Hauling Surfboards on OEM Rack
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bolt79, May 3, 2013.
  1. May 3, 2013 at 4:18 AM
    Bolt79
    Bolt79 [OP] Well-Known Member
    White Springs, FL
    2022 Lunar Rock Trail Edition
    Screen ProTech kit, JDMCAR center console organizer, JDMCAR Center Console Armrest Cushion, Toyota door sill protectors, Black Toyota tailgate letter inserts
    I've ordered an OEM roof rack that will primarily be used to haul surfboards. I need suggestions on the best way to attach my boards to the rack.
    Has anyone used the Thule "Double-decker Surfboard" carrier or the "Board-locker" attachment made by Inno? Does anyone know if they will even fit on the OEM rack? I really like the fact that these two attachments allow you to lock down your boards deterring thief.
    Info on these options or any other suggestions would be greatly appreciated. Also, pictures of Tacomas hauling boards on OEM racks would be great!
  2. May 3, 2013 at 3:49 PM
    Bolt79
    White Springs, FL
    Come on, I know somebody on here surfs and hauls their boards on an OEM roof rack!
  3. May 3, 2013 at 4:22 PM
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
    I just put it in the bed. I have bed racks by Inno.
  4. May 3, 2013 at 11:39 PM
    PahalaTacoma
    PahalaTacoma Well-Known Member
    Tucson, AZ
    2017 Tacoma TRD PRO
    i have the Thule SUP taxi on the OEM rack and have a 9' board. it holds fine. Should have no problem holding 2 stacked
  5. May 4, 2013 at 4:20 AM
    Bolt79
    White Springs, FL
    Thanks for the response, Pahala. Does your Thule carrier lock and could you possibly snap a picture of your set up the next time you've got it loaded up and post it?
  6. May 4, 2013 at 5:00 AM
    DLAV
    DLAV Well-Known Member
    Denis
    SK
    12 DCLB Barcelona Red
    N-Fab Steps, Weathertech floor mats, Oem Bed mat
    I also have the Thule SUP carrier on my truck. It's mounted on the Thule 422XT Xsporter. I find that it is easier to load the boards (especialy for my wife)then it would be on the OME Rack. But our boards are 12'6 SUPs
  7. May 4, 2013 at 8:51 PM
    Bolt79
    White Springs, FL
    Thanks for the info guys. I ended up ordering the Thule Double-decker Surfboard carrier from Auto Anything. I'll update whenever I get everything installed.
