Having a tough time finding this
Discussion in 'Towing' started by DJ Funktacular, Apr 11, 2019.
  1. Apr 11, 2019 at 2:23 AM
    DJ Funktacular
    DJ Funktacular [OP] Well-Known Member
    Maine
    '05 Toyota Tacoma TRD off road
    Last fall I got rear ended and he left the scene. He slid into me nearing a stop light during a snowstorm.
    Minor damage to bottom of bumper was done, but took out my towing wiring harness.
    I'm having trouble finding the part that I need, and where to buy it from.
    The rust you see is on the towing receiver. The rest of the truck has a new frame.
    Thank you in advance!
  2. Apr 11, 2019 at 2:30 AM
    Nixinus
    Nixinus Well-Known Member
    Oregon
    2010 4x4
  3. Apr 11, 2019 at 3:05 AM
    DJ Funktacular
    Maine
    Looks cool... but my harness is partially broken. I may get one of these but it still doesn't totally cure the issue. Thanks
  4. Apr 11, 2019 at 11:15 AM
    Nixinus
    Oregon
    2010 4x4
    Didn't see the amount of destruction....I was half asleep *my bad*
    A cursory search found a Toyota parts number of 82169-04010, but I do not know all the specs on your 2005 to determine if that part number is correct for your model. It's about $180.
    You can always go aftermarket from Amazon. This one is listed as compatible with a 2010, also a 2nd gen. Do your research and find one that you can plug/splice in for a fraction of the cost.
  5. Apr 11, 2019 at 12:06 PM
    DJ Funktacular
    Maine
    Wow, maybe I should just pay the $200 deductible and get a new bumper to go along with it!
  6. Apr 12, 2019 at 9:36 AM
    Shellshock
    Iowa
    Looks like there is quite a bit of corrosion on the connector so you likely need a whole new assembly, not just the mount. I dont remember how the wires are connected to the back side of that if you'll be able to just unplug or if you'll have to cut them and splice into a new connector.
  7. Apr 13, 2019 at 4:12 AM
    DJ Funktacular
    Maine
    I guess the question is, of I still can, should I just re-file the claim to get the bumper and harness for $200 deductible? I'm gonna call some salvage yards today first though.
  8. Apr 15, 2019 at 3:27 AM
    Indy
    Indy Master of all I survey.
    A new socket is $20-$30 available pretty much anywhere including walmart.
