Haunted Truck or Intermittent Beeping While Driving Driving Me Crazy!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ethanmr, Jan 18, 2024.
  1. Jan 18, 2024 at 8:40 PM
    ethanmr
    ethanmr [OP] New Member
    2005 Red Tacoma 4x4 6-Speed
    Having a strange issue on my 05. It’s a 4x4 6 speed manual, and a week ago it started beeping sporadically while driving. It’s the exact beep that it does when you put it in reverse on a manual. At first it was super sporadic and random, primarily when coasting/decelerating but not only then. Normally it would go away after driving awhile, and sometime it wouldn’t do it at all. No warning lights /abs light/check engine lights. Today it got worse, and started doing it every time I applied the brakes, even at a stop. Brakes are working flawlessly.
    2 factors that might have had an effect on it.
    1. This happened immediately after fixing a misfire cause by a bad ignition coil. Swapped it with a denso coil and the misfire went away. (Forgot to unplug the battery while doing this, but truck was obviously turned off)
    Once i fixed it and started driving it again the beeping started.
    2. I also washed it the day before the coil swap, maybe water got somewhere it shouldn’t have?
    Any thoughts? 1500 mile road trip planned for the weekend and would love to not deal with the beep the whole way. Still have no dash lights to indicate any issues, and reverse lights are working fine.
  2. Jan 18, 2024 at 8:56 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    If it's the same beep as when you put it in reverse then I'd be looking into the backup light circuit. Do you have aftermarket taillights? If a wire was rubbing/shorting onto another wire back there it could possibly backfeed into the circuit make the chime go off. Check the reverse light switch on the side of the trans and see if it's closed when it should be open
    Dm93 likes this.
  3. Jan 18, 2024 at 9:16 PM
    ethanmr
    I think that’s a good plan. I do have an aftermarket backup camera installed that I have hooked in to my backup light circuit. It turns on every time that circuit gets power. It’s been hooked up for a year and has been flawless. When the beep happens, the camera has yet to turn on, making me assume that it’s not getting power. Maybe there’s a short that’s brief enough that it doesn’t get power long enough to power on. Not sure. Any thoughts?
  4. Jan 19, 2024 at 4:57 AM
    ethanmr
    Just curious. I replaced the reverse switch last year, and it may be going out. If I just unplug the harness for this trip, I know I’ll lose backup lights and I think the beep. Any problem with doing that while I get this sorted? This beep might drive me crazy in the truck all weekend.
  5. Jan 19, 2024 at 6:14 AM
    Waasheem
    Waasheem
    2007 xrunner
    Intermittent issues can be a pain to troubleshoot.
    I’d start with the brake bulbs since it’s doing it now when braking. Look for a broken filament, connection at the bulb socket.
    Also try unplugging the tail light connectors, see if the problem disappears, plug one at a time back in to see if it returns.
  6. Jan 19, 2024 at 6:20 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Your fine doing that but I'd tape it up to keep moisture and debris from getting into the connector.
  7. Jan 19, 2024 at 8:35 AM
    Derk33
    Derk33 Well-Known Member
    Derek
    Pennylvania
    22 Army green TRD OR
    Sounds like either your brake lights are somehow feeding voltage to your reverse circuit or check under the dash, your brake pedal could be grounding out a wire for the back up beeper and causing it to beep. I’m not sure if there are any ground controlled relays in these trucks or not. I’d also check grounds at the back of the truck, faulty grounds can do some really weird stuff.
  8. Jan 19, 2024 at 8:40 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Strange, but which Tacoma's have a backup beeper? I have never heard one beep nor have I seen anything in the circuit diagrams about a reverse beeper.
    Puzzled.
    TXpro4X4 and steelcity2 like this.
  9. Jan 19, 2024 at 8:46 AM
    steelcity2
    steelcity2 Well-Known Member
    Pittsburgh Pa
    2013 MGM DCSB TRD sport
    Bilsteins 5100's all 4 corners 1 inch rear spacer
    I was thinking the same. But I have an auto.
  10. Jan 19, 2024 at 8:51 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Only 6 spd manuals have it, I think it's a safety because reverse is where 1st would normally be on a 5 spd manual.
    steelcity2 likes this.
  11. Jan 19, 2024 at 9:51 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Is it in the circuit schematics? I've never seen a reference to it...
    OP - Sorry for the highjack...
  12. Jan 19, 2024 at 9:55 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I'd have to look, I know the actual beeper is in the Combination Meter (Instrument Cluster). It's the same one as the key in and seatbelt alarms use.
  13. Jan 19, 2024 at 10:12 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Thanks. I was thinking along the lines of an external beeper as you hear on commercial trucks to warn pedestrians of a backing vehicle...
    Dm93[QUOTED] likes this.
  14. Jan 19, 2024 at 10:15 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Nope it just gives one beep as a caution that your in reverse.
    Jimmyh[QUOTED] likes this.
  15. Jan 19, 2024 at 10:52 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Thanks for the response.
    Yet another useless feature I can live without.
    LOL
  16. Jan 19, 2024 at 10:56 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Doesn't bother me, it's there but if it would happen to stop working I probably wouldn't worry about it.
  17. Jan 19, 2024 at 11:02 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Feel the same about the clutch pedal switch.
  18. Jan 19, 2024 at 11:37 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Idk I think those kind of safeties are a good thing but some of the nannies they are putting on stuff now are just stupid.
  19. Jan 19, 2024 at 11:58 AM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    It's only a warning beep that sounds one time when putting it reverse with a manual.
    Not like a truck back up beeper
  20. Jan 19, 2024 at 12:02 PM
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    I'd unplug the camera 1st
    I have a peddle commander, 120k on the odo
    Never a problem
    Installed one of those
    2 months later check engine light and limp mode 2 times. Have not plugged it back in since.
    Not all aftermarket stuff works
    Maybe for a while but never seems to hold up
