Have any of you rebuilt your 3rd member?
Discussion in '1st Gen. Tacomas (1995-2004)' started by La_Mere, Jul 2, 2025.
  1. Jul 2, 2025 at 5:40 PM
    La_Mere
    La_Mere [OP] Active Member
    Christopher
    Arizona
    2000 Tacoma 3.4L 5-speed 4x4
    Mine is on its way out, so I'm just comparing options. It is a 4x4 e-locker.
    Thank you!
  2. Jul 2, 2025 at 6:50 PM
    02hilux
    Planet: EARTH
    Will be a very expensive lesson if you do it wrong. Find a shop or order from east coast gear supply
    Laxtoy likes this.
  3. Jul 11, 2025 at 5:03 PM
    La_Mere
    Christopher
    Arizona
  4. Jul 11, 2025 at 6:32 PM
    Jiveydude
    Jiveydude Well-Known Member
    Micah
    OH
    04Taco
    Stuff and things that make it better.
  5. Jul 11, 2025 at 11:15 PM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, home built rack with CVT Mt. Shasta, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    Little confused by the question. Are you asking if many/any here have rebuilt the 3rd member by themself, or if they’ve had them rebuilt professionally?
    Rebuilding yourself, like @02hilux was alluding to, is very difficult for the layman. It requires special tools (dial indicator to measure backlash) and considerable knowledge (what the fuck is backlash and how do you apply it?), and if you make a mistake, it could cost you. At minimum (and if you’re very lucky) you’re out no parts but the time to uninstall everything you did and redo it correctly, hopefully with the aptitude required to now do it correctly.
    Worse case is worse.
  6. Jul 12, 2025 at 11:08 PM
    La_Mere
    Christopher
    Arizona
    My question is "Has anyone personally rebuilt their own differential by themselves?"
  7. Jul 12, 2025 at 11:20 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    If you have a press, a clamshell bearing puller, and the patience to set a crush sleeve or shim out the pinion preload, then there’s no real reason you can’t do it yourself. You don’t even need the bearing puller but it makes life much easier.
    If you are just simple replacing the 4 bearings, races and pinion seal, then there’s is really nothing special to the job. You don’t need to set back up backladh or anything else, you just need to achieve proper pinion bearing preload via the new crush sleeve (or shims if using a crush sleeve eliminator kit). For the carrier bearings you just need the keep the shims on the same side they are on.
    There’s really not much to screw up unless you just plain don’t know what you’re doing and don’t have the tools to do the job. If you have the tools and the knowledge, it’s really not that bad.
    Go with OEM bearings and seals (assuming they are available).
  8. Jul 12, 2025 at 11:40 PM
    Azrael's Gaze
    Azrael's Gaze Well-Known Member
    Steve-O
    Springfield, Oregon
    2022 Black Tacoma TRD Offroad
    Youre saying I can replace mine with a bigger one? Interesting...
