have I got this right??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Supashawn, Dec 26, 2013.
  1. Dec 27, 2013 at 7:42 AM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    Yeah even at full lock. I'm sure if I actually wheeled this truck it would be a much different scenario. But it's just a work truck, going to be a couple years before this thing gets wheeled.
  2. Dec 27, 2013 at 7:47 AM
    Supashawn
    Supashawn [OP] Well-Known Member
    Canada
    09 tacoma trd
    thanks for all the helpful info but im not sure what to do....lift and go with 285's or go 275's and run without any issues...will I need the uca's with the 275's...im kinda confused now lol
  3. Dec 27, 2013 at 7:57 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    tires and UCAs have nothing to do with each other. UCAs are for alignment. Wheels or wheel spacers will prevent the majority of the rubbing.
  4. Dec 27, 2013 at 7:57 AM
    Shauncho
    Shauncho Embrace your inner Bro-ness
    Shaun
    Parts Unknown...
    none
    Maybe getting all the info piecemeal like this is getting you confused so I'll do my best to clarify with my little knowledge.
    The purpose of changing the stock UCA's to aftermarket is for two reasons:
    • Improve travel characteristics with your aftermarket suspension
    • Allow for more accurate alignment with your aftermarket suspension
    A side effect of getting new aftermarket UCA's is that they often take up much less space at the ball joint than the stock one so when you're running a wider tire like a 285, changing out the UCA may also minimize the risk of the tire rubbing the UCA. But it is not imperative to change the UCA's just because your running 285's.
    A cheaper way would be to get wheel spacers instead.
    With that said, I believe that you'd NEED to have at least a little lift in order to run 285's at all...In which case it would be worthwhile to also do the UCA's for the above stated reasons.
  5. Dec 27, 2013 at 7:57 AM
    rat107
    rat107 Well-Known Member
    Kauai, HI
    2024 TRD Off Road 4x4, Automatic DC/LB Bronze Oxide
    aFe Momentum GT Cold Air Intake System w/ Pro DRY S Filter
    I'm running 285/75R16s on 16x8s, 0 offset, 4.5" backspacing with no rubbing even off road. No trimming either. I just removed the mud flap and the trim piece in the front of the wheelewell. 3" Toytec spacer lift.
  6. Dec 27, 2013 at 10:03 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I run LT275/70/17 Hankook ATm's on stock Sport alloys , no rub
  7. Dec 27, 2013 at 10:10 AM
    BBtacosurfer
    BBtacosurfer Well-Known Member
    Dave
    ID
    MGM 2012 4x4
    If you are wheeling a lot you will need to chop the cab mounts otherwise you will rub. If you are mostly street with little off road then you may get away with not doing the CMC. It's honestly not that big of a deal and nobody even sees it. In fact it looks perfectly stealth when it's done if it's done nicely and welded nicely.
  8. Dec 27, 2013 at 10:57 AM
    Supashawn
    Canada
    09 tacoma trd
    great info!!! I would like to go with the lift I originally stated and the 285' and uca's...so u think spacers or a 16 rim with a 0 offset is the way to go? any pros and cons?
  9. Dec 27, 2013 at 10:59 AM
    Supashawn
    Canada
    09 tacoma trd
    got a pic of ur setup?
  10. Dec 27, 2013 at 1:12 PM
    OZ-T
    Peter North
    British Columbia
  11. Dec 27, 2013 at 4:10 PM
    Supashawn
    Canada
    09 tacoma trd
    nice thanks!!!
  12. Dec 30, 2013 at 8:35 AM
    Supashawn
    Canada
    09 tacoma trd
    I think im gonna go with ome lift with the aal ( I don't tow anything) camburg uca's, 275 70 17 on stock alloys for now with goodyear mtr's....maybe aftermarket 17x9 wheels with 4.5 backspacing and 285 70 17's down the road if I can get em to fit without a cmc????
    what do u guys think? and wheres the best places in Canada for these lifts?
  13. Jan 2, 2014 at 4:07 PM
    KayStrait
    KayStrait Camburg Girl
    Kayla
    Huntington Beach
    '98 Desert Dune SR5 4Runner
    You can purchase our UCAs from our Canadian dealer, Baja North in Kamloops, BC.
  14. Jan 2, 2014 at 4:10 PM
    BBtacosurfer
    Dave
    ID
    MGM 2012 4x4
    Good call on the Goodyear MTRs...bad ass tires!
    :burnrubber:
