Have a problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoMan1991, Jul 27, 2011.
  1. Jul 27, 2011 at 10:00 AM
    TacoMan1991
    TacoMan1991 [OP] Pissed Off
    DFW
    09 PreRunner,Painted things
    dumped exhaust, blacked out tails and third brake, fog light mod, painted rear bumper,rims and front grill,Cobra 29 special edition added.
    I painted my front grill sometime ago and I guess either the clear wasn't done properly or something an now I have some orange peel coming up, I have some questions about getting rid of it, any help guys, I'll show pics if need be
  2. Jul 27, 2011 at 10:02 AM
    resq330
    resq330 El' Capi-Tan
    Josh
    VA
    13 MGM DCSB TRD-Sport
    K&N Drop-In, Dick Cepek 'Torque' Wheels, Wet Okole Seat Covers, LED Interior
    Probably sand and repaint, if you have orange peel.
  3. Jul 27, 2011 at 10:08 AM
    TacoMan1991
    DFW
    Any specific grit?
  4. Jul 27, 2011 at 10:08 AM
    resq330
    Josh
    VA
    Also, make sure your paint/thinner mixture is right. That is, if you using a paint gun and not spray paint.
  5. Jul 27, 2011 at 10:23 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Depends on how bad the orange peel is. If it's really bad, start with lower grit (100 or so) and work to a finer paper from there (probably 400 - 600 grit before paint, the finer the better). Spray paints can cover sanding lines left by 200 grit but automotive paint will not.
    If the orange peel is fine and only in the finish, wet sand with 400 or 600 grit to basically polish out the orange peel.
  6. Jul 27, 2011 at 10:27 AM
    TacoMan1991
    DFW
    Do I need to do any buffing?
  7. Jul 27, 2011 at 10:30 AM
    charles08tacoma
    charles08tacoma Well-Known Member
    Santa Cruz, CA
    08 Prerunner SR-5 Access Cab
    White Snug Top shell
    If you are just trying to sand out slight orange peel, 400-600 is too coarse & will burn through into the base coat, unless you are starting over to paint again. To sand slight orange peel, wet sand starting with 1000, then 1500, finish with 2000 or 3000 grit. Then polish with polishing compound to make it shine again. I use Meguiars products. Be careful not to burn through the clear coat layer into the base coat. If you do, you will have to start again with the base coat, followed by clear coat.
  8. Jul 27, 2011 at 10:33 AM
    TacoMan1991
    DFW
    Do I need to respray the clear coat?
  9. Jul 27, 2011 at 5:47 PM
    charles08tacoma
    Santa Cruz, CA
    I would only if you have heavy orange peel & you have to do a lot of we sanding. Otherwise when the orange peel is gone & pleny of clear coat left, then polish will bring back the shine. You also have to be careful not to use a polish that is too coarse & cuts into the clear cut too deeply.
