Have spindles. Getting camber/caster back to spec?
Discussion in 'Suspension' started by rzimm001, Mar 30, 2011.
  1. Mar 30, 2011 at 4:31 PM
    rzimm001
    rzimm001 [OP] Tearmytaco
    Bobby
    Wildomar
    08 PreRunner SR5 Long-Travel
    King 10" coilovers w/ resi. 3.5" over long travel kit. Factory spindles w/ ALLPRO gussets. Total Chaos tower gussets. Energy Poly cab mounts and steering rack mounts. Glassworks fenders and bedsides. Home fabbed bed cage. King 2.5x16 bypass shocks in the rear. DMZ long travel rear end. Race radio (2meter). Removed secondary carbon air filter. Exhaust dumped before the axle / no muffler. Phram fresh air cabin filter. K&N replacement filter, After market stereo, Grillcraft grill, custom fabled roof rack with 7" HID's, PRP race seats.
    I've got camburg spindles, total chaos UCA's, and my camber/caster lobes are adjusted all the way inward. I've lived with it for quite awhile because it doesn't seem to hurt anything. The specs are currently 4.5 caster and like 0.2 cambered in. It looks cool having a little inward camber and I've never heard of a little extra caster being an issue either, but it's screwing with my o.c.d that I have no adjustment left. Also the fact that my tires will start wearing a little uneven. Why would this be? Is it because the UCA have alignment correction in them and I'm running no preload (no coil lift)? Or are the spindles designed to add inward camber? I'd like to get the adjustments back close to neutral.
    Just something I've been thinking about :confused:
  2. Mar 30, 2011 at 4:49 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    .2 camber shouldn't really cause any noticeable tire wear. I'm at .8 and I haven't noticed any premature wear.
    How is your toe? out of spec Toe causes pre-mature tire wear more than camber does.
    4.5* of caster? wow, that's a lot. I'm at 1.9 on both sides (stock UCA's)
  3. Mar 30, 2011 at 6:06 PM
    rzimm001
    Bobby
    Wildomar
    My toe is dead nuts. I align it after every outing just about. I think my caster correcting uca's are whats causing the issue. But than how Am I suppose to run extended travel shocks with a stock uca?
  4. Mar 30, 2011 at 8:21 PM
    rzimm001
    Bobby
    Wildomar
    Anybody running extended travel shocks with a spindle lift?
  5. Apr 13, 2011 at 11:15 PM
    JdMeF9SiR2
    JdMeF9SiR2 PARTS HOARDER
    Riverside CA
    06 Tacoma
    im currently running icon intended travel, tc uca, camburg spindles with no sway bar.
    i just got my truck aligned today.
    CASTER - 3.3
    CAMBER - .8
    TOE - 0
  6. Apr 13, 2011 at 11:28 PM
    rzimm001
    Bobby
    Wildomar
    Are your lower control arm adjustments maxed? How lift you running?
  7. Apr 13, 2011 at 11:54 PM
    JdMeF9SiR2
    Riverside CA
    06 Tacoma
    im not to sure if its maxed or not but heres a picture. extended with .75 lift
  8. Apr 13, 2011 at 11:56 PM
    all.on.black
    all.on.black Well-Known Member
    Auburn, WA
    06 Double Cab Sport with a few mods
    ^ Yours aren't maxed out. You still have plenty of adjustment.
  9. Apr 14, 2011 at 9:18 AM
    rzimm001
    Bobby
    Wildomar
    That's so weird. Yours are in a great spot. Mine are definitely maxed out. I can't understand why other than that is the way the spindle was built.
  10. Apr 14, 2011 at 9:34 AM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    Realistically I believe toe should be 1/32 toe in iirc
  11. Apr 14, 2011 at 4:35 PM
    JdMeF9SiR2
    Riverside CA
    06 Tacoma
    im curious what kind of alignment did you get? front end, thrust angle and four wheel alignment?
  12. Apr 14, 2011 at 9:01 PM
    rzimm001
    Bobby
    Wildomar
    Well I was standing with the techs when they did it. They told me I had to choose between reducing caster or having normal camber. See both camber and caster lobes are all the way inward. So the caster is neutral technically seeing as the camber lobe is all the way in (they are relative to eachother), but if they move it outward than the the lower control arms will extend outward giving me excessive camber in. It's hard to explain but more or less it seems that the spindles have too much camber built into them. The tires are vertical because I checked the wheels with my digital level. I just wish I had some adjustment left.
  13. Apr 14, 2011 at 9:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    No. If anything, you should be toe out a bit. +.05* is good.
  14. Apr 14, 2011 at 9:15 PM
    rzimm001
    Bobby
    Wildomar
    Say what :eek:
    News to me. Please educate me. I've always heard that cars are given a slight amount of toe in and almost every spec sheet I've seen says the same. I know on my R/C cars I run toe out. I've wondered why real cars were different
  15. Apr 14, 2011 at 10:12 PM
    JdMeF9SiR2
    Riverside CA
    06 Tacoma
    thats really weird. ill be at the meet in temecula next week if you wanna check out my alignment print out.
    how long ago did you get it installed? Tim @ DMZ installed mine on tuesday.
  16. Apr 14, 2011 at 10:23 PM
    rzimm001
    Bobby
    Wildomar
    I installed them myself a year ago just about. I would definitely like to see your alignment tabs next week at the meet.
  17. Apr 14, 2011 at 10:26 PM
    Fisheez
    Fisheez Built Ford Tough.
    Zack
    So Cal
    Tacomaless For Now
    after i got my truck alligned with spindles i get toe in too. it looks like its more on the driver side. also my truck pulls to the right pretty hard. I need to go and get it realigned at firestone. the plaace i went was cheap and did a $45 job :(
  18. Apr 14, 2011 at 10:34 PM
    rzimm001
    Bobby
    Wildomar
    Dang that's cheap. If it's pulling hard to the right you need some more caster on the right side.
  19. Apr 14, 2011 at 10:38 PM
    Fisheez
    Zack
    So Cal
    Tacomaless For Now
    i dont know too much about camber/caster or all that lingo, but i think i just need another alignment done right and I should tell the guys there what problems i am experiencing.
  20. Apr 14, 2011 at 10:44 PM
    rzimm001
    Bobby
    Wildomar
    Yup. That would definitely be the thing to do. Caster is just how much your spindles are tilted back towards the cab. It's what causes your steering wheel to return to center after making a turn.
