have you broken anything on your truck lately?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by monstajp, Apr 8, 2014.
  1. Apr 9, 2014 at 8:12 AM
    aaronbuell
    aaronbuell Well-Known Member
    aaron
    windsor NY
    09 TRD/OR Access Cab V6 debadged
    Fog-light anytime mod, ,black grill,URD short throw,TRD decals removed ,debadged,black rear bumper, homemade tire carrier,TreadWright tires,Evo mod,removed rear headrests and seats,ABS kill switch mod,black center caps,Clarion CX501 head unit,Relentless hood brackets with floodlights.
    Broke a leaf spring. Tried to take the bolts out (ones on the bottom of the bumper) to take the center cover off the rear bumper so I could paint it and they snapped off same with the push clips and the ones behind the plate. Now everythings held on with zip ties. LOL
  2. Apr 9, 2014 at 1:09 PM
    WhiteNemesis
    WhiteNemesis Well-Known Member
    Mr PattyCakes
    T-Town, AZ
    Cant get enough
    Blow it through the roof
    had my heart broken a couple times since buying the truck, dont do the gf mod
  3. Apr 9, 2014 at 5:24 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Howard would have been absolutely exhausted and way too fat after dealing with the chimpmunk invasion I had that year.
  4. Apr 10, 2014 at 5:55 PM
    monstajp
    monstajp [OP] Well-Known Member
    joshua
    las vegas
    2011 trd sport debadged
    Debadged, Blacked Out Taillights and 3rd Brakelight , Blacked Out Grille, Blacked Out Lower Valence, Hot Wheels Badges, Yellow Fog Lights, Rims and Tires. Undercover Swing Case, Pop-A-Lock on my Tailgate, N-FAB Step Bars, Extang Trifecta Bed cover, Aero Cat- Back Exhaust, PIAA Extreme white 4000k Bulbs, Readylift 2.25 Leveling Kit.
    Im sure it costs less to fix broken hearts compared to broken parts.
  5. Apr 10, 2014 at 5:57 PM
    monstajp
    joshua
    las vegas
    It seems like leafs seem to break pretty often. Anyone buy an AAL or an aftermarket leaf pack to avoid an initial problem? ? Part of the point of this thread is to see what parts need to be reinforced to avoid breakage and equipment failure.
  6. Apr 10, 2014 at 6:02 PM
    monstajp
    joshua
    las vegas
  7. Apr 10, 2014 at 7:44 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    I need to do this, they're flat on mine, it's only a matter of time
    I messed the bearing up on my driveshaft pretty good. It was a sunny day, about 30 degrees out, and it had snowed about 3" that morning. When the sun came out the snow melted; by the time I got out of work I had icicles underneath my truck. I didn't realize it had also melted down the back of the cab and froze into a giant ball on the driveshaft. About two miles of 55 mph and my tired bearing's rubber went kaput.
    Found out you can order the original bearing from any driveline shop that carries Spicer parts for 1/3 the cost of the dealer, and it's not one of those aftermarket cheapies, it's the real deal.
    Between that and the binding steering shaft u-joint in February, I'm tired of winter breaking stuff.
    Not that summer is any better, the clutch on the AC compressor self-destructed last July. I still gotta fix that
  8. Apr 10, 2014 at 7:56 PM
    Xaks
    Xaks Cranky & often armed sysadmin
    Xaks
    Oklahoma City area
    work beast '06 reg cab 4 cyl 5 spd
    Hmm.
    Welp, I broke the rear shocks when loading *insert a lot of mental math here* 1, 470ish (give or take about 50-70ish) pounds of computers and printers and assorted battery backup units into the bed of mine and driving it three counties away.
    (Long story short: Hurricane relocation in less than zero time with classes starting in new school facility in less than 20 hours)
    34 Lenovo PCs. 7 4xxx series HP laserjet printers with full stack trays, duplexers, and paper. Full rack of servers and switches and UPSes to run them.
    THOUGHT I might have broke the rear end and/or tranny driving through three+ feet of water over a dozen times in some flooding we had here in January...spend over $100 to drain, flush, re-fill both, to find not a drop of water in either.
    Really , that's about it.
  9. Apr 10, 2014 at 8:05 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    I wouldn't even know where to begin ...
  10. May 24, 2014 at 8:57 PM
    monstajp
    joshua
    las vegas
    Anyone else?
  11. May 24, 2014 at 9:07 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    had a c/v boot rip :notsure:
    damn things been pretty good to me. I relocated the exhaust crossover though before it had any chance to be crushed.
    not sure if my aal has saved factory pack
    no leaks or anything. 108k miles
  12. May 24, 2014 at 9:11 PM
    14TACO4X4
    14TACO4X4 Mmmmm... Beer
    Shawn
    Temecula
    18 RAM EcoDiesel
    Laramie
    Was 4 wheeling around the lake I fish in... went down a steep little hill and it dead ended, but there was a truck parked there, so I couldn't turn around.
    I backed up the hill in 4 wheel (2 wheel wouldn't cut it) and ran over a rock and broke one of the front mud flaps. I took the other one off when I got home and it looks better.
  13. May 25, 2014 at 8:50 AM
    RogueTRD
    RogueTRD Learn to swim...
    Cade
    So. Oregon
    Supercharged '14 Pyrite Mica DCSB 4x4 TRD OR
    Stacked spacer lift, 22x12 wheels with stretched 33's, tow mirrors, bull nuts.
    I haven't broken anything or had anything go wrong with my '14. My '09 had a dented rear bumper and a broken/bent 7 pin connector when I traded it in. Other than that no issues/damage.
