have a few questions about a lift
Discussion in '1st Gen. Tacomas (1995-2004)' started by ethanfoy, Feb 3, 2012.
  1. Feb 3, 2012 at 7:16 PM
    ethanfoy
    ethanfoy [OP] Well-Known Member
    ethan
    Little Rock AFB
    99 toyota tacoma xcab 4x4
    im wanting to put a lift on my 99 xtra cab that is a DD and hunting/offroad truck. I've search and these are the questions that i couldn't find an exact answer to. My questions are:
    • How high can you lift it without having to put a diff drop on it.
    • Will a 1in. body lift hurt my truck structurally
    • If i put a lift on my tuck do i need to change anything like steering, brake lines,etc.
    • Is a spacer lift bad.
    • Do i need to worry about axle wrap if i put a AAL with a shackle.
    If there is anything else i need to know before pulling the trigger on the lift please let me know. thanks alot
  2. Feb 3, 2012 at 7:36 PM
    ontarioyota
    ontarioyota Well-Known Member
    @scott777taco INSTAGRAM
    SW Ontario, Canada
    2001 Reg Cab 4x4
    Blacked out badges-rims OME lift with 881's & dakar pacs, summer tires=BFG 31x10.5x15 on 93 4runner rims,winter= 265 75 16 DURATRACS on stock steelies,Flowmaster exhaust, deck plate mod, ARB front bumper
    diff drops are easy a cheap
  3. Feb 3, 2012 at 7:57 PM
    lil J
    lil J Well-Known Member
    Jacen
    Louisville
    99 Tacoma 4wd V6 Horizon Blue
    Old Man Emu Suspension
    Check out Old Man Emu, just put it on my 99, 2 inches of lift no need for breaklines or diff drop. Paid a little over $1100 after taxes and free shipping at autoanything
  4. Feb 3, 2012 at 8:16 PM
    ethanfoy
    ethan
    Little Rock AFB
    o yeah forgot to put that i just replaced my shocks and struts less than 2000 miles ago. I paid close to 300 dollars to replace them i don't really want to replace them again. That is why i asked about a spacer lift. Thanks alot
  5. Feb 3, 2012 at 8:30 PM
    sir1123
    sir1123 Tacomas FTMFW!!!!
    Charleston
    99 SR5 Prerunner, Black,3.4L
    3"Ebaich with 5100 Bilstiens, K&N cai, 5% 3M Tint, Magnaflow 18", Hella 500s with 35w 3000k hid retro, 33x9.5x15 BFG A/T
    you replaced your shocks and struts? what about your coils? if you didnt change your coils i think you can put the ome coils on....you will have to ask sombody else about this option because those coils might only be compatible with ome shocks
  6. Feb 3, 2012 at 8:36 PM
    ethanfoy
    ethan
    Little Rock AFB
    No i didn't replace my coils. I'm 16 years old ,and figured i would listen to my dad to just get shocks and struts. I'm sure someone will chime in if the are compatible.
  7. Feb 3, 2012 at 9:20 PM
    sir1123
    Charleston
    I mean spacers will work for just a dd but i have seen firsthand what happens when you wheel them and hit a stump hard enough.....CRACK!
  8. Feb 4, 2012 at 10:09 PM
    ethanfoy
    ethan
    Little Rock AFB
    I don't plan on any hard core wheeling but alot of hunting. Also i want some extra room for some bigger tires. Thanks alot guys, yall have answered my question.
  9. Feb 5, 2012 at 12:21 PM
    Phuket
    Phuket Well-Known Member
    Travis
    Los Angeles
    03 4X4 TRD
    Eibach/Toytec coils, bilstein 5100's all around, Kenwood DNX7100 Navigation
  10. Feb 5, 2012 at 4:25 PM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    I wouldnt call them a scam. Some trucks need them.....others don't. I got 3" of lift and didnt put it in. keep in mind the diff drop also makes the stock skids and most aftermarket skids unable to be installed.
  11. Feb 5, 2012 at 6:40 PM
    lonzorizo
    lonzorizo Well-Known Member
    Lonnie
    Hoopa, Ca
    2003 TRD OR, 2016 TRD OR Tacoma
    Not true...I have a diff drop and my stock skids fit fine.
  12. Feb 5, 2012 at 6:52 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    This & I don't know how dropping the diff an inch or so to straighten out CV angle can be called a scam....:notsure:
  13. Feb 5, 2012 at 7:19 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Right, 30 bucks to decreasd cv angles is a scam..
  14. Feb 5, 2012 at 7:34 PM
    ontarioyota
    SW Ontario, Canada
    2001 Reg Cab 4x4
    happy with my diff drop....like the stress free cv angles
    had to install the supplied spacers to fit the stock skid back on....was a tight fit
  15. Feb 5, 2012 at 7:46 PM
    Phuket
    Travis
    Los Angeles
    03 4X4 TRD
    well sooorrryy i dont see the point of them if you can do the boot slide mod. like 5-10 bucks vs. 30
  16. Feb 5, 2012 at 8:40 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Not talking about torn CV boots, more about CV angle & the increased stress on all those front end CV "pussy parts" as I call them.
  17. Feb 5, 2012 at 8:42 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Although now that you bring it up, getting the CV's to a more "natural" level angle you probably wont need the boot slide MOD
  18. Feb 6, 2012 at 6:53 PM
    Phuket
    Travis
    Los Angeles
    03 4X4 TRD
    I guess theirs two ways to look at it. I'm not going to argue with you i guess whatever floats your boat you know. The Op's question has been answered, and he has two ways to look at preserving his cv's.
  19. Apr 18, 2012 at 3:50 PM
    ethanfoy
    ethan
    Little Rock AFB
    Well yet another question if I buy eibach coils and billy struts do they come with a top plate and studs or do I have to use my stock ones. Also I'm wanting about three inches of lift what leaf springs do i get. I know this old an old thread but i figured no news in starting a new on.
  20. Apr 18, 2012 at 5:12 PM
    Phuket
    Travis
    Los Angeles
    03 4X4 TRD
    your stock top plate and studs should work fine. Thats how I did mine. do you want a rake look or level? if you like a rake, get All Pro Expo leaf packs.... if you want a level look, get wheeler leaf pack or deaver J59's
