you may have to use a sheet of drywall or 2x4s running lengthwise to keep the stuff from snapping.
    Cheers
  19. Mar 14, 2011 at 6:32 AM
    TacoDaTugBoat
    TacoDaTugBoat Well-Known Member
    Goshen, Ct
    13 DCLB TRD Sport
    I trimmed the ends of 2 2x6's so they rest flush in the notches with the top of the wheel wells. Then just load the sheets on top of the boards and they are supported by the two boards and wheel wells. Then ratched strap accross the ends using 1 D ring and 1 tailgate latch. I think I have hauled about 20 sheets at a time and there is still room under them for more supplies. I just keep the boards in the garage when not using them. You could probably buy 1x6 and screw a strong back to the lower side if you dont want to notch the ends of a 2x6.
  20. Mar 14, 2011 at 7:12 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    This ^^^
    Also do yourself a favor and spend the extra $0.20 a sheet and buy the lightweight drywall. It weighs about 30% lighter and believe me it's worth the extra expense. Your back and arms will thank you.
