Have you developed VIBES or Humm/Buzz Since Lifting?
Discussion in 'Suspension' started by Negative1, Dec 14, 2009.
  1. I've never had any vibrations since lifting.
    26.2%
  2. Yes I have the vibrations since lifting.
    64.3%
  3. Had the vibrations but fixed them (please post to explain)
    5.1%
  4. Yes I had the vibrations, but even before I lifted.
    4.4%
  1. Jan 8, 2012 at 5:37 PM
    #121
    TacomaChris
    TacomaChris Well-Known Member
    :DWell, I'm glad I took the measurements posted above. I installed my 3 degree shims this weekend and the vibes are completely gone just as I thought. It's very important to take measurements so that you know just where to decrease/increase your angles and which accessories to purchase
  2. Jan 11, 2012 at 3:18 AM
    #122
    Irish020
    Irish020 Well-Known Member
    Phil
    Pennsylvania
    '05 Tacoma TRD Sport 4 Door Longbed
    ARE Hard Tonneau Cover Flowmaster American Thunder Super 50 Series Stainless Dual Exhaust Toytec Ultimate 3" w/ UCA's
    Just the sound of AT Tires on pavement...
  3. Jan 11, 2012 at 7:57 AM
    #123
    KingMoo
    KingMoo Well-Known Member
    Calgary
    Tacoma TRD Sport
    -LIFT: 5100 bilsteins all around (set at 0.85 in front) eibach coils 2" AAL -D-RINGS -BED COVER rollaway
    could someone please explain the easiest way to go about getting these measurements?
  4. Jan 11, 2012 at 8:28 AM
    #124
    Sgtfluffy16
    Sgtfluffy16 Well-Known Member
    Corey
    PA
    07 Tacoma Double Cab TRD Sport
    20% tint, HID headlights/ yellow fog light bulbs and LED lights interior/exterior lights. 4.5 Inch RCD lift, 1 Piece custom driveshaft, AEM intake, Dynomax Exhaust, Amp research Moto-bed extender, Extang Express tonno.
    4.5 Inch RCD lift kit I had a vibration immediately after I lifted it. Used 1/2 inch 3/4 inch 1 inch 1.25 inch 1.50 inch and 1.75 spacers, Found a had a bad carrier bearing. Figured Id fix the problem by just doing a 1 piece driveshaft because 1 piece and stronger and better for wheeling. Put the 1 piece on and still had vibrations from 25-35 MPH and then again from 45-55MPH. The the 45-55 vibration is sometimes bad sometimes not as bad especially noticeable when on the gas from just a lil bit-WOT. Tried flipping my degreed blocks, tried 2, 3, and 4 degree shims all made it worse. Now I'm just running with the blocks in correct orientation and 1 piece driveshaft. figured I will just have to live with it. Anyone having similar issues?
  5. Jan 11, 2012 at 9:37 AM
    #125
    TacomaChris
    Sure...go buy a digital angle finder (with the magnetic edge) and use it to measure your driveshaft before and after you carrier bearing as well as the rear differential angle. I bought one at Harbor Freight for about $25. From here you should be able to figure out which angles are too extreme.
    My pinion angle still isn't ideal - it's at about 3.9 degrees; however, once torque is applied it causes the rear differential to point upward thus reducing the angle even further when I'm driving. Either way my vibrations are gone so I'm happy. Good luck
  6. Jan 11, 2012 at 10:56 AM
    #126
    KingMoo
    Calgary
    Tacoma TRD Sport
    I'm experiencing a humming sound that comes and goes. It is not a constant hum, but rather a hum that hums every half-second. This occurred after I installed the AAL
  7. Jan 14, 2012 at 4:52 AM
    #127
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    I have had zero issues with vibrations post lift. After reading christians post on the diff drops I was going to remove mine although I decided to leave them in fear of developing vibrations. I intalled ATO's bullet proof front skid and I have about 3/4" clearance between the skid and the drops
  8. Jan 30, 2012 at 3:52 PM
    #128
    KingMoo
    Calgary
    Tacoma TRD Sport
    did you get the ?
    that's all I see at Harbor Freight. I found a digital angle finder at a local store but it's $89...
