Having dealership under coat new truck
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Wenty, Feb 6, 2023.
  1. Feb 6, 2023 at 4:05 PM
    Wenty
    Wenty [OP] Well-Known Member
    Minnesota
    2023 Tacoma Sport 4x4 V6
    Is this a good thing? Having the rubber coating put on and whatever else they put on it.
    It has a 7 year warranty on it.
  2. Feb 6, 2023 at 4:09 PM
    GBourne
    GBourne Just a regular guy
    Grant
    Surprise, AZ.
    23 Ram 1500 Classic
    Dumped the Tacoma, that's all it needed.
    Where do you live?
  3. Feb 6, 2023 at 4:11 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    I had the vulcanized rubber undercoating applied to my frame and underbody. Frame still looks brand new except for rock chips here and there.
    It also acts as a sound deadener.
    A lot of folks gonna chime in and say don’t do it because you will ruin your truck. I’m sorry but that’s total BS. If it’s done right to a new truck, it works great.
  4. Feb 6, 2023 at 4:12 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    No, never use rubberized undercoating. It eventually cracks flakes and will hold water salt and cause more problems. Lot of times, if you read fine print. It will void oem warranty.
  5. Feb 6, 2023 at 4:13 PM
    petethemeat
    petethemeat Well-Known Member
    Pete
    Ontario
    2023 TRD OR AC MT
    I would use a rust protection specialty shop for undercoating. Krown is known for good protection around here in Canada.
    Leafan, df41590 and 10thMTNgrunt like this.
  6. Feb 6, 2023 at 4:14 PM
    10thMTNgrunt
    10thMTNgrunt This is the way, step inside.
    2013 TRD Sport
    Regarding the seven year warranty, let’s say you have it put on before the truck leaves the lot, in seven years can you have it reapplied to renew the warranty? If no to the warranty renewal, is it something that can be reapplied after seven years of wear and tear? I know with fluid film, one can just hose their truck undercarriage before each application and each renewal is as protecting as the one before.
    Adam_W and Gen2 Man like this.
  7. Feb 6, 2023 at 4:15 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Exactly what I’m talking about.
    I bet you never had rubberized undercoatings on your vehicles. And you probably watched that YouTube video that was shown about a thousand times on here.:)
    det107 and J Williams like this.
  8. Feb 6, 2023 at 4:15 PM
    Gen2 Man
    Gen2 Man Well-Known Member
    Midwest
    07 Sport DCLB
    3rd Gen Sport wheels
    Use a coating that you can monitor what’s happening underneath. The black rubberized stuff is a throwback to 1970s and yes it will separate and get moisture underneath promoting rust
    use something more modern that doesn’t seal in the water. Even cosmolene is better than the rubber crap
    50Buck, det107 and df41590 like this.
  9. Feb 6, 2023 at 4:16 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    No. If Toyota thought it was a good idea why would they have not already done it? These type of offerings by dealers (normally done by the finance manager, even if you are not financing) are just basically scams. It is an easy way for them to sell something you don't need and charge way more than it cost in the aftermarket and hide the cost in your monthly payment.
    BmTaco91 and bedobe like this.
  10. Feb 6, 2023 at 4:16 PM
    Wenty
    Minnesota
    Minnesota
  11. Feb 6, 2023 at 4:17 PM
    na8rboy
    WI
    Yes, I have had it on vehicles before, and it did exactly what I described. Never again. Never watch YouTube or Tik tok.
    50Buck likes this.
  12. Feb 6, 2023 at 4:17 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    My truck is almost 5 years old and they use salt where I live. I can take a pic of my undercarriage if anyone would like to see it.
  13. Feb 6, 2023 at 4:17 PM
    MadKatt
    MadKatt In need of serious help..
    Frozen Midwest Tundra
    2019 TRD OR DCLB Calvary Blue
    Hard pass on that if you live in the rust belt. As stated above cover your frame with something you can monitor rubberized coating will hide what’s actually going on which is a very bad thing in the rust belt.
    50Buck, Gen2 Man and na8rboy like this.
  14. Feb 6, 2023 at 4:18 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Poor preparation and/or application.
    CalcityRenegade and Gen2 Man like this.
  15. Feb 6, 2023 at 4:19 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    It was a part time job while I was in college.
    It cannot be applied 100% and water will eventually get behind parts of it. It can't be helped. Not saying it will ruin your truck but pretty much every other thin coating will protect better. Con is it has to be applied every year unlike yours.
    50Buck, RustyGreen, RustyVT and 3 others like this.
  16. Feb 6, 2023 at 4:23 PM
    ssd2k2
    ssd2k2 Well-Known Member
    Keith
    Minnesota
    2019 Tacoma TRD Sport M/T
    For a product that needs to be installed pretty much perfectly, do you really trust a dealer to do that?
    If you are in the Twin City area this guy does Wool Wax (a slightly better product than fluid film because it lasts a bit longer) applications.
    https://www.affordableautosolutions...lxYkVV8WA3qQN7VYElSvzvfpcNLvLfR2BMh06gLOYGurs
    I've had it on my truck for 3 years, I go through the car wash with underbody sprayers once a week and the only places that have needed to get resprayed each year are the diff and control arms.
  17. Feb 6, 2023 at 4:24 PM
    Gen2 Man
    Midwest
    07 Sport DCLB
    Go for it and report back in about 5 years
    FlyingWolfe, MadKatt and na8rboy like this.
  18. Feb 6, 2023 at 4:27 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Fair.
    You see back then, they used “tar” like shitty rubber and applied it very thick.
    Nowdays they use vulcanized rubber. It’s a thin and very hard coating. Almost like black paint. I triple checked my frame after the application and couldn’t find anything I didn’t like. I guess time will tell:) So far though, no complaints at all.
    Lt. Dangle and hiPSI[QUOTED] like this.
  19. Feb 6, 2023 at 4:27 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    :wave:
    My frame looks brand new.
  20. Feb 6, 2023 at 4:28 PM
    na8rboy
    WI
    Whom applied yours?
