have a weird squeak when in reverse need help plz
Discussion in '2nd Gen. Tacomas (2005-2015)' started by majorosmask, May 3, 2015.
  1. May 3, 2015 at 3:51 AM
    majorosmask
    majorosmask [OP] Active Member
    hi eveeryoe i have a strange squeak that has started on saturday. i have a 2010 v6 access cab standard tacoma sport. i was driving it bacwards and noticed a squeaking oie when backing up. so my first assumptin was ujoint as i have hear that noise from a ujoint before. so i checked that out and greased tem as well and found absolutely nothing, they were tight no play in them at all. the onlyplay was in the carrier bearing hlding the drive saft but that only had a little side play nothing majr. here s the next thing it ony seem to do it in reverse with clutch pedal out if i push it in and let it role it goes away so that made me think maybe its the clutch but hw could it be if it only does it on the reverse side. anyone ever encounter this
  2. May 3, 2015 at 3:57 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    While going in reverse, press the brakes lightly ....and see if the squeak stops.
    From what I've known - the rear brakes adjust when in reverse. So - you could go in reverse faster and hit the brakes harder to force them to adjust (more or less) and see if the squeaks go away.
  3. May 3, 2015 at 4:54 AM
    majorosmask
    Ok ill try that
  4. May 3, 2015 at 10:01 AM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Did all four caps of every u-joint (of the rear 2pc shaft) purge grease? If unsure, grease it again, and check. If even 1 cap does not purge, it's likely still the culprit, even though you can't feel play in it.
    gearcruncher likes this.
  5. May 14, 2015 at 4:58 PM
    majorosmask
    Thanks for the help it did go away then came back i am going to grease it again and check the caps i thought they all did but didn't look closely I might not be on for bit been super busy at work
  6. May 14, 2015 at 5:09 PM
    14 Tacoma
    14 Tacoma ColeMcMathisaDouche
    Clinton
    IL
    2014 TRD Sport
    Cheap ebay bumper, plus others
    Don't rule out that carrier bearing. If you can, get a second person to walk along the side of the truck on each side and narrow down where(front to rear) it seems to be coming from.
    I'd stop throwing oil/grease at it until it's located and then try a quick fix while knowing where the source is and having a replacement part on hand rather than waiting for failure to know for sure
  7. May 31, 2015 at 7:01 AM
    sockmonkey
    sockmonkey Well-Known Member
    Greg
    Benbrook, SW Fort Worth
    2007 White Dbl Cab Pre-Runner
    Volant Ram Air intake,URD MAF calibrator, Mr Marv 10" sub box, Alpine HU, Alpine Amp, fog light mod, scan gauge II, RAAMmat front and rear doors, Wet Okole seat covers, blacked out dash. blacked out front bumper. American Racing Mojave Teflons wrapped with 265/70/16 Pathfinder AT. NST Lite Pulleys
    I too have this.
    It started about week ago. (we have had tons of rain over the last month or so. Might be related.?)
    It only happens while backing up and regardless of brakes applied, coasting or in gear.
    Strange thing is that it only does it when the truck has been sitting for a while.
    Had the wife try to determine where it was coming from... definitely from the front and seemingly from both sides. Coasting or in reverse and brakes or no brakes
  8. May 31, 2015 at 7:09 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    All most all of your driving is forward so when you reverse the drive shaft is going the other way that is why U joints make noises when they are dry or junk going backwards chances are it will have no play because it's full of rust and jamb rollers. You can try a small screw driver to pry back the seals if there is even the slightest rust they are junk and generally it will the one closest the the diff.
    BUZZCUT likes this.
  9. May 31, 2015 at 5:03 PM
    sockmonkey
    Greg
    weird thing today...backed out of the garage..no squeak.
    edit 6-8-15...it's back
  10. Jun 2, 2015 at 4:54 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Well you can either drop the drive shaft and check it or wait until it falls out by it's self.
