Having issues with my starter
Discussion in 'Hawaii' started by bkiel311, Jan 29, 2014.
  1. Jan 29, 2014 at 8:20 PM
    bkiel311
    bkiel311 [OP] Well-Known Member
    Brian
    Bremerton, WA
    2024 Silver Tacoma DCLB TRD OffRoad 4x4
    Stock (for now)
    I posted about this about this in the other areas of the forums but not getting much luck. I was curious if any of you guys have had any experience with taking the starter out and possibly cleaning it out. I'm having issues with the truck randomly starting. When it doesn't it just clicks. I'm thinking there's mud in there and it might causing issues and just needs a good cleaning.
    When I took it in for routine maintenance the dealership wanted about 1300 to order and swap it out. I'm not doing that if it's necessary. I've watched vids about how to get to it but not much luck on actually taking it out. I've got the service manual going back to the earliest year in the generation. But it's a bit daunting for a first time on this, at least for me.
    Any help is appreciated.
  2. Jan 29, 2014 at 9:23 PM
    kh7nm
    kh7nm Stay Boosted
    Miles
    Ewa Beach, Hawaii
    2011 MGM DC 4x4 TX PRO Off Road
    What have you done to your truck lately
    Not covered under warranty?
  3. Jan 29, 2014 at 9:24 PM
    Frkypunk
    Frkypunk "Death is what you make of it."
    Timmy
    Woods of P.A.
    2010 Tundra limited,2015 Highlander limited, Prius(commuter)
    Got the gas mileage down to 13mpg! Modification complete
    A click noise is almost always a bad solenoid.
  4. Jan 29, 2014 at 9:45 PM
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    I've pulled one out before, it sucks a little...have to go in from the driver side tire near the exhaust header.
    You have a 2013 so it should be covered under warranty.
    Could also try and check the voltage on the starter wire. I had a bad wire in my car, when I was thinking it was the starter.
  5. Jan 29, 2014 at 9:47 PM
    raycie
    raycie Well-Known Member
    Oahu, HI
    2013 DCLB / 2016 4R Trail
    In need of $$$
    Yea.. A 13 should be under warranty.... i had to change my starter on my 99 a while ago. Bought the new starter and brought it into a shop and had them change it for a couple bills....
  6. Jan 29, 2014 at 9:55 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    I had a clicks starter on my 2006 tacoma for a while. Just before I was going to replace it, it stopped clicking, and started working. I'm still running it today. It was clicking a couple times then working. You can replace the contacts in the starter apparently.
  7. Jan 29, 2014 at 11:59 PM
    bkiel311
    Brian
    Bremerton, WA
    Stock (for now)
    I'll check the solenoid. They said the warranty won't cover it because it's muddy. Kind of a copout.
  8. Jan 30, 2014 at 8:23 AM
    luka
    Kailua, HI
    that is a pretty bad copout. could get some break cleaner or electrical plug cleaner and shoot the mud off and see if that helps. maybe the contact is dirty.
  9. Jan 30, 2014 at 1:24 PM
    cheech1
    cheech1 Well-Known Member
    Kaneohe, HI
    08 PreRunner Off Road
    Warranty won't cover it cause it's muddy? That's total BS!
  10. Jan 30, 2014 at 1:27 PM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    Yup, BS on the mud, take it to a manual car wash and clean the phucker real good, then take it back in for the warranty work...
    Dirt gets all over cars and trucks after a couple of rain/snowstorms, they are copping out big time on this one, so get them back with a clean shiny starter next time...
  11. Jan 30, 2014 at 2:25 PM
    bkiel311
    Brian
    Bremerton, WA
    Stock (for now)
    I thought it was a BS reason too.
    Now it makes an odd noise that I can't describe when I turn the ignition off. Almost to a point of bubbling. So I'm starting to think that the starter is flooded. Is that possible. It sucks not having the experience for this. If only it was a damn computer, this would be easier. lol
  12. Jan 30, 2014 at 2:26 PM
    TexasPreRunner
    TexasPreRunner Well-Known Member
    Anthony
    San Antonio/Houston,TX
    2011 PreRunner
    Can you post a video of the sound?
  13. Jan 30, 2014 at 2:29 PM
    Detective_Dan
    Detective_Dan "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    hmmmm, you own a 4x4, but because there is mud on it, they wont cover it. f that, clean it off and if it still doesnt work, go to a different dealer so you dont have to deal with their BS
  14. Jan 30, 2014 at 2:40 PM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    How many dealers in HI? Probably not too many choices, big ass island in middle of big ass ocean, they have a special hold on your hanging marbles...
  15. Jan 30, 2014 at 2:49 PM
    Detective_Dan
    Colorado Springs
    yeah, didnt notice that lol
  16. Jan 30, 2014 at 2:59 PM
    bkiel311
    Brian
    Bremerton, WA
    Stock (for now)
    Here's an audio clip.
  17. Jan 30, 2014 at 3:05 PM
    bkiel311
    Brian
    Bremerton, WA
    Stock (for now)
    I only have a couple to work with on Oahu.
  18. Jan 30, 2014 at 4:12 PM
    luka
    Kailua, HI
    just a single click? i'm pretty sure the contact isn't getting the voltage needed.
  19. Jan 30, 2014 at 6:44 PM
    bkiel311
    Brian
    Bremerton, WA
    Stock (for now)
    It's random. If I hold it it will go 100%. But if I try to do it normally it's random. It will work 3 times straight but sometimes it will take about a few tries.
  20. Jan 30, 2014 at 8:13 PM
    kh7nm
    kh7nm Stay Boosted
    Miles
    Ewa Beach, Hawaii
    I got a 5lb sledge hammer that might help.
