Have there been any actually documented issues caused by SC mods?
Discussion in 'Performance and Tuning' started by 6xchamps, Sep 13, 2015.
  1. Sep 13, 2015 at 9:13 PM
    6xchamps
    6xchamps [OP] Well-Known Member
    Fuquay Varina NC
    2015 AC
    I know that any modifications will void your warranty but...
    Has anyone actually had problems after mods? I mean just the usual stuff-smaller pulley/upgraded fuel pump , CAI . I've never even heard of anything
  2. Sep 14, 2015 at 6:24 PM
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    No, any modification will NOT void your warranty. Any mod COULD void your warranty and that's a rather large difference. Put simply, the onus is on the manufacturer to prove that your modification caused whatever failure they're trying to deny coverage on. As consumers we're protected against such things and simply modifying your ride doesn't mean that you just voided your warranty. Big distinction difference.
  3. Sep 14, 2015 at 8:09 PM
    6xchamps
    Fuquay Varina NC
    2015 AC
    You honestly think that? This was on my shift knob when I picked up my truck from the dealership after the install. CLEARLY says that it nullifies the warranty.
    My question is if anyone has heard about the mods actually causing any issues. I have not, but I have only been here half a year
  4. Sep 14, 2015 at 8:22 PM
    Ostrichsak
    Jer
    Think? No. I know. There's case law that supports everything I said. They don't get to do whatever they want because they're the big scary corporation.
    Don't believe me. Research Magnuson-Moss Warranty Act of 1975.
    Some stupid letter (even one drafted by a legal team on fancy looking letterhead complete with Roman numerals & #'s) can't overrule federal laws no matter how much manufacturers wish it did. Also, posts like this perpetuate the incorrect assumption that any modification immediately & fully voids your warranty. It's false.
    MadDaddy likes this.
  5. Sep 14, 2015 at 8:43 PM
    6xchamps
    Fuquay Varina NC
    2015 AC
    The federal minimum standards for full warranties are waived if the warrantor can show that the problem associated with a warranted consumer product was caused by damage while in the possession of the consumer, or by unreasonable use, including a failure to provide reasonable and necessary maintenance.
    to me that reads...your truck wouldn't have had these issues if you hadn't changed fuel delivery, intake and made the pulley smaller.
    i still have the same question though, has anyone had an supercharger issues?
    T4RFTMFW likes this.
  6. Sep 14, 2015 at 9:09 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Only overtightening the hose clamps on the fuel pump line when doing a swap..... This could cause a leak and lead to rough/no start...
    That's it really.....
    Other known issues I can recall were due to someone raising rev limiter and regularly taking it to the strip.....key point, rev limit increase.
    Another case involved nitrous as well.
    No real issues with adding a smaller pulley WITH proper fueling/cooling mods done in conjunction...... No issues with headers..... No issues with intakes cept the newer TRD intake running lean on n/a apps.......any issues with the maf calibrator are tuning errors.
    Boost on, use common sense, ask away, and purchase/pay attention to proper gauges
    Torspd, T4RFTMFW and 6xchamps[OP] like this.
  7. Sep 14, 2015 at 9:10 PM
    6xchamps
    Fuquay Varina NC
    2015 AC
    right on
  8. Sep 14, 2015 at 9:12 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    That's just off the top of my head....... Stay tuned for others replies..... It's been a long day
  9. Sep 15, 2015 at 11:08 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Once this one guy got a long travel. Jumped it to far....
    Justus likes this.
  10. Sep 15, 2015 at 12:27 PM
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    As issue i've got a power increase and worst of all i've got the disease of trying to get more.:mudding:
  11. Sep 15, 2015 at 12:30 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Infectious like the plague.
