Having an issue with spacer lift
Discussion in '1st Gen. Tacomas (1995-2004)' started by Yota4Ever, Apr 4, 2014.
  1. Apr 4, 2014 at 5:58 AM
    Yota4Ever
    Yota4Ever [OP] Well-Known Member
    Taylor
    Oregon
    Sas'd 00 4wd PreRunner
    38" Tsl Super Swampers 3-link front Fox 2.0 Built D44 Built D60 Cobra Cb
    Hi I just recently put on a 2.5 inch spacer lift
    And noticed that when I'm at full drop my passenger side top ball
    Joint hits on my coil pretty bad now I'm not sure what could
    Cause this but I have a few things I wanna try
    First thing is I want to try getting an alignment
    Second is hooking my front sway bar back up
    Anyone have any other suggestions I'm kinda lost on what to do
    At this point thanks
  2. Apr 4, 2014 at 10:06 AM
    604YOTA
    604YOTA Well-Known Member
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    Grey wire mod, eibach, 5100's & 5125's, ome Dakar leafs, 1.25 rear shackle, Gibson exhaust, ram air intake, throttle body spacer, boot slide mod, poly bushing kit, extended brake lines.
    Had the same problem with my spacer lift. isn't really a problem though cuz you probably don't want to wheel it hard with a spacer lift. The only time you will be at full droop in other words is when its on a jack. Save up a bit and get some 5100s maybe?
  3. Apr 4, 2014 at 10:09 AM
    Spoon93
    Spoon93 Well-Known Member
    Rogue valley
    06 DCSB SR5
    Title says it all. Wheeling with Spacer lifts not so good. Using them for looks and mild forest service roads no big deal. I would suggest not wheeling to the point of full flex and save for a suspension lift up front. You can always block the rear end until funds are available to replace leafs...
  4. Apr 4, 2014 at 12:11 PM
    Yota4Ever
    Taylor
    Oregon
    Can an alignment help at all cause it's only on that one side ??
  5. Apr 4, 2014 at 1:41 PM
    Terminal4
    Terminal4 Well-Known Member
    South of the Sierras
    2022 DCLB 4WD
    Accutuned Fox suspension, Wildpeaks AT4, Batzmaru
    had same issues w/spacers. what they said^^^. and yes, alignment always helps when lifting. whenever the fronts lifted, camber increases and suspension geometry's off. more importantly, you'll see a change in your tire's tread pattern first though.
