Have you survived a frame rebuild?
Discussion in '1st Gen. Tacomas (1995-2004)' started by openstage, Aug 23, 2010.
  1. Aug 23, 2010 at 8:53 AM
    openstage
    openstage [OP] New Member
    Maine
    2002 Tacoma 2wd
    My 2002 Taco has less than 79k miles on it. They inspected, and I just heard they will do the frame redo on it. Has anyone come through this with your sanity intact? Any advice? Can you answer any of the following:
    1. How long did it take them?
    2. Now that you've had it back a while, how has it been riding since the rebuild - any problems?
    3. What parts did they recommend for you to replace and which ones (if any) did you have replaced while they had it apart?
    4. Are replacing the part really a good deal or just a way for them to squeeze more $$ out of us?
    5. What should I keep an eye/ear out for when it comes back?
    Thanks!
    openstage
    [​IMG] [​IMG] [​IMG] [​IMG] openstage View Public Profile Send a private message to openstage Find More Posts by openstage Add openstage to Your Contacts
  2. Aug 23, 2010 at 9:04 AM
    kingston73
    kingston73 Well-Known Member
    eastern MA
    09 SR5 4.0L 4x4
    I had mine done last october with pretty good results. I'll get to the one issue in a second:
    1) took about a month, most of the time was waiting for toyota to ship the parts and frame but I had a free loaner car the whole time
    2) the only problem was they forgot to tighten my exhaust which tripped a CEL. It could have been bad, the bolts from the cat to the rear where only finger tight, I actually unscrewed them with just my fingers and if they'd fallen off while driving I don't want to think about what would have happened. I called the dealer and told them about it and they offered me a free oil change, gee thanks guys.
    3) No recommendations from them and I didn't have anything done, but I should have had one of my steering rack boots replaced. It ripped shortly after I got it back.
    4) Most dealers I've heard of including mine said they'd do work without charging for labor, so it is a pretty good deal if you need something done. I'd recommend searching your truck for things that might need done and having it done while it's apart.
    5) check your bolts for the exhaust! Other than that, I don't know, but make sure you get a copy of all the work written down and keep it for your records.
  3. Aug 23, 2010 at 3:41 PM
    TacoMike
    TacoMike Active Member
    Pennsylvania
    '04 Tacoma SR5
    Here's what I did when they replaced the frame on my '04. They had the truck about a month, job only took 4/5 days. There were a few ahead of mine. Take full advantage of the situation if you can. You can get a reduce labor rate on some stuff because the truck is apart. I bought front and rear bilsteins, calipers, rotors, and pads. New synthetic fluids, for everything. I had the shop put in a new water pump and belt while it was apart. My truck had 58,000 on it at the time. All in all I spent $1200 on parts and labor for the stuff not included in the frame swap. Not a bad investment. I can't complain about anything, mine turned out good.
  4. Aug 23, 2010 at 6:09 PM
    snoope
    snoope Well-Known Member
    Ft.myers,FL
    2003 Lexus ES300/2004 Lexus 330 AWD
    openstage,
    you have mail ;):cool:..
