Having MPG issues, whats wrong?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nor7, Apr 19, 2015.
  1. Apr 20, 2015 at 11:46 AM
    mountainmonkey
    mountainmonkey Well-Known Member
    Colorado
    '13 Double Cab TRDOR DCSB
    Never enough
    This was already brought up above but I wanted to expand upon the point, speed plays a huge role on mpg during highway driving. The reason for that is because the power required to overcome aerodynamic drag has a cubic relationship to speed. Meaning if you double your speed ie 30mph to 60mph it takes 8 times as much power to overcome the aerodynamic drag. Yes you read that correctly, 8 TIMES! Considering aerodynamic drag is only one component of total drag you can see why speed plays a big factor.
    Your tires also will have higher rolling resistance than OEM tires which will also contribute to lower mpg as well as increased weight which others have mentioned above.
    Sorry for the long rant, I just hadn't seen a technical explanation about speeds effect on mpgs anywhere on tw before so I thought this as good a place as any.
  2. Apr 20, 2015 at 3:01 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    pair that with the brick like aeros of the taco and thats why i will see a 4+ mpg drop when crusing at 75-80mph vs 60-65
  3. Apr 20, 2015 at 3:17 PM
    mountainmonkey
    Colorado
    Never enough
    Exactly! Couldn't have said it better myself
  4. Apr 21, 2015 at 11:32 AM
    Nor7
    Nor7 [OP] Well-Known Member
    Eric
    Texas
    2011 Tundra, Texas Edition
    Ok, so I've modified my driving habits and was able to boost my MPG to 18.6!!
  5. Apr 21, 2015 at 11:44 AM
    Nor7
    Eric
    Texas
    Also, I'd like to expand on what has been said above (technical stuff). Being an engineer (PE Mechanical) I can expand on these concepts.
    The energy to move the vehicle is E=m*v^2 so any increase in velocity is exponentially increased.
    Regarding tires, the Torque required to rotate the tires is T=tJ/r where the rotational moment of inertia (2nd moment of inertia) is affected by the equation J=(pi)(r^4)/2. So you can see that additional weight towards the outside of the tire is added at a rate to the 4th power and being at the outside it has the greatest effect.
    Sorry for the nerd rant but my inner engineer had to speak up (just got my PE about 6 months ago).
    With all that said, nobody really buys a truck for great MPG but I did get this truck to get better MPG than my last one. :)
  6. Apr 21, 2015 at 11:52 AM
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    Great job!
    Also, check your tire pressures. When you move from a P rated tire like the stock tires to a LT tire like a KO your nominal tire pressure should increase by quite a bit.
    For example, a SR5 or TRD OR/Sport will run tire pressures around 30 PSI according to the door tag but a Baja or Pro will run at 46 PSI according to the door tag. This is because the load inflation curves for P and LT tires are very different. Yes an LT tire can handle a higher maximum load but at any given inflation pressure an LT tire handles a lower load than a P tire. LT tires handle higher loads only by running much higher pressures.
    So it is possible if you installed your BFG KO LT tires but are running 30 PSI pressures as the door sticker says for your stock P tires that you are actually running under inflated and that could also lower MPG by a bit.
  7. Apr 21, 2015 at 12:05 PM
    DVexile
    Ken
    All wrong. Entirely wrong. The *power* to move a vehicle (energy is irrelevant) with no rolling or aerodynamic resistance is zero. Conservation of momentum. You've confused the kinetic energy of the vehicle with the power to maintain speed.
    Of course there is rolling and aerodynamic resistance. And so the relationship of power to maintain speed depends on how those resistances change with speed.
    In general air drag goes as the velocity squared, but this is a bit of a simplification. It assumes that the drag coefficient of the vehicle is itself not velocity dependent which is not strictly true. But square law is a good enough approximation.
    The larger issue is that air drag is not the only resistance, there is the rolling resistance associated with the contact with the road and the drive train. This is not square law, typically it is less than square law. The result being the overall resistance is dominated by rolling resistance at lower speeds and air drag at higher speeds.
    So when considering 65 vs 75 for driving the result is slightly less than square law. The higher the speeds the more closely square law is a good approximation.
    But none of this has anything at all to do with E=0.5m*v^2
    Indeed, and this can drastically effect city mileage where there is lots of starting and stopping of the wheels. On the highway the impact is far less clear from equations and fundamentals.
