Have you had to replace your lift or adjust due to settling?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DestinTaco, May 10, 2011.
  1. May 10, 2011 at 7:01 AM
    DestinTaco
    DestinTaco [OP] Well-Known Member
    Destin, Fl
    2011 Silver PreRunner Off Road DC SB
    Challenger tube step, OME 884 Coil, 2" AAL, Weathertech vent visors
    I know a lot of times your lift will settle over time. Has anyone had to readjust their lift or totally replace it and if so, how long did your original lift hold up?
  2. May 10, 2011 at 7:03 AM
    mike686
    mike686 Well-Known Member
    Michael
    Waldorf
    10 Tacoma TRD Off Road
    See Build Thread
    Depends on how much you offroad I took it out and excercised my flexing and I had to readjust it so 200 miles really ... but it only settled .5 inches on one side
  3. May 10, 2011 at 7:08 AM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    I'm going to swap out my front coils in the next few moths, but it's to go with slightly stiffer, longer coils that will require no preload to correct the coil bind I currently experience.
    The rears are another story. I've worn out the rear leaf springs and definitely need to replace those due to sag. Got less than 2 years of use out of those springs, but my truck's a bit heavier and sees harder use than most.
  4. May 10, 2011 at 7:48 AM
    DestinTaco
    Destin, Fl
    I don't do any off roading. I'm hoping mine will last a while.
