Have a New Tacoma, reading code 0333, Help Please...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WMRanch, Jul 15, 2013.
  1. Jul 15, 2013 at 8:26 AM
    WMRanch
    WMRanch [OP] Active Member
    Cari
    San Diego
    I've had my '05 Tacoma less than a year and yesterday the check engine light came on, ran a reader and it says code 0333, I've looked a bunch online but can't find anything that actually pertains to the Tacoma engines, it's all Tundra's or FJ's and I believe those are different engines.
    Can anyone help me figure out what this is and how to fix it?
    Thank you in advance! :D
  2. Jul 15, 2013 at 8:30 AM
    Blueitrgsr
    Blueitrgsr Well-Known Member
    Brad
    Gainesville, Fl
    2006 Reg Cab 4wd
    Some bilsteins, OME 885's, and an AAL.
    So unless you've put bad gas into the truck it shouldn't be knocking. And 9/10 it's an issue with the knock sensor itself. Wiring could be bad. Sensor could be loose. But first things first is make sure it's not the gas. Not all gas stations are created equal.
  3. Jul 15, 2013 at 8:31 AM
    WMRanch
    Cari
    San Diego
    It's not actually knocking. Nothing is wrong except the check engine light came on and I have to get it smogged this month. :rolleyes:
    If it's the sensor how do I replace it? Is it something I can do myself?
  4. Jul 15, 2013 at 8:40 AM
    Blueitrgsr
    Brad
    Gainesville, Fl
    2006 Reg Cab 4wd
    I've never done one on my tacoma. But I've change a bunch on some Hondas. And they are a simple unplug the connector and get an open end wrench and unscrew them from the block. But that is me assuming they are the same way on the tacoma. Hopefully someone else will chime in.
  5. Jul 15, 2013 at 8:53 AM
    Azntrutek
    Azntrutek Well-Known Member
    ATL
    08 TRDsport -Towpackage
    2".5 lift, HID head lamp and HID lights, color match tonneau cover and running board.
    It is a hell of the job. You have to remove a lots ( intake, valve covers,header, fuel rails.....etc) get to that knock sensor. Dealer charge 2200$ for this type of work .
  6. Jul 15, 2013 at 5:59 PM
    Blueitrgsr
    Brad
    Gainesville, Fl
    2006 Reg Cab 4wd
    Wow! I remember on my old Rsx all you had to do was reach down onto the front of the block. No more than a 5 minute job!! That's nuts.
  7. Jul 16, 2013 at 11:44 AM
    WMRanch
    Cari
    San Diego
    Yeah crazy, just for a sensor! How the heck am I supposed to get this done before smog. :(
  8. Jul 16, 2013 at 12:22 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Take it to a reputable shop and get it checked and repaired properly. Without proper troubleshooting and just throwing parts at it may fix it, but it is very expensive and time consuming process...
  9. Jul 16, 2013 at 1:47 PM
    WMRanch
    Cari
    San Diego
    Would it work to disconnect the battery and reset it, just to run down and get it smogged real quick? Then deal with it correctly when I have more time?
  10. Jul 16, 2013 at 2:40 PM
    victorramse3
    victorramse3 Well-Known Member
    Victor
    Bakersfield, CA
    2013 Dbl cab TRD OR 4x4
    N/A
    Simply disconnecting the battery to reset the CEL won't work. It used to work back in the day but now when you get a SMOG check they check to see that there have been a certain amount of miles put in since the last ECU reset. Something to do with the ECU having to calibrate itself again (not too sure on the specifics).
    I would suggest taking it to a shop to see if they could provide a more in depth diagnosis.
    Good luck!
  11. Jul 16, 2013 at 2:45 PM
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
  12. Jul 16, 2013 at 2:51 PM
    TMW
    TMW Well-Known Member
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    Light bar and bumper guard, 3/16 steel skid plates for engine, tranny and transfer box, OME 881 springs with 5100 shocks at mid clip. AAL in rear. Positraction rear diff.
    Maybe stop by a smog shop and talk to them as to what it would do to the smog results. Also aren't smog related componets warranty for 100,000 miles? Or do you have over 100,000 on it?
  13. Jul 16, 2013 at 6:07 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Good luck with the P0333 knock sensor code. Mine involved chipmunks. Not cheap.
  14. Jul 16, 2013 at 6:13 PM
    5.56 Well-Known Member
    OKC
    2013 DCSB Off Road
    What's with the knock sensor that apparently makes it rodent filet mignon?
  15. Jul 16, 2013 at 6:17 PM
    hogeyphenogey
    hogeyphenogey Rotted frame = New Truck!
    Dave
    Chicopee, MA
    2015 TRD Off Road Crew Cab
    new truck... No mods yet!
    All cars are now made with a soy based wiring insulation. It smells like dinner to rodents. See chewed injector wiring, fuel pump wiring, etc... All th time where I work.
  16. Jul 16, 2013 at 6:18 PM
    08TacoTrD
    08 TRD Offroad
    It's a nice warm tight space.:eek:
  17. Jul 16, 2013 at 6:32 PM
    5.56
    OKC
    2013 DCSB Off Road
    Since this is apparently a common issue, is there a way to dissuade this from happening?
  18. Jul 16, 2013 at 7:44 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Peppermint Oil.
