Have you dropped your Taco's spare tire yet?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by undermoneyed, Apr 7, 2013.
  1. Apr 7, 2013 at 3:53 PM
    undermoneyed
    undermoneyed [OP] aka Alley Opp,
    Mark
    B.C., Canada
    Tacoma TRD
    totally stock
    If you have not dropped your Taco’s spare tire yet, I suggest you do so at your earliest opportunity. Better to practice in your driveway than have to do it for real off road in the middle of the night. It took me over a year to get around to dropping my spare. I thought, how hard could it be, so I did not bother until today. It isn’t hard, just a tad tricky. For a complete blow by blow on dropping your spare, search for – “How to video: Change a tire on the Tacoma”.
    Only thing that I would add to that excellent video, is get yourself a 6” Mag light or some other light with a small diameter. Pack it with your jack handle. I was not connecting with the curly end of the jack handle. I had to use my 6 inch Mag lite to line up the end of the jack handle with the socket type piece on the spare tire assembly. You need a flash light with a small diameter so that you can see past the flash light to the socket like piece that you have to connect up with. Once you do that, it’s a piece of cake.
    HTH Mark
  2. Apr 7, 2013 at 4:23 PM
    tacomarandy
    tacomarandy Well-Known Member
    Central FL
    '13 Prerunner SR5
    Nah, I'll just read the manual if it happens--in the middle of the night --out in the middle of nowhere.
    Actually, I bought a 4 runner last year and dropped the spare the day after I bought it.
    I still haven't done it with my Tacoma and I've had it for 2 months now. your post just remined me. I'll do it in a couople of days.
    Thanks for the reminder!
  3. Apr 7, 2013 at 4:27 PM
    ndcmack
    ndcmack Well-Known Member
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    Spares worthless if you're running oversized. Drop it and leave it off. Anyone figured out if a 33" will fit under there?
  4. Apr 7, 2013 at 4:28 PM
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    You have to grind off the little wings that are closer to the cab and shove it under.
  5. Apr 7, 2013 at 4:29 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
  6. Apr 7, 2013 at 4:30 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Anyone who lives in areas where salt and corrosion are facts of life, dropping the spare a couple times per year and spraying a shot or two of lube in the winch will help keep it from seizing up too. Trying to use a spare when you need it can be tough if you can't lower it.
  7. Apr 7, 2013 at 4:38 PM
    yote
    yote Washington State University
    Mark
    Tacoma, WA
    2002 Ext Cab TRD Off-Road
    Any chance on a link to that DIY thread?
  8. Apr 7, 2013 at 4:44 PM
    Cain
    Cain Well-Known Member
    Southern California
    2012 Tacoma
    Chrome don't get you home
    AAA :)
  9. Apr 7, 2013 at 4:46 PM
    Detective_Dan
    Detective_Dan "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    IMO a spare is still better than nothing at all. it will still get you a few miles at a low speed if need be, even if there is a size difference
  10. Apr 7, 2013 at 4:46 PM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    Yeah i did one day. and flipped it i think. I need to do it agin thought and clean the mud and maybe some salt out.
  11. Apr 7, 2013 at 4:47 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    first off, why do you have your spare under you bed if you are offroading. Tsk. tsk.
    Would hate to have a flat spare when you need a full one.
  12. Apr 7, 2013 at 4:50 PM
    Conman117
    Conman117 AWESOME MEMBER
    Nathan
    BC, Canada
    98 Brap-coma
    Blue LED dash lights
    Just have full-size lift-out spares:cool:
    But in all seriousness, I don't know if my old spare would have dropped if I needed it. Its a good thing to check when its not muddy/raining/dark.
    Just like I had chains that didn't fit when I needed them.
  13. Apr 7, 2013 at 4:52 PM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    I should have thrown it in the bed. But I can’t keep it in the bed, i use the bed way to much to keep it in there.
