Hauling lots of firewood/upgrading suspension
Discussion in 'Suspension' started by Ak yoda, Mar 23, 2015.
  1. Mar 23, 2015 at 7:19 AM
    Ak yoda
    Ak yoda [OP] Member
    2011 sr5 tacoma
    So I've been using my 2011 double cab 4x4 sr5 to haul and sell firewood. The rear has been sagging a lot and bottoming out under loads. I've realized that I was carrying too much weight in the bed. While I still want to use my tacoma to haul wood, albeit much less, I'd like to beef up the rear to accommodate for the weight. I don't do any real off-roading and am not interested in making a hobby out of modifying my truck. I would possibly like a small lift (1.5""-2") but want to maintain factory performance. I'm leaning towards new rear leaf packs and shocks. Any suggestions on brands or specifics? I'm also wondering what I'll have to do to the front end to level it out? I have basic tools and some mechanical aptitude and am wondering if I can take this on or should I pay a mechanic?
    Thanks!
  2. Mar 23, 2015 at 7:23 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Could always get air bags in the rear.
  3. Mar 23, 2015 at 7:27 AM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    If you don't want a lift I'd say either replace with Alcan custom springs or air bags are the 2 best options. The cheapest option is get a helwig helper spring or maybe a set of 2 per side.
    With Alcan, you can give them your requirements and they'll make a set of springs to fit your needs and it isn't much more than any other rear leaf replacement set.
  4. Mar 23, 2015 at 7:28 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If you want to maintain stock height and ride when unloaded, air bags might be a good option for you. You can adjust them to the load you're carrying. If you want a lift, you can check out Old Man Emu full kits that come with replacement leaf packs and shocks for the rear and coilovers for the front. You can vary the amount of lift depending on the kit you choose. Install isn't terrible if you're mechanically inclined and it helps to have another set of hands. You only need basic hand tools and a couple floor jacks for install (impact tools make it easier to break free some of the stubborn bolts). BJMoose made a great thread with pictures on installing a full OME kit. Read through the thread and see if it's a job you'd want to tackle.
  5. Mar 23, 2015 at 7:31 AM
    Clearwater Bill
    Billy
    Largo Florida
    No problems with breaking/cracking the plastic bed yet?
  6. Mar 23, 2015 at 7:43 AM
    Cloudmaster
    Cloudmaster Well-Known Member
    Dustin
    Elko,NV
    2006 Tacoma
    Off road things
    I have the OME 3" lift with a Dakar spring pack in the rear. it's working great I have never bottomed out with the new leafs.
  7. Mar 23, 2015 at 7:44 AM
    ThomasMore66
    Dallas/Fort Worth & Durango
    I'm running the OME Dakar's in the back and they'll take a load.
  8. Mar 23, 2015 at 7:47 AM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    X2 on the airbags, they work great for me hauling a pretty good amount of weight in the bed.
  9. Mar 23, 2015 at 7:49 AM
    Clearwater Bill
    Billy
    Largo Florida
    Yeah, recall seeing a couple incidents that popped or cracked the bed. I just think of throwing in firewood as a risk factor for that (more than the dead weight) but maybe it's loaded with reasonable care...........
  10. Mar 23, 2015 at 7:56 AM
    OutbackHack
    OutbackHack Well-Known Member
    Evergreen, CO
    2014 DCLB Heavy
    Stupid amount of extra heavy metal all over
    x3 on the airbags, easy to adjust on the fly so that the truck doesn't sag under load or ride overly stiff when empty
    Also recommend the Daystar airbag cradles, that way you don't loose suspension travel or risk tearing the airbags when offroading or putting the truck on a lift at the shop.
  11. Mar 23, 2015 at 10:39 AM
    Ak yoda
    Ak yoda [OP] Member
    2011 sr5 tacoma
    I'll look into the airbags. I'd like to get this done for under 1000. I also have a roadmaster active suspension spring on the rear which I beleive does help on the hwy with a load.
  12. Mar 23, 2015 at 10:43 AM
    Boone
    Boone, NC
    Airbags deployed
    Don't know if they are the cheapest out there, but the kit and a hour of your time will be substantially less than a grand.
    http://www.autoanything.com/suspension-systems/77A2966A2341544.aspx
  13. Mar 23, 2015 at 12:03 PM
    Ak yoda
    Ak yoda [OP] Member
    2011 sr5 tacoma
  14. Mar 23, 2015 at 12:05 PM
    Boone
    Boone, NC
    Airbags deployed
    I do. Put them in a couple weeks ago and have nothing but good things to say about them. Quick easy install, about 5 pumps per bag with a bike pump and they are around 30 psi. Didn't go with the electric pump to keep it dirt simple.
  15. Mar 23, 2015 at 12:09 PM
    Boone
    Boone, NC
    Airbags deployed
    It's simple and effective so far. I'll report back this week after I have a few thousand more miles on them.:D
  16. Mar 23, 2015 at 12:16 PM
    Boone
    Boone, NC
    Airbags deployed
    I haven't done taxes either.:anonymous:
  17. Mar 23, 2015 at 12:43 PM
    Boone
    Boone, NC
    Airbags deployed
  18. Mar 23, 2015 at 1:30 PM
    BYBO
    BYBO Well-Known Member
    Byron
    Indiana
    Firestone ride rite
  19. Mar 23, 2015 at 1:59 PM
    Ak yoda
    Ak yoda [OP] Member
    2011 sr5 tacoma
    I'm hauling 1/2 cord of semi seasoned birch.
  20. Mar 23, 2015 at 2:50 PM
    Ak yoda
    Ak yoda [OP] Member
    2011 sr5 tacoma
    Like this
