Having low RPMs and as a result vibrations
Discussion in '3rd Gen. Tacomas (2016-2023)' started by gord1212, May 10, 2024.
  1. May 10, 2024 at 3:29 PM
    gord1212
    gord1212 [OP] Member
    2018 Inferno Tacoma TRD Off Road
    OTT
    Hi all,
    First time poster, so I apologize for any rookie mistakes here. But I recently got my 2018 Tacoma Off Road tuned with the OTT tune and didn't have any issues initially, but noticed after 500kms that there was a slight vibration when in idle and lower rpms (below 1500), I got the tune adjusted (lower throttle response) and it's worse now. The truck will idle at 500 RPMs and cruises at or under 1500 RPMs... It's not such an issue at 1500 or higher, but anything under and the vibration is very noticable. My mechanic couldn't find anything that would be causing this. I'm just looking for any leads on a solution or if anyone else has had this issue. Thanks everyone.
    WilliamJames likes this.
  2. May 10, 2024 at 3:33 PM
    czukie
    czukie Well-Known Member
    Colorado
    ‘23 Tacoma Access Cab
    What’s your setup? Got a lift?
  3. May 10, 2024 at 3:42 PM
    gord1212
    OTT
    No lift, 265/70/R17 tires. As far as I know everything else is stock (I got it in September '23 with 65,000kms on it)
  4. May 10, 2024 at 3:48 PM
    cfarley
    cfarley Well-Known Member
    Michigan
    2023 TRD Off-Road
    Center console organizer
    Mine has this driveline vibration, which I believe to be torque converter shudder. The only thing that fixed it for me was running premium fuel.
  5. May 10, 2024 at 3:55 PM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    2023 Ford Raptor
    There isn't a single parameter within the ECU that is changed on our tune for the 3G Tacoma at idle. Just FYI.
    Polythemus, 33yrsoftoys, Kbar and 2 others like this.
  6. May 10, 2024 at 4:12 PM
    RCTuningFL
    RCTuningFL OTT Florida Tuner
    RC Tuning FL
    Melbourne / Brevard County, FL
    2020 Tacoma TRD Pro @rctuningflgarage
    OTT + Magnuson Supercharger - 5.29s etc etc.
    There is no tune parameter that will cause your truck to vibrate. I suspect something truck related. Not really fair to make a post labeled "OTT causing low RPMs and vibration" when you're trying to figure it out. Misleading.
    Polythemus, timw1, Glaese and 2 others like this.
  7. May 10, 2024 at 4:21 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    So it happens whether moving or not but whenever under 1500 rpms? I’d start by looking for something come loose or cracked.
  8. May 10, 2024 at 4:46 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I don't think it has anything to do with the tune.
    Have you tried the following:
    1. Idle in Park / Neutral vs Drive.
    2. Revving the engine in Park / Neutral to see if the vibration goes away.
    3. Holding your foot FIRMLY on the brake, then giving it a little gas to see if the vibration changes or goes away.
    You obviously can not give it too much gas or the rear wheels will start to spin.
  9. May 10, 2024 at 4:48 PM
    gord1212
    OTT
    I suspected fuel at first and ran a tank of premium and I'm on my second tank of it now with no improvement. I'm not saying it's the tune completely, but the tune is causing the truck to run low RPMs which I think is linked to finding the issue. This issue wasn't present before the tune and then once I got it, it's here. I don't think that's a coincidence.
  10. May 10, 2024 at 4:49 PM
    gord1212
    OTT
    Yes, I do still feel it between 1500-2000 but it is very noticable anything under 1500
  11. May 10, 2024 at 4:50 PM
    soggyBottom
    soggyBottom Well-Known Member
    Are you talking about lugging?
    When your car engine is at very low RPM while driving down the road, the vibration you're experiencing is likely due to "lugging" or "engine lugging." This happens when the engine is operating below its optimal power band or RPM range. In this state, the engine struggles to produce sufficient power to maintain the desired speed, leading to increased vibrations.
    By downshifting, you bring the engine RPM back into its optimal range, where it can produce power more efficiently. This action reduces the load on the engine, eliminates lugging, and consequently, the vibrations typically go away.
    tune or not, is this what you're experiencing?
  12. May 10, 2024 at 4:52 PM
    gord1212
    OTT
    Also, for the record I'm not trying to talk negative about the OTT tune. Other than this vibration I love the tune. I'm simply trying to find a solution.
    eurowner likes this.
  13. May 10, 2024 at 4:58 PM
    gord1212
    OTT
    Its present in neutral. When I did the park and revs its not very noticeable when the rpms hit 2000
  14. May 10, 2024 at 5:02 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
    Might also check the heat shields around the exhaust. I had a similar issue on my last Ranger. One of them was rattling against the pipe.
  15. May 10, 2024 at 5:04 PM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    Keep in touch with your tuner. Maybe you need a re-flash. Try going back to stock to see if if goes away. The last thing you changed is usually the problem.
    Kbar and Canadian Caber like this.
  16. May 10, 2024 at 5:28 PM
    gord1212
    OTT
    I am considering this as a last resort. I was hoping to find a solution prior to this because I really love everything about the tune.
  17. May 10, 2024 at 5:32 PM
    OldSchlPunk
    Rich
    East Central Wisco
    Go back to stock to see if that's the source of your problem. It doesn't mean permanent. If the problem goes away, re-flash and see if it comes back. There have been quite a few people who have had to do this.
    gord1212[QUOTED][OP] likes this.
  18. May 10, 2024 at 5:49 PM
    Kbar
    Kbar Well-Known Member
    Western WA
    22 OR
    Yea your tuner should be able to flash it back to stock. You drive around for 20 minutes and circle back to him. If the vibration still happens it’s not the tune. Could be something as simple as turning your radio down lol.
  19. May 10, 2024 at 6:12 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    OP, they are not "tuners". Take their "thoughs" with a grain of salt.
    Have them to flash back to stoke.
    FyI, On other tune provider's thread, it was mentioned that VFTUNER software was changing value in tables.
  20. May 10, 2024 at 6:19 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Flash back to stock. If it goes away, ask for your money back!
    Ronk44 likes this.
