Have a few questions about supercharging my T100.
Discussion in 'Performance and Tuning' started by my96T100, Nov 2, 2021.
  1. Oct 6, 2024 at 9:39 PM
    Jon64l
    Jon64l Well-Known Member
    Jon
    2000 4runner, 1996 Tacoma
    You should be in good shape with your transmission mods. Wish I did them back then.
    I currently do want to keep the ecu. Try car part .com or Lkq to find one.
    The ecu was a direct swap with no other mods needed to run on my rig. Without boost it was fine. Putting the SC on I couldn't even make it to the main road with hearing ping. It had colder plugs and tighter gap. Walbro 190 pump (now aem 340 ethanol pump) I had the Fic wired in and began to pull timing. Quickly the ping went away after that.
  2. Oct 6, 2024 at 10:19 PM
    Jixerboy96
    Jixerboy96 Member
    The truck is definitely more alive with those mods even N/A’d.
    No prob on the ecu, thanks for the recommendations, Lkq is dry but il check out car parts.com
    Do you recall what your original ecu was or what month your truck was made? My driver door label tells me mine was June of 96.. I’m just comparing that to the different ecus that are available. Thanks again I appreciate your help.
  3. Oct 6, 2024 at 10:25 PM
    Jon64l
    Jon
    Mine was 95 build year, I think December but will have to look in the morning. Happy to help when I can.
    Jixerboy96 likes this.
  4. Oct 7, 2024 at 4:02 PM
    Jixerboy96
    Jixerboy96 Member
    Good to know, thanks Jon
  5. Oct 7, 2024 at 6:46 PM
    Jon64l
    Jon
    It was actually October of 95. Spooky
  6. Oct 7, 2024 at 9:05 PM
    Jixerboy96
    Jixerboy96 Member
    Well happy 29th revolution around the sun for your rig. I was worried that your truck was newer-ish than mine and the harnesses / ecu / sensors wouldn’t match up and the 04321 ecu wouldn’t work. I’m working on sourcing that ecu and will report back.
    Question, Any 1996 3.4 4x4 autos running the 04320 ecu with a supercharger?
    Jon64l likes this.
