Have oil in the coolant reservoir. Can anybody help??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mackey01, Jul 19, 2010.
  1. Jul 19, 2010 at 7:12 PM
    mackey01
    mackey01 [OP] New Member
    '10 trd offroad
    I had oil in the coolant reservoir about a month ago. I brought it to toyota and they replaced the oil cooler around the filter. Then today I checked the reservoir and found oil floating in the coolant. I only have 6K on the engine. has anyone else had this problem??
  2. Jul 19, 2010 at 7:13 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW!
    Take it back. You may have a bad gasket.
  3. Jul 19, 2010 at 7:33 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Thats most likely bad gasket, Toyota owes you new engine, dont take refurbish.
  4. Jul 19, 2010 at 7:34 PM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    ^^^ What all the guys said. ^^^^
    Damn on a new truck!
  5. Jul 19, 2010 at 8:11 PM
    JKD
    JKD Well-Known Member
    It could be as simple as a head gasket leak -- in which case a new head gasket would fix the problem. Even better, maybe they didn't fully flush the cooling system when they 'fixed' it last time.
    Or it could be a cracked or porous block.
    Are you sure it's engine oil and not trans fluid?
  6. Jul 19, 2010 at 8:29 PM
    CtTaco
    CtTaco Well-Known Member
    Eric
    Connecticut
    2010 4x4 Doublecab Sport Longbed Supercharged
    3" lift, Tundra wheels with BFG ATKO's, Viper Remote starter TRD Supercharger
    I dont care if its a headgasket, no one would be pulling apart my brand new engine with 6k on it, changing the headgasket and puttin it back together again...they'd be givin me a brand new engine and showing me the new engine while its stilll in the crate just to make sure theyre doing the right thing...
  7. Jul 19, 2010 at 9:00 PM
    mackey01
    '10 trd offroad
    I'm positive it's not tranny fluid. last time they flushed the system twice
  8. Jul 19, 2010 at 9:03 PM
    Peru
    Peru Well-Known Member
    Jonathan
    Redmond WA
    SR5 -- V6 -- 2005 -- 4X4
    none
    If you want to increase your chances of getting the best deal. Keep taking the truck back to them -- let them keep on trying till after the 3rd time then you have leagle options available to you under the lemon law. Every state has different requirements but if you keep on giving them the chance to fix the problem and they don't the state will make them do it. VERY important -- document everything keep records of times, names and any and all paperwork.
    Follow that and you will get a new truck. If you force the issue now they may just replace parts till it is fixed and then you'll have who know what type of quality work do on your truck
  9. Jul 19, 2010 at 9:04 PM
    AKTACO420
    AKTACO420 Well-Known Member
    RETODD
    Anchorage AK
    2009 tacoma
    bucket seats grille craft mesh grille and lights behind grille
    That's some bs you should take it in and tell them you want a new motor now no exceptions it already messed up they can't just change the coolant and drain the oil and change the gasket and expect not to be damaged. I had a car were the same thing happened and the valves started ticking the motor was garbage. Don't take any crap from the dealer its a brand new truck
  10. Jul 19, 2010 at 9:06 PM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Yeah, I agree that Toyota owes you a brand new motor out of a crate, and not a overhauled motor.
    Might be a good idea to contact a "Lemon lawyer".
  11. Jul 19, 2010 at 9:17 PM
    jdtemple
    jdtemple Well-Known Member
    Bay Area CA
    08 DBLCAB LB TRD Sport
    Lift & Tires, in cab power outlets, Locking Bed Boxes, K&N
    You should probably buy the extended warranty if all they do is fix the leak.
  12. Jul 19, 2010 at 10:04 PM
    JKD
    They aren't going to do that unless the block is damaged. And then they'd replace the block only, unless the head(s) were damaged.
    Replacing a head gasket would be the correct repair if that's the only problem.
  13. Jul 19, 2010 at 10:18 PM
    BlazeTaco
    BlazeTaco Well-Known Member
    PA
    4.0l 6sp SR5
    TRD Exhaust TRD Filter
    I would fight with the dealership about getting a new engine. When you get engine oil in the coolant you more than likely have coolant in the oil which is murder on plain bearings. Which many things in the engine have like your main crank bearings and the rod bearings.
  14. Jul 20, 2010 at 2:28 AM
    AKTACO420
    RETODD
    Anchorage AK
    2009 tacoma
    Well I think we all know not to listen ( JKD ) the damage is done already you can't just over look something like this its going to cause problems in the future
  15. Jul 20, 2010 at 9:50 AM
    JKD
    Good luck. Toyota is pretty good with trying to keep customers happy, but I don't think it's going to extend to installing a brand new engine if a simple repair will do the job. Even if you made them replace the main bearings, it's still going to be cheaper for them to replace the head gaskets and bearings than it would be to replace the engine--by a factor of about 10.
    Look up the lemon law in your state, OP. You're already on at least visit two for the same problem--if you get to enough visits or time out of service (depending on your state law) you could go through the lemon law process to get a new truck.
  16. Jul 20, 2010 at 9:54 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    did you let KrazieSJ work on it?
  17. Jul 20, 2010 at 6:20 PM
    maju
    maju Well-Known Member
    Davenport Fl
    2010 DC Silver TRD Sport 4x4
    Undercover tonneau, Scangauge II, Garmin GPS, Michelin LTX M/S2
  18. Jul 20, 2010 at 6:32 PM
    JDMcQ
  19. Jul 20, 2010 at 7:42 PM
    Peru
    Jonathan
    Redmond WA
    none
    Ive used the lemon law twice. Once I got my money back and a discount on a new truck. Once the state got involved things moved quickly and the stone walling ended
    Second time I got $3000 plus and extended warranty
    Document everything
