have 3" but getting a bumper. what to do?
Discussion in 'Suspension' started by mh.meier, Apr 18, 2012.
  1. Apr 18, 2012 at 10:52 AM
    mh.meier
    mh.meier [OP] PB MIKE Vendor
    MAD MIKE
    Flagstaff AZ
    Truck Norris Silver Unicornimus Prime
    2008 Tacoma DCLB 4X4 SR5 -Pelfreybilt Steel front single-hoop bumper(, color matched -Heretic Studios 20" single row light bar -Rigid Dually D2 Flood pods -KM FABRICATION custom 1/4" steel bumper mounts -Warn ZEON Platinum 12,000lb Winch -Pelfreybilt Rear HI-Clearance bumper with swingout -NATO can carrier -Folding Aluminum table -RIGID SRQ reverse lights -Full Pelfreybilt skids -ARB air compressor under the hood -Custom CO2 Setup -KMFAB Custom ext brake line brackets -KMFAB Bedrack -Camping Lab MANSION RTT -ARB Touring 6' Awning -Litra Torch camping light -CTC Bed Cap, color matched -Toyota OEM bedmat -KMFAB bed reinforcement -AVID Offroad weld on slider -BAMF Bed corner tie down brackets -Custom chopped front fenders -Front custom satoshi gille, color matched -OTTRAW switches -King Ext Travel front CO's -King 700# coils -Total Chaos Uni-ball UCA's -Dirt King stock length lowers (soon to be installed) -Sway-A-Way 2.0 rear ext travel shocks -All-pro Expo LEaf packs w/ custom bumps -35" Goodyear Wrangler MTR's w/ Kevlar -16" SCS SR8's in Black -Custom Retrofits -Smoked Tails -Airflow Snorkel -Cobra 29LX CB with PA and the fixins' -KMFAB CB antenna mounts -Pioneer in dash DVD with Nav -Weathertech mats
    I lifted my truck myself, all pro standard leafs in the rear, with Billy 5100 RCD's and a ubolt flip and I have Billy 5100's set at. 85 with OME 885 coils and camburg UCA's and i still have the factory rake which is weird. I was sure that i would be sitting level at 3". I am sure i will have to upgrade my coils to the OME 886's when i get my bumper but what else do i need to get my 3 inches? Any input would be good. And yes i have read multiple threads and searched but i have already installed what was supposed to be a 3" lift and no luck. Thanks guys. You rock.
  2. May 16, 2012 at 2:27 PM
    Large
    Large Red
    What did you end up doing
  3. Jun 2, 2012 at 8:26 PM
    YFZ450MOE
    YFZ450MOE When you blow off steam you get an eyepatch
    Moe
    Auburn, WA / Roseburg, OR
    09 white DCSB TRD (it's getting there)
    Icon Extended Travel 2.5" Coil Overs All-Pro U-Bolt Flip Kit Bilstien Rear Shocks Fabtech Add-a-Leaf Icon Upper Control Arms All-Pro Rear Bumper w/ Wrap Arounds & Hitch with custom LED plate light BHLM and Morimoto III D2S retrofit Satoshi Grill 2 Hella Black Magics behind Grill Bestop Supertop BAMF sliders
    I'm about to do the same and i need to know what spring rate to run to maintain my 3". I dont want a harsh stiff ride but i also dont want my taco driving around with its face in the dirt!
  4. Jun 3, 2012 at 9:07 AM
    mh.meier
    MAD MIKE
    Flagstaff AZ
    With my dclb I had to run the OME 886 coins for the bumper just to get a 3" lift and I don't have any kind of bumper on there at all right now haha! and for some reason I have super taco lean and my drivers side is 1" shorter than my passenger side!
  5. Jun 3, 2012 at 5:39 PM
    Large
    Large Red
    Maybe you left the driver side with the 885 and put a 886 in the passenger? 1" taco lean is whack.
  6. Jun 3, 2012 at 5:44 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Are you decided on a bumper yet? Relentless makes an aluminum bumper that only weights like 60 lbs. With that bumper you could keep your current setup.
  7. Jun 3, 2012 at 6:19 PM
    YFZ450MOE
    Moe
    I am going to get the all pro. I like the option of being able to remove the sides. I want to color match them to my truck and I just looks awesome. I was thinking a king (or equivalent) 14" shock with a 700lb spring rate. Would that work well to maintain the lift and keep a good (not stiff) ride?
  8. Jun 4, 2012 at 7:07 AM
    mh.meier
    MAD MIKE
    Flagstaff AZ
    That would be a pretty awesome set up
  9. Jun 4, 2012 at 7:07 AM
    mh.meier
    MAD MIKE
    Flagstaff AZ
    And No ihavent decided on a bumper. The economy is bad but bumper prices haven't gone down haha!
  10. Jun 4, 2012 at 7:23 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    How do you figure a 700lb spring rate coil is not going to be stiff ?
  11. Jun 4, 2012 at 7:44 AM
    mh.meier
    MAD MIKE
    Flagstaff AZ
    It would be stiff. My 885 coils are pretty stiff but not too bad now that they are broken in. And yeah I don't get Howie have so much taco lean. I'll have to preload my driver side shock and it still won't be even.
  12. Jun 4, 2012 at 11:35 AM
    YFZ450MOE
    Moe
    Well oz I really don't know and that's why I am asking!
  13. Jun 4, 2012 at 11:38 AM
    OZ-T
    Peter North
    British Columbia
    I C
    Thought you were stating not asking , my bad , I misread your sentence
    700lb spring rate coils will ride stiff
  14. Jun 4, 2012 at 11:50 AM
    YFZ450MOE
    Moe
    Thank you kind sir! So then a 650lb with the preload cranked up is what am looking at. I just talked with Downsouth motorsports and they said that the manufacturer recommends that i keep their spring on the shock which is 600lber. Can i change the springs out pretty easy on their setup?
  15. Jun 4, 2012 at 11:56 AM
    mh.meier
    MAD MIKE
    Flagstaff AZ
    I bought Billie 5100's and ome 885 coils and did the install of the coils myself. It's cheaper to buy them separately and do it yourself but it looks nicer and rides better when you buy the whole set up.
  16. Jun 4, 2012 at 2:52 PM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    First thing first, don't preload 5100s when using OME coils. Now, if you decide to use 886s it is recommended that you pair them with OME nitrocharger shocks.
  17. Jun 4, 2012 at 2:59 PM
    YFZ450MOE
    Moe
    I just ordered a set of icons, I'm going to see how they hold up with the 600lb spring. If it **** to much after i get the bumper I'll upgrade to a 650lb spring in hopes that it will help! Thanks for the info guys. Much appreciated
  18. Jun 4, 2012 at 3:27 PM
    mh.meier
    MAD MIKE
    Flagstaff AZ
    I'll upgrade shocks and coils when I have the chance. Both Billie's are set at the recommended .85 to get 3" of lift but until I can figure out why my lean is so extreme I'll have to set the driver side to 1.25 which still won't get the driver side as high as the passenger side.
  19. Jun 4, 2012 at 3:34 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Camburgs, Methods, Vision X, BFG
    Depends on how much weight you run and how much you crank them up!
  20. Jun 4, 2012 at 3:37 PM
    OZ-T
    Peter North
    British Columbia
    700lb spring rate coil is a lot for a relatively light AllPro bumper , no ?
