Have you developed VIBES or Humm/Buzz Since Lifting?
Discussion in 'Suspension' started by Negative1, Dec 14, 2009.
  1. I've never had any vibrations since lifting.
    26.2%
  2. Yes I have the vibrations since lifting.
    64.3%
  3. Had the vibrations but fixed them (please post to explain)
    5.1%
  4. Yes I had the vibrations, but even before I lifted.
    4.4%
  1. Feb 5, 2010 at 9:20 AM
    #41
    SamSter0077
    SamSter0077 Happy Camper
    Katy, TX
    09 Tacoma 4x4 TRD OR
    OME 886 Coils, and Struts, Rear Toytec TSB AAL/ OME shock absorbers, Fog Lamp anytime mod, Voyager Brake Controller.
    for me, vibes in the steering wheel was Tire Balance related.. and yeah.. i took it several places before someone finally balanced it right. Also, the height of the lift in front played a part as well... I had 4" of lift, and it was too much. Good Balance, and going back down to 3" ish lift in front did the trick.
  2. Feb 5, 2010 at 7:25 PM
    #42
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    too bad i can't chop an inch off my spindles :p
    if you used coilovers and got 4" you definitely went with too much lift. i got a road force balance and most of the vibs went away and when the truck tracks right and i try to keep it straight is when my vibs happen the most, so i'm leaning towards it being an alignment problem which i will have them check it out soon.
  3. Feb 8, 2010 at 5:23 AM
    #43
    jshaw
    jshaw Active Member
    Jeff
    S.C.
    06 TRD Sport White
    UWS black tool box, ScanGuage with Blend Mount, Rear AAL with 5100's all around,Total Chaos UCA's, Firestone air bags, BHLM with HID's
    After installing 5100's and an add a leaf in the rear, I had a vibration between 25 and 45 mph. Dealer replaced front diff and LF axle. Nothing was said about the lift. Vibes are gone for now but scared they will come back.
  4. Feb 8, 2010 at 12:38 PM
    #44
    csuviper
    csuviper Moderator Moderator
    Brian
    Broomfield, CO
    2012 Tundra Rock Warrior 5.7L 4x4
    3" Toytec Ultimate Lift, 315/70R17 Duratracs, RW Wheels, Grillcraft Grill, Toyota "Raptor" Lettering and more
    Some vibes lately (6" lift), just got the LR UCA's. Hoping that helps out the problem. If not was thinking front drivers side bearing because on last tire rotate it didnt feel right.
  5. Feb 9, 2010 at 9:11 AM
    #45
    Fmsvandal
    Fmsvandal Well-Known Member
    David
    Ormond Beach, FL
    09 DC/LB TRD Sport
    Toytec Ultimate 3" Lift, Light Racing UCA's, N-Fab Steps, Black Headlight Mod, Satoshi Thin Lip Grille, Painted Hood Scoop, Debadged, Bakflip G2 Cover, Pop/Lock, Alpine HU, Kicker Door Speakers, RE Audio Subs, Arc Audio Amps
    Seems like my vibs/rubbing feeling is only really when i turn. I have the OME 3" with LR UCA's and BFG KO's. Is this due to the tires or could it be something else....? I know its not tires rubbing on anything cause ive already cut away everything.
  6. Feb 14, 2010 at 6:37 PM
    #46
    cdn_bacon
    cdn_bacon Well-Known Member
    Christopher
    Houston
    07 Tacoma Dbl Cab short box 4x4 TRD
    Slim's HID 6000k headlights and fog lights; Redline hood and tailgate struts, TRD CAI
    I just put my 3" lift on this weekend (thanks for the help Sam), and I've noticed some shake in the steering wheel. Mostly between 55-70. It just seems like it I can feel every shake and grove on the road. Idea's? Sam, I might get you to take my Taco for a spin this week .... I got a diff drop and carrier drop kit at the house...
  7. Feb 16, 2010 at 10:44 AM
    #47
    scrapedface
    scrapedface Well-Known Member
    vacaville, ca
    2008 2.7 liter 4wd tacoma
    ipod charger and aux cable, scanguage 2, wet okole seat covers, 35% tint, toytec ultimate set at 2.5"
    i only get vibes when i let off the gas pedal going 50+ mph. its worse when im in 4wd. i got the toytec ultimate.
  8. Feb 16, 2010 at 11:41 AM
    #48
    cdn_bacon
    Christopher
    Houston
    I had the same problem although I just got my alignment done again and had them crank up the castor ...vib is considerably less now.
  9. Feb 16, 2010 at 4:10 PM
    #49
    csuviper
    Brian
    Broomfield, CO
    GO GET YOUR TIRES/WHEELS BALANCED!!! I got mine balanced and wow, what a huge difference. The majority of the vibes are gone and the steering wheel doesn't shake. :)
  10. Feb 17, 2010 at 7:32 AM
    #50
    SamSter0077
    Katy, TX
    are you still having this problem? we can look at it tonight..
