have you seen the inside of a Golf ball?
Discussion in 'Off-Topic Discussion' started by chris4x4, Jan 8, 2009.
  1. Jan 12, 2009 at 7:02 AM
    #61
    neontrail
    neontrail ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
    Common Golf Ball Types
    Two-piece
    If you are just starting to play golf, you most probably need to consider using the two-piece golf ball. This type of ball, aside from being the cheapest type available in the market, is aimed at providing great distance. If your swing is slow, the big rubber core of the ball helps in transferring the energy from the swing to the ball efficiently, thereby providing you with good distance.
    If you are a neophyte in the game, you need to concentrate on your accuracy. Hence, you need a ball that will boost your distance, enabling you to concentrate more on building your accuracy. Once you have mastered consistency, then you need to try the other types of golf ball.
    Three-piece
    The three-piece ball is ideal for advanced players, who have pretty much mastered control, partly because a person wouldn't want to spend too much for a golf ball that will brandish his or her hit-and-miss swings. Such a ball, which is preferred by pro players, is composed of a core, which can be solid or made up of liquid or gel, a layer of wounded thread, and a plastic covering.
    Materials used as golf ball coverings
    Although there maybe other kinds of golf ball covering, the two most popular are the surlyn and balata.
    Balata
    Balata golf balls, which are usually three-piece balls, are made of soft covering. Professional golfers prefer such balls because they not only cuts and scuffs easily, but they are also easier to control. Furthermore, balata balls give more spin. However, these balls have shorter life span and are more expensive.
    Surlyn
    Surlyn balls are more apt for amateur gofers because they are cheaper. Most two-piece golf balls are made of surlyn, a hard material, thus it is more resistant to cuts and scuffs and provide more distance. Aside from being more inexpensive, such balls are also long lasting. However, it is harder to control and does not provide ample spin.
    Compression rate
    Traditionally, the tightness of the golf ball's thread windings determines its compression rate. Due to recent technological advancement, however, the compression rate of a golf ball is now basically dependent on how the ball is affected when it is hit. The compression rating of golf balls usually range from 70-110.
    Low compression balls
    Balls with compression rating of 70-80 are considered low compression balls. Such balls are soft and are easily deformed or compressed when hit. Players with slow swings are encouraged to use such ball.
    Medium compression balls
    Most advanced golfers prefer balls with a compression rate of 90. These medium compression balls provide both softness and ease of control.
    High compression balls
    Golf balls with 100-110 compression rating are high compression balls. Such balls are hard and are less likely to deform upon impact, compared to those with lower compression rates. A high compression ball is ideal for those whose club head speeds are high.
    Be keen in knowing how the type of ball or its compression rates affect your performance. Keep in mind that the knowledge of golf ball comparisons is handy in enhancing your strengths and masking your weaknesses in the golf course.
  2. Jan 12, 2009 at 11:14 AM
    #62
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    sure, you can look at that after you fix my boat
  3. Jan 12, 2009 at 12:00 PM
    #63
    tacoholic
    tacoholic Well-Known Member
    East Bay, CA
    lol, waaaaay too much time. Although the liquid filled one is interesting...
  4. Jan 12, 2009 at 1:20 PM
    #64
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Ok.......Define "Fix". :confused:
  5. Jan 12, 2009 at 1:33 PM
    #65
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    he meant blow up...or sink...or both
  6. Jan 12, 2009 at 2:29 PM
    #66
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I can do that....In any order. :D
  7. Jan 12, 2009 at 2:30 PM
    #67
    JimBeam
    JB
    2015 Tundra
    he'll appreciate it most if a huge fireball and some alcohol is involved
  8. Jan 12, 2009 at 6:41 PM
    #68
    tacoholic
    East Bay, CA
    +1, I'll help!
