Have a confusing problem with the head light...please help!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JoshBradt49, Feb 6, 2014.
  1. Feb 6, 2014 at 2:19 AM
    JoshBradt49
    JoshBradt49 [OP] Member
    Arkansas
    06 TRD SR5
    Hey guys, I just bought my 2006 Tacoma SR5 about three months ago. I have a few problems with it but I got it about 5 grand under book so I was willing to work with it. One problem that has come up is my low beam head lights have stopped working while my high beams do work. I figured replace the bulb and I'm good but then I noticed that the high and low are the same bulb. I checked the low beam fuses and they are good. Any ideas on what can cause this and how to fix it? Thank you
  2. Feb 6, 2014 at 3:12 AM
    seanboy
    seanboy Well-Known Member
    '13 TRD Sport
    It is a very rare case that I have seen, where both low beam filaments could be out at the same time. Probably will not hurt to buy 1 bulb, install and check to see if in fact that it is just the filaments that are out (single bulb dual filament) . Before doing so, check all wires to eliminate and grounding issues that may cause the low beam circuit to be malfunctioning. Keep us posted, and good luck!
  3. Feb 6, 2014 at 3:21 AM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    X2
  4. Feb 6, 2014 at 11:08 AM
    Skunkman
    Skunkman Well-Known Member
    Syracuse - Tug Hill
    2007 Tacoma Access Cab ,
    I was running Sylvanias in mine, and one night on the way home had 2 low beams blow at the same time, never heard of it before. Drove home with the high beams, and 2 new bulbs solved it.
  5. Feb 6, 2014 at 11:26 AM
    L J
    L J Well-Known Member
    Illinois
    07 4X4 SR5 TRD Sport DCLB
    Get a volt meter, turn on the headlights and check for current. Simple.
  6. Feb 6, 2014 at 11:36 AM
    anotherreject
    anotherreject Well-Known Member
    Ive had both low beam filaments blow at the same time 2 times now, shot happens especially when running anything other then a stock long life bulb
  7. Feb 6, 2014 at 9:33 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Fixed that for you.
  8. Feb 6, 2014 at 11:57 PM
    Foihdzas
    Foihdzas VA7PTZ
    Danny
    B.C Canada
    2010 Dbl Cab 5' Box 6 Speed
    2010 Tacoma, sold...
    lol, I was hoping someone would "fix" that.
  9. Feb 7, 2014 at 5:57 AM
    maykevin5
    maykevin5 Well-Known Member
    Kevin
    Carbondale Illinois
    2012 Tacoma SR5
    3 inch lift, stainless steps, JL/Focal audio sound system
    low beam relay?
  10. Feb 7, 2014 at 7:01 AM
    L J
    Illinois
    Thanks Jimmyh. I'm not an electrician so maybe I was technically wrong. Is current the flow of electricity? I hope at least I got that right. I was trying to point out that rather than guessing what part may or may not have failed it would be easier to connect a meter that measures voltage to the low beam side of the headlight plug, turn on the headlight switch and see if the meter detects anything. Would this work?
  11. Feb 7, 2014 at 8:11 AM
    JoshBradt49
    Arkansas
    06 TRD SR5
    Hey thanks for all the advise. Replaced the bulbs this morning and it was just that simple. I feel stupid now but it threw me off that both did it at the same time. Thanks for all the help!
  12. Feb 7, 2014 at 11:21 PM
    seanboy
    '13 TRD Sport
    :woot: That's what we're all here for! :cheers:
  13. Feb 8, 2014 at 5:29 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    You were on the correct track.
    Voltage could be compared to water pressure in a pipe.
    Current could be compared to gallons per minute water flowing through the pipe.
    You just cannot measure current with a voltmeter. You would need an ammeter to measure current.