    The important thing is to get them Balanced correctly! just cause the machine shows it right, does not mean it is right. Some rims require a different type of balance.. road force balancing is the only way to be 100% sure. FWIW
  11. Feb 22, 2010 at 1:24 PM
    #51
    SamSter0077
    Katy, TX
    New Vibe.. Gas Pedal.. when 60 or up, hit the gas feel a vibe in the pedal let off the gas and it goes away. I am thinking it's the ujoints or the input angle on the differential. ordered some Shims today for the diff.. wish me luck. :)
  12. Feb 24, 2010 at 9:21 AM
    #52
    SamSter0077
    Katy, TX
    FYI.. lubed the Driveline two days ago.. gas pedal vibe is gone. 12,500 miles on the truck.. some in the sand, mud, and water.. :D
  13. Mar 12, 2010 at 2:54 PM
    #53
    yodaman
    yodaman Active Member
    Bellingham
    07 TRD Sport 4x4 V6 Automatic
    Yokohama tires Skyjacker canopy add more later
    Vibes at 20 and 40 mph. Vibration in gas pedal at 70mph. Put on a home made carrier bearing drop. Vibes at 20 went away. At 40 they are still present. Noise goes away in 4x4.
    Skyjacker installed.
  14. Mar 16, 2010 at 4:48 PM
    #54
    paidfor
    paidfor Well-Known Member
    Austin, TX
    2013 TRD OR 4x4
    Hidden GPS tracking system. Backflip cover, weather techs, bed mat, tailgate lock, OME 885 springs, blistein shocks, 2.5 in AAL/
    no vibes w/ mine. 5100 and ebiach coils with TSB,
  15. Mar 18, 2010 at 9:04 PM
    #55
    aspen432
    aspen432 Member
    I've got 5100's (set at 0) up front with Eibach Coils for a total of 1.6"of lift and then a ToyTec 1.5" AAL in the back. Steering wheel vibrates above 30 mph pretty consistently. I'm thinking of doing the carrier bearing drop to see if that helps. Does that make any sense for such a minimal lift ~1.5"?
    P.S. I've had my tires balanced and my alignment checked 3 separate times already although I don't think they've been road force balanced. I have 265/70/17 BFG AT KO's. Maybe I should look into a road force balancing?
  16. Mar 18, 2010 at 9:21 PM
    #56
    jwhelan
    jwhelan Well-Known Member
    JW
    Dallas Texas
    05 TRD Silver
    TRD PreRunner, 5100's on all four fronts @ 1.75, AAL, SP performance rotors, hawk pads, 17" FJ Cruiser wheels P/C black, 265/65/17 BFGR Rugged Trails, BHLM , painted grill, blacked out emblems
    I have a slight vibration off the line from 0-10mph after having AAL and 5100's set at 1.75 installed...:confused:
  17. Mar 19, 2010 at 3:34 PM
    #57
    kd8awe
    kd8awe Well-Known Member
    Rocky
    Ohio
    4x4 TRD Off Road
    Fog mod, 3" lift, ShoMe stobes, MicroLight LED Strobes, HiLift Jack, RCI 2950, Yaesu 8900r, 20% Tint, ScanGauge II, Weathertech Side Window Deflectors, *** New Mod's (parts on the way) *** U-Bolt flip kit. Tom Woods 1 Piece Double Cardan Drive Shaft. 3* Axel Shims
    I just finished installing 1/4 CB shims and the vibation is now gone. Last fall I installed a 3 inch lift with AAL in the rear. Vibration started a few months later. I have to do my wrenching in the driveway so I had to wait till now to shim the CB.
  18. Mar 19, 2010 at 9:08 PM
    #58
    scrapedface
    vacaville, ca
    i fixed my vibes. the front vibes were caused by the 1" diff drop. once i removed it my 4wd vibes were gone. then i removed the 2"AAL and shims in the back and the rear vibes were gone. now its not lifted in the back. more like a leveling kit now. but better than having vibes that will one day cause my drive shaft and other stuff to fail.
  19. Mar 21, 2010 at 6:18 PM
    #59
    scrapedface
    vacaville, ca
    I know for a fact the diff drop caused vibes up front for me and i got vibes in rear from The drive shaft angle. Shims did not help at all.
  20. Mar 21, 2010 at 6:21 PM
    #60
    mr smitty
    mr smitty Well-Known Member
    Tennessee
    09 prerunner sport
    Westin Chrome running boards Rough Country 3" lift 17x9 motometal 951 chrome mickey thompson baja atz 285/70 17
    i got the 3" rough country lift and no problems at all with it
