havein some troubles here
Discussion in '2nd Gen. Tacomas (2005-2015)' started by grizzlytravis, May 1, 2010.
  1. May 1, 2010 at 5:28 PM
    grizzlytravis
    grizzlytravis [OP] Well-Known Member
    tampa florida
    08 taco 5 lug
    3inch ready lift, tint, foglights,BHLM,dumped exh,rims,tires, and a dent in the bumper
    so they other day i went to start my truck and got the ol click click click (dead battery sound) and so i figured okay no biggie ill just push start it being is a standard trans well...after 3 tries of that it would kinda start but runnin real low rpm and die out. some guy came along with a battery charger and it started turnin over real slow and i dont know if it was a coincedence or not but i gave it a lil gas and it cranked right up!? this was 3 days ago and i havnt had a prob since. i got the battery checked out and they told me it was good i mean its the one from factory and its two yrs old and with the cold winter we had in florida and now the heat idk im baffled help me!:confused:
  2. May 1, 2010 at 8:30 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Maybe the throttle valve stuck a bit and when you gave it some gas it kicked open? I dunno kinda a weird one. I'd chock it up as a glitch but if it happens again look more into it...
  3. May 2, 2010 at 5:08 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Have your alternator checked.....
    If the battery is completely dead, there won't be enough power to allow the spark plugs to function or even the door locks,etc.
    On our corvette, the battery was sooooooooooo dead.... it wouldn't even operate the door locks to unlock the doors using keyless entry.
    You can charge up the battery but it'll be sucked dry pretty quickly if the alternator isn't functioning properly. Just something to have checked.
  4. May 2, 2010 at 9:57 AM
    grizzlytravis
    tampa florida
    08 taco 5 lug
    well the only reason i feel the alternators not the issues is cause all my lights and everything was workin and my battery tested good
