Have My Winter Tires Expired ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MikeDeason, Nov 5, 2022.
  1. Nov 5, 2022 at 5:58 AM
    MikeDeason
    MikeDeason [OP] Well-Known Member
    Hakka r2 SUV. Manufactured 2015
    tread depth is great. I only put like 3k per winter
    I’m reading 6 seasons for winters before rubber degrades to a point where it won’t soften properly.
    stored outside. Me Bad. Not covered. Under a shady tree so very little UV
    NEW Hakka R5 SUV me want but wondering if I am throwing away perfectly good tires.
  2. Nov 5, 2022 at 9:15 AM
    MikeDeason
    Wondering if I should list them for sale and what is value of good tread expired tires ?
    depreciation anyone ?
  3. Nov 5, 2022 at 9:38 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Post pics?
    SR-71A likes this.
  4. Nov 5, 2022 at 9:59 AM
    AdamM
    AdamM Semi-pro aardvark wrangler
    Adam
    Edmonton, AB
    14 DCSB base 6MT 4x4
    If there is no dry cracking, put them on and see how they feel in winter conditions. If they feel like they're not performing like they used to, replace them.
    Big Foot and Thatbassguy like this.
  5. Nov 5, 2022 at 10:02 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Most tire stores won't touch a tire over 10 years old. It is sunlight that does the most damage and a tire in Arizona may be toast in only 5-6 years whereas a tire in Michigan might be fine at 10 years.
    You're at 8 years and if you live somewhere that you need winter snow tires you probably don't see much sunlight on the tires. Without seeing/feeling them it is hard to say, but I'd bet you can get one more year out of them.
  6. Nov 5, 2022 at 10:19 AM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    General consensus is that most tires should be replaced at 6 years and possibly up to 10 years max. Your tires are 7 going on 8 years old. Since yours has been used only part of the year each year and have been stored away from UV light , they are maybe ok for another year. Inspect them carefully for any cracks on the sidewalls. If there is cracking and/or any bulges get rid of them.
    Me personally I would dump them. Your life and your passengers lives depend on your tires. Why take chances with lives.
    Finally, Hell no, don’t sell them. You want to jeopardize other people’s lives on tires you are not comfortable or safe driving on? What the hell? Just dump them and get new tires.
  7. Nov 5, 2022 at 11:27 AM
    MikeDeason
    Sounds like I have an excuse to get the R5’s.
    No cracks. Good tread depth. Seems a shame.
  8. Nov 5, 2022 at 11:52 AM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Was it 100% shade coverage all year long? They look fine to me, but as you pointed out winter tires typically have a very soft compound that aids with traction and that also matters.
  9. Nov 5, 2022 at 12:02 PM
    MikeDeason
    Very little UV. Under a massive Maple.
    I know I was impressed with the traction 7 yrs ago after switching from Blizzaks. Hard for me to tell if performance has deteriorated or if I’ve been adjusting my expectations as they incrementally deteriorate.
    I will leave it to the Gods. The R5’s arrive here Dec 1 and there will be short supply. If I can get my preferred size I will get them. If not wait.
    SR-71A likes this.
  10. Nov 5, 2022 at 12:09 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I have brand new tires never mounted from 20 years ago. They came out of my tire dealers warehouse .
    If you were close I would buy those tires at a fair price.
  11. Nov 5, 2022 at 1:25 PM
    MikeDeason
    Well I carefully inspected all 4 tires and zero cracks. All look like pic. Tread is great. Over 1/2 usable.
    but as I understand it, the fact that they are winter tires means that regardless of condition, the rubber will no longer soften properly because of exposure to oxygen and fluctuations in temps
    wonder if new ones are kept inside in a vacuum seal bag if I could avoid this next time.
  12. Nov 5, 2022 at 1:35 PM
    2015WhiteOR
    Gainesville TX
    Tire rubber contains "anti-ozonants" which help them fight off oxidation during their expected lifetime (5-7 years?). If you've ever seen a new tire with a brown chalky surface, that is blooming from the anti-ozonants.
    Also keep in mind that cracks on the outside of a tire do not always translate to cracks on the inner carcass of the tire. When most tires are manufactured, the outer tread/sidewall piece is heat bonded to the inner carcass which has the belting and the bead.
    SR-71A likes this.
  13. Nov 5, 2022 at 1:44 PM
    MikeDeason
    So stored inside in a vacuum seal bag for storage should give me several more years next time.
    You think?
  14. Nov 5, 2022 at 2:43 PM
    MikeDeason
    I just looked at the pic above of the tread on my desktop instead of my phone and there are a lot of imperfections between the tread blocks.
  15. Nov 5, 2022 at 2:49 PM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    I’d run them!
    They are all mounted try them if you aren’t happy get different ones.
  16. Nov 5, 2022 at 3:56 PM
    MikeDeason
    Good plan but with supply shortages I either jump on them when shipment comes in or I’m on the old ones another year
  17. Nov 5, 2022 at 3:59 PM
    Bishop84
    Bishop84 Well-Known Member
    My rule is 5 years and I sell em, we need really soft here.
    What I do with customers vehicles is simply educate them that they will have deteriorating performance as they get older beyond 5 years. 10 years cap with winters.
    SR-71A likes this.
  18. Nov 6, 2022 at 2:42 AM
    MikeDeason
    Soft is why I buy winters. I had no idea this ability degraded over time until I happened on the info online
  19. Nov 6, 2022 at 6:04 AM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    Do you have a source for that general consensus on 6 years? Seems too aggressive as a general statement.
    I'd run 'em. Those look to be in fine condition for this season. Revaluate each year.
  20. Nov 6, 2022 at 6:09 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    They don't look terrible to me
