Have a roaring noise from left front 30mph on up
Discussion in '2nd Gen. Tacomas (2005-2015)' started by divad94, Mar 4, 2012.
  1. Mar 4, 2012 at 6:03 AM
    divad94
    divad94 [OP] Active Member
    David
    Ivor, VA
    05 Tacoma PreRunner SR5 2WD
    K&N air filter
    Bad roaring from left on my 2WD. When I turn left a little it quiets down, but going straight or making a right turn its kinda loud. I took it to the dealer for a coolant flush and had them drive it. He said without further investigation it could be the wheel bearing. Its been making this noise for about 9 months and I would think that a bearing would have gone out by this time. Any help would be appreciated.
  2. Mar 4, 2012 at 6:11 AM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    Sounds like a wheel bearing.
  3. Mar 4, 2012 at 6:11 AM
    tacos
    tacos Well-Known Member
    Andrew
    NKY
    05 A/C Off Road 4x4
    BHLM,5100's set 2.5,Toytec 2" aal,FJ TRD wheels,AFE pro-dry, Duratracs
    Wheel bearing.
  4. Mar 4, 2012 at 6:14 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Wheel bearing. An easy diagnosis. Jack the truck up and put it on stands. Grab the wheel and try and lift it up and down. If it moves, definately wheel bearing. 2wd's are easier to fix than 4wd, so it's not as complicated as you might think.
  5. Mar 4, 2012 at 6:16 AM
    bh867
    bh867 Well-Known Member
    idaho/utah
    tacoma
    arb bumper winches- xrc 8 front xrc 10 rear 2 lightforce 140's 40" led light bar Custom CBI built bed 4.88' and arb's front and rear tc long travel
    Wheel bearing
  6. Mar 4, 2012 at 8:26 AM
    divad94
    David
    Ivor, VA
    K&N air filter
    Thanks for the quick reply's. Any one have a how-to on changing that bearing?
  7. Mar 4, 2012 at 8:28 AM
    divad94
    David
    Ivor, VA
    K&N air filter
    Texoma, I have seen pics and instructions on the 4 wheel drive but not on the 2.
  8. Mar 4, 2012 at 8:30 AM
    jivewalker
    jivewalker Well-Known Member
    Jack MeHoff
    Chucktown
    2012 4RUNNER TE w/KDSS, 2017 LAND CRUISER
    Agree with wheel bearing. I changed one on a 96 bronco once, not that hard, i heard the noise up front but it turned out to be the opposite side rear bearing, so diagnosing correct bearing may be a challenge....bump for some help on how to..good luck
  9. Mar 4, 2012 at 8:50 AM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    It's about the same, except you don't have to deal with a CV axle. You may be able to pick up the entire bearing assembly and avoid having anything pressed.
  10. Mar 4, 2012 at 8:53 AM
    rcbs204
    rcbs204 Well-Known Member Vendor
    Wheel bearing for sure,
    I have 80K on my 05, and just replaced both fronts.
  11. Mar 4, 2012 at 8:57 AM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
  12. Mar 4, 2012 at 10:07 AM
    divad94
    David
    Ivor, VA
    K&N air filter
  13. Mar 4, 2012 at 10:50 AM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    I'll get back to you on that, unless someone else can answer.
  14. Mar 4, 2012 at 12:03 PM
    divad94
    David
    Ivor, VA
    K&N air filter
    Ok, Thanks
  15. Mar 4, 2012 at 4:26 PM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    You can disassemble everything and then have the bearing pressed to save some cash. Whatever seals are there, you can reuse them, just be careful not to mess them up.
  16. Mar 5, 2012 at 5:30 AM
    divad94
    David
    Ivor, VA
    K&N air filter
    Ok, ill do that and let you know how it went. Thanks everyone for your input.
  17. Mar 18, 2012 at 6:19 AM
    divad94
    David
    Ivor, VA
    K&N air filter
    Did you do it yourself? And if you did any how-tos on it?
  18. Mar 18, 2012 at 8:26 AM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Pre runner wheel bearing is the same as 4wd wheel bearing except you don't have the cv axle to mess with. Find the write up on 4wd wheel bearing replacement and just omit anything that has to do with cv axles. Basically remave your brakes and take out 4 bolts on the back of the hub to get to the wheel bearing.
  19. Mar 19, 2012 at 12:29 PM
    divad94
    David
    Ivor, VA
    K&N air filter
    Thanks for the info.
  20. Mar 25, 2012 at 1:43 PM
    divad94
    David
    Ivor, VA
    K&N air filter
    Ok, this is what happen when I changed the bearing. After I got the caliper and rotor off I could see where the bearing was bolted up by the 4 bolts, the heads are between the bearing flange and the hub. After I got the hub /bearing unbolted i seen a round nut w/4 holes in it(need a special spanner wrench) on the bearing side. This is where the problem started. Since I was going to take the assembly to a garage w/press anyhow I would just take the whole assembly and have them remove the nut, press the bearing from the hub and press my new bearing back together(not). The first garage I took it to said they have tried that before and they couldnt even get the nut off(it was a reputal garage too). The second garage got the nut off but said there was no way he could get the assembly situated in his press to separate it. He drilled the holes bigger in the nut so HIS spanner wrench would fit. He had to use heat to get it off. I said I need my truck for tomorrow and I asked if he could put it back on in case I couldnt get it done that day and he said no, I am leaving in 15 minutes. So I went home and called Toyota dealer to see if they had a whole bearing/hub assembly and they did not, it came separated anyhow. Service tech said bring it in(60 mile round trip) and they would separate it and press it back together for an hour charge of $98. In 45 minutes it was done. Went home and had it back together in 20 minutes, test drove it and the roaring noise subsided but didnt disappear, so the other side is next. So for the price of the bearing(Timken off Amazon/$75) and the pressing at the dealership($98) and some gas paid to neighbor($20 plus beer afterwards) I dont think it was too bad($193). I can give more detailed intructions on this if anyone needs them(omit the rest of the crap I went thru)ha ha