  9. Feb 19, 2012 at 2:47 PM
    #129
    TacomaChris
    Yes that's the one
  10. Nov 30, 2012 at 8:48 PM
    #130
    hanrock
    hanrock Well-Known Member
    craig
    sask
    2012 nauticle blue dc lb
    any one used the east coast gear bushing to solve the front diff bearing vibe i have the vibe in my 2012 dc lb 4x4 . there is a lot of play in the left front cv where it enters the differential vibe feels like when you hit the rumble strip on the highway but not quite that loud and comes and goes with bumps in the road turning or 4 high engagement
  11. Dec 1, 2012 at 12:05 PM
    #131
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    I've had the bushing in my diff for almost 50k miles and it is def the fix.
  12. Dec 2, 2012 at 10:27 PM
    #132
    VancouverTaco
    VancouverTaco Well-Known Member
    Cole
    Vancouver, BC
    08 SR5
    Billy's 5100 all 'round, 2.5 front
    Just buy Magnaflow offroad pro series cat back exhaust. so load the whole truck vibrates. covers up the driveshaft and CV vibes nicely :)
  13. Dec 2, 2012 at 10:59 PM
    #133
    Foihdzas
    Foihdzas VA7PTZ
    Danny
    B.C Canada
    2010 Dbl Cab 5' Box 6 Speed
    2010 Tacoma, sold...
    Good to hear. I'm installing mine next weekend. Hope it helps
  14. Dec 3, 2012 at 1:13 AM
    #134
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    OME 885s & Dakars.
    3" front & 3" rear lift on my 4Banger AC.
    No vibes & nothing done to prevent them (No CB drop, No axel shims).​
  15. Jan 11, 2013 at 12:53 AM
    #135
    pontastic1
    pontastic1 Well-Known Member
    Pon
    NorCal
    '11 MGM DCLB TRD Sport
    OME 885 + TSB/AAL, Light Racing UCA, Fold-A-Cover G4 tonneau, OEM bedmat, AMP Bed X-tender, Neoprene Seat Covers, Weather Tech floor liner, Pop-N-Lock, UltraGuage, more to come.....
  16. Jan 11, 2013 at 1:48 AM
    #136
    Trowbocop
    Trowbocop Adventurer
    Nashville, TN
    03 Tacoma SR5 4x4
    X2
    OME 881s, nitrocharger sports. no problems
  17. Jan 16, 2013 at 4:53 PM
    #137
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    Installing a lift actually fixed the vibes/rattles my truck had.
    OME 885s, OME struts/shocks, Dakar leaf packs with 3rd leaf removed.
  18. Jan 25, 2013 at 3:16 PM
    #138
    blmfirert
    blmfirert Member
    Gary
    Hood River,Oregon
    07 Tacoma V-6 Level Kit front only
    Front level kit
    Yes. I have a 07 Tacoma access cap that I put a front 1.5 level kit on. Basically a taller spring cap on top of the spring. The vibration started the first time I drove it after the install. Took it back to Les Schwab and they said no way it must of had the vibe before we did the level kit (no). The tech took it for a drive and said must be something in the throttle body (what).
    Bottom line I've been chasing it for the past 2 years and 20k miles. I'm interested in the ECGS fix but don't know how to do it.
    Yes it's been to the dealer for every oil change and told to check for a front vibe each time. One time they put a chim under the tranny. But really all the visits say the same thing it's normal for the tacoma or it's your tires.
    What to do. Will it go out on me?
  19. Jan 26, 2013 at 6:30 AM
    #139
    Sgtfluffy16
    Corey
    PA
    Try and Isolate the vibration.. Take off your front driveshaft and see if its still there. Put the front back on, remove rear drive shaft, and drive in 4wd.. See if you can isolate the issue before spending a whole bunch of money on a whim
  20. Mar 11, 2013 at 4:32 AM
    #140
    K1992f
    K1992f Well-Known Member
    Kanon
    Dirty Hanover pa ...
    2012 tacoma TRD sport fully loaded
    6" fabteck 20" fuel hostage 33" nitto MTs
    I got a vib at 25 mpr and 60 mpr diff in my drive shaft only thing I here to help is moving it up and down by shimming didn't try it yet ?
