Having brake problems. Please help. Thank you!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Brroyota, Jul 2, 2021.
  1. Jul 2, 2021 at 11:43 PM
    Brroyota
    Brroyota [OP] Member
    Hello! Before I even get started I have read multiple forums and still have not figured this issue out.
    I have a 2008 Toyota Tacoma TRD 4x4 V6. I have had this pulsating brake pedal haunt me for almost a year... the brakes feel great while driving straight and hitting the brakes or turning right...the problem is when I am driving and turning left and hitting the brakes to slow down, that is when my brakes are pulsating or feeling spongy/bouncy. Also when the brakes are pulsating I hear a humming noise come from behind the dash. Sounds like some motor of some sort..... once I turn my wheel straight the noise and the pulsating stops.
    i have changed my front brakes, rotors, calipers, brake booster, master cylinder, abs sensors and abs module...I have yet to fix the problem..
    I would really appreciate if someone could give me some feedback. Thank you!
  2. Jul 2, 2021 at 11:53 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Does your truck have VSC?
    Kolter45 and Jimmyh like this.
  3. Jul 3, 2021 at 12:01 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Have you scanned the abs/trac system for trouble codes?
    blu92in99 likes this.
  4. Jul 3, 2021 at 11:37 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
  5. Jul 3, 2021 at 1:16 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
  6. Jul 3, 2021 at 1:55 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Too late for that :anonymous:
    Jimmyh likes this.
  7. Jul 4, 2021 at 12:03 PM
    Hugh Morron
    Hugh Morron Manic Mechanic
    Bill
    Schuylkill County, PA
    12 DCLB SR5 4X4 Barcelona Red Metallic
    ARE Cap, AVS Bugdeflector II, AVS Ventshades, DTRL delete, ABS/VSC/TRAC disable, Toyota LSD with clutchpacks, N-Fab Lightbar, Hella 700ff lights
    Did you check your wheel bearings?
    SR-71A and landphil like this.
  8. Jul 5, 2021 at 2:29 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Pads. :fenforcer: Rotors. :fenforcer: Calipers. :fenforcer:what else....:fenforcer::fenforcer::fenforcer::fenforcer::fenforcer:
  9. Jul 5, 2021 at 6:40 AM
    badzook
    badzook Member
    East Coast
    Off Road
    Climb under your truck on the drivers side. Grab your Inner Axle at the Differential and Shake it. If it's loose you will know it. Then look up ECGS Clamshell CV Axle Bushing Install. My guess is you wiped out your axle too.
    Cross your fingers the internals in the diff survived.
    I have a bone stock 2014 Taco with 67k that wiped out that bearing and the Axle. I replaced with bushing and new Axle. Very similar symptoms to what you described. Problem solved
    And..... a 2018 4Runner Bone Stock with only 20k same problem I have yet to fix... Toyota would only replace with same pos part not the bushing. Right now I'm really pissed at Toyota...
    Therefore, I had to do it myself. It's not complicated just a bit involved. Watch a few videos then buy the parts and tools.
    Cost me $500 but for two vehicles. Just need the Puller, Seal install tool, Torque Wrench, and 35mm socket. the rest just handtools etc,
    Please report back. Badzook
  10. Jul 5, 2021 at 8:15 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    You may have a bad ABS encoder on one of the front wheels.
    The "hammer sound" is likely the ABS system pulsing.
  11. Jul 5, 2021 at 8:26 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    If the pulsating doesn't occur when the OP isn't on the brakes when turning left, then this has nothing to do with OP's problem.
  12. Jul 5, 2021 at 8:30 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Yep could be corrosion buildup on the tone ring on the inner face of the wheel bearing. Relatively easy to diagnose with a scan tool.
  13. Jul 5, 2021 at 10:08 AM
    Larzzzz
    Larry
    MA
    I believe the tone ring is on the CV.
    Edit: duh. You're right. The tone rings are on the rear wheel bearings.
  14. Jul 5, 2021 at 11:48 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    The front tone rings are on the bearing inner face. This way it is better protected against water and corrosion compared to the CV-mounted tone rings on some FWD cars. However, water still gets in after 13 years, especially if taken off-road.
    SR-71A likes this.
  15. Jul 12, 2021 at 7:36 PM
    Brroyota
    I appreciate all the responses to my issue… I am not certain if my truck has VSC or not… I don’t see any VSC light or button on the truck….. I had it serviced and was told to change all of the wheel speed sensors and I did…. Then my abs and brake light came on and it start pulsating even more than normal… I had it scanned with a OBD2 reader and the code that comes up is C1239 “foreign matter is attached on the tip of left rear sensor”…. So next I completely removed the left rear drum and cleaned the hub where the sensor reads off of… not sure what that part is called….. and truck still drives like crap….. I tried to remove both abs fuses and it drives great without it… no brake issues without the abs fuse connected….
  16. Jul 12, 2021 at 7:40 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Pretty sure sensor and tone ring is built into the wheel bearing assembly, whatever you cleaned with the drum off probably wasn't the tone ring
    Probably needs a new bearing assembly
    SR-71A likes this.
  17. Jul 12, 2021 at 8:06 PM
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Try pulling off abs sensor and see if its contaminated with oil . Axle seal could be leaking .
  18. Jul 12, 2021 at 8:11 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    I would say if your steering wheel shakes then warped rotors. If your brake peddle pulsates it could be warped rear drums. I would pull each rear and see if you have a spot that gives resistance when turning.
  19. Jul 13, 2021 at 11:50 AM
    Brroyota
    Abs sensor does have some oil on it.. not alot but it does… just took it apart . Attached is a picture of that helps
  20. Jul 13, 2021 at 12:19 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Common! Slippers and socks, are you kidding? Go put some boots on, crack open a beer and put that in the pic for crying out loud.
    Jimmyh likes this.
