Have you used the crawl control? I mean really used it?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Chad l., Dec 12, 2020.
  1. Dec 12, 2020 at 6:16 PM
    Chad l.
    Chad l. [OP] Well-Known Member
    Colorado
    Blue 2006 TRD DBL Cab
    Stock
    I've read where guys have said, "they'd rather be in control" or I can "drive better than the crawl" etc. This fall I used the hell out of it in some crazy terrain, have the scars on my truck to prove it (still pissed, need some sliders) and all I can say is that feature on the offroads is crazy incredible. It will take you places (my opinion) that you simply can't go with your foot on the gas. That with the rear differential locker engaged, it simply blew me away.
    Going downhill you get the noise, and the jerking so to speak, but uphill, wow. Worth the price of admission.
    Need to get this painted....... Rough fall.
  2. Dec 12, 2020 at 6:21 PM
    TacoMamba35
    TacoMamba35 Well-Known Member
    PNW
    2021 Tacoma TRD OR DCSB 3.5
    Yep, used it a few times on some of those frame-twisting types of obstacles, and super steep rocky inclines. It just finds traction where any other mode will not, all while keeping things under control.
  3. Dec 12, 2020 at 6:40 PM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    Well its a hard lesson learned
    You're not alone though
    SandyTaco4x4 likes this.
  4. Dec 12, 2020 at 6:54 PM
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    More than one thing being true at once. There is a type of skill involved with off-roading technical terrain in which, at least for me, MTS has been more useful. However, crawl control can do things that a driver simply cant do by how it directs power to certain wheels based on traction it senses. That being said, technical driving is becoming a lost skill these days I think.
    jcampbell474 and Lt. Dangle like this.
  5. Dec 12, 2020 at 6:58 PM
    kairo
    kairo >_>
    Nor Nev
    '20 OR DCLB Quicksand
    This is the first vehicle I've owned and offroaded with the option to use it. I haven't yet. I've tested it out to make sure everything works, but it's gonna be pretty tough for me to get in a spot with a stock truck that the crawl control makes a significant difference. I've had a few double-locked jeeps on 35's, and Never got into a spot yet with the taco where I've thought "yah, having this feature would help"
    I'd trade all the crawl control and multi-terrain select stuff if they'd just let me lock the rear locker anytime I wanted.
    Locker > computers. But maybe I'm just old and bitter.
  6. Dec 12, 2020 at 6:59 PM
    eurowner
    eurowner Duke Sky
    Scoty
    CC is excellent ascending and descending loose undulating trails, though the brakes get a tad hot descending
    Lt. Dangle likes this.
  7. Dec 12, 2020 at 7:05 PM
    Dirk Diggler
    Columbus, GA
    2017 MGM OR DCSB
    Have you seen the 2wd low mod ? Might be a bridge depending on what you're lookin to do
  8. Dec 12, 2020 at 7:10 PM
    kairo
    kairo >_>
    Nor Nev
    I haven't. I didn't think it was a thing you could do on the 3rd gens. Might need to do some investigating.
    Dirk Diggler[QUOTED] likes this.
  9. Dec 12, 2020 at 7:11 PM
    Dirk Diggler
    Columbus, GA
    2017 MGM OR DCSB
    kairo[QUOTED] likes this.
  10. Dec 12, 2020 at 7:13 PM
    kairo
    kairo >_>
    Nor Nev
