Having issues with retros
Discussion in 'Lighting' started by rhewins13, Jul 17, 2012.
  1. Jul 17, 2012 at 5:37 PM
    rhewins13
    rhewins13 [OP] Well-Known Member
    Richard
    rhode island
    2013 sr5 debadged
    3" toytec lift, 20" chrome wheels with 295/55 r20 nitto trail grapplers, leer 100xr cap w/ thule bars
    So here is the issue. I have the morrimoto mini d2s retrofit kit on my truck. Im running 35 watt 3five ballasts with the 4300k orsam bulbs. My driver's side light went out this morning and I checked the ballast (had one burn up on me a month ago) and it was good. The bulb appeared to be good as well. I then connected the bulb to the ballast outside the housing and turned it on and the light came on for a second and then went off. This kept happening. I have no idea what the issue is.
    The ballast on the drivers side is brand new, less then 2 weeks old. It is the replacement that came from trs. The bulbs are also new and were put in less then 2 weeks ago. Anyone have any ideas of what is wrong or on how to troubleshoot this issue?
  2. Jul 18, 2012 at 6:39 PM
    DevL
    DevL Well-Known Member
    What does the bulb do when fitted to passenger side ballast?
  3. Jul 18, 2012 at 6:41 PM
    griffin407c
    griffin407c Well-Known Member
    Upstate NY
    '12 DCLB MGM 4x4 Sport w/Entune
    OME 885s on Bilstein 5100s set at 0 with 1/2" plate spacers. OME Dakars with Bilstein 5100 Extended Length Shocks. 16" Pro Comp 7032 wheels wrapped with 285/75-16 Duratracs
    check your grounds