  14. Apr 7, 2013 at 5:04 PM
    DR007
    DR007 Well-Known Member
    Dylan
    Port Barre, LA
    '06 DCSB PreRunner
    MagnaFlow exhaust, K&N cold air intake, MB TKO wheels with 265/75/r16 Hankook Dynapro ATM, Blue Center shift LED color change, Map Lights with Dome, LED Map and Dome lights, Cluster Light Change, DTRL, Parking Light as Blinker, Blue A/C Control lights, Blue Clock, Bed Lights, Debadged tailgate, painted all exterior plastic trim, 6LZ Lightbars in grille, OTRATTW switches, Fog Light in Reverse light Mod, LED Blinkers all around, Projector Fog Lights, 15" blitzpro light bar, added hidden cig lighter port, custom plate front bumper, OME complete lift with 885 front coils, Ultraguage, CB radio 3' whips, 12v bed lighter port, Center Console Lights, AllProOffroad Sliders, 50" roof led light bar, 2 BlitzPro 6LZ Reverse Lights
    I checked mine after a couple months of getting my truck and it was flat. I haven't needed it yet but I'm glad I checked and wasn't stuck with 2 flats.
  15. Apr 7, 2013 at 7:30 PM
    ScudRunner
    ScudRunner Three Tacomas Deep
    Erik
    Twin Cities, MN
    07 TRD 4x4
    IMRYO mirror mount, color keyed front and rear, SCS wheels, 5100 on corners, ALCAN leaf packs, ECGS bushing
    Great advice. I dropped mine this weekend while searching for the cause of my TPMS light.
    I spent a few minutes cussing until I found a flashlight. After that, I figured out what the hell the manual was talking about and the tire came down with no problem. Kind of neat, actually.
    Incidentally: for those of you with after market rims and 265/70 or 265/75/16 tires, will the stock spare (same size tire) work in a pinch, even though the offset and back spacing don't agree with your new rims?
  16. Apr 7, 2013 at 7:41 PM
    kryten
    kryten Well-Known Member
    Canada
    07 TRD Sport DCSB 6MT 4x4
    1" lift from 3rd gen suspension, 265/75/16 ATs
    ^ Stock size tires are 265/65/17 and 265/70/16, but one size bigger 265/75/16 (32") tire still fits under the truck.
    I have 4.5bs aftermarket rims with 265/75/16 AT tires mounted, and I also have a 16" OEM steelie with 265/75/16 AT tire as a spare to complete the set. Different offset, same size. Was told it will be fine so thats what I bought. Didn't have to use the spare from that set of (summer) tires yet.
    First time I had to drop the spare on the Taco, it was -15F outside. Took a while. :eek:
  17. Apr 7, 2013 at 8:38 PM
    undermoneyed
    Mark
    B.C., Canada
    Tacoma TRD
    totally stock
    Offroadtoy, Mandy has a great idea with the PVC pipe. I'll be installing one next week along with giving the elevator a shot of lube. Phil, I find that using engine oil seems to do a good job.
    SeattleCoug, go to the menu and under "Search", type in “How to video: Change a tire on the Tacoma”.
    It about the 3rd post down the list.
    Mark
  18. Apr 7, 2013 at 8:49 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    The only time I drop it is when the TPMS light comes on telling me the spare is low (can only be that since I check the others once a week).
  19. Apr 7, 2013 at 8:50 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    Labatt's Blue Light Lime. LOVE that.
  20. Apr 7, 2013 at 9:07 PM
    majorhavok
    majorhavok Rabid Conservative
    Mike in Cali..
    Peoples Republic of Caulifournia
    '13 TRD Sport DoubleCab 4x4
    Ultragauge, ImMrYo mirror, Tailgate lock, Snugtop Rebel Shell.
    Good point.. I got a flat on my xterra in the middle of GODNOWHERE at 2am once on a gnarly dirt road and had to figure out how to drop the spare. luckily it was a full size and inflated. I need to keep that in mind with future tire purchases.