    Exactly. Though I just threw KO2s and a camper shell that overhangs the cab on mine and ouch as far as MPG goes on the highway!
  8. Apr 21, 2015 at 12:19 PM
    DVexile
    Ken
    As a quick way to experiment with velocity vs fuel efficiency you can use this online tool:
    http://ecomodder.com/forum/tool-aero-rolling-resistance.php
    Some very rough parameters for a Tacoma:
    Weight - 5000
    Crr - 0.12
    Cd - 0.5
    A - 25
    Leaving the rest at defaults gives us:
    55 mph - 22.5 mpg
    60 mph - 20.2 mpg
    65 mph - 18.0 mpg
    70 mpg - 16.3 mpg
    75 mpg - 14.7 mpg
    Obviously the parameters loaded are not exactly correct, but they give a rough idea for the balance between rolling resistance and aero resistance. At 65 mph the aero resistance is about 70% of the total resistance and so the relationship is not quite as bad as square law.
    So yes, slowing down helps quite a bit. And 65 vs 75 should expect around a 3 mpg difference.
  9. Apr 21, 2015 at 1:05 PM
    thewarriordinghy
    thewarriordinghy General Lee's Titan
    Ben
    Georgia
    2017 Nissan Titan 4x4
    Temporarily Stock
    I drive 80mph and floor it at lights...17mpg.
  10. Apr 21, 2015 at 1:24 PM
    Nor7
    Eric
    Texas
    I appreciate the feedback but the science is sound. You are referring to 'Work', which is power over time. However once you compare two vehicles over the same amount of time then the amount of time becomes irrelevant.
  11. Apr 21, 2015 at 1:25 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    I drive 60-65 and accelerate like an apple. 17 MPG.
  12. Apr 21, 2015 at 3:42 PM
    DVexile
    Ken
    No the "science" is not sound and energy vs. power is not the issue.
    You are using the equation for the kinetic energy of the vehicle. That is only relevant in the case of changing speed (i.e. accelerating from a stop to say 60 mph). At the same speed the kinetic energy remains constant and thus by definition no power. Recall power is change in energy divided by time. You've got an equation that while square law has nothing to do with the correct answer.
    The correct answer relates to air drag and rolling resistance. Drag is square law, rolling resistance is not.
    I appreciate you are proud of being an engineer for all of six months and wish you a productive career. But you need to go back and review your Physics 101 text and think about the problem some more. Kinetic energy does not play any roll in the solution. If you want to have a successful career as an engineer you need to make sure that you are using the correct equations and correct fundamentals when analyzing a problem or system. Just grabbing an equation that happens to have nearly the right power law is not sufficient.
  13. Apr 21, 2015 at 5:35 PM
    Nor7
    Eric
    Texas
    Lol, you're so close but not quite there. You are correct that the truck has to overcome air drag and rolling resistance but in both equations (air drag vs kinetic energy) the velocity is square so the truck's speed is affected the same (ideal conditions) based on speed. Basically, both equations are changed by the same factor by a change in speed. THUS, both equations give you the same answer when wanting to comparing one speed vs another (this equation is used mainly in Ballistic Analysis). Maybe once you've taken advanced statics/dynamics instead of just googling aerodynamics you'll understand the concept of how power and energy and drag are all related. FYI: I've been an engineer for over 7 yrs but just got my PE 6 months ago.
  14. Apr 21, 2015 at 5:41 PM
    T Fades
    T Fades Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    Did I miss where you mentioned what size tire and psi you are running?
  15. Apr 21, 2015 at 5:44 PM
    #35
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    rabble rabble rabble buy a truck for mpg rabble rabble Prius
  16. Apr 21, 2015 at 5:54 PM
    #36
    DVexile
    Ken
    Thanks, engineer for 23 years. You don't know what you are saying. Not going to waste any more time. The web is full of half baked statements, yours is just another one. Won't bother fighting a losing battle.
    You used the wrong equation (kinetic energy) which happens to be square law which almost answers the question correctly. Wrong fundamentals to get the "right" answer is just clueless sloppy engineering demonstrating no actual understanding of the problem.
  17. Apr 21, 2015 at 10:22 PM
    #37
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    50% city driving like a stoplight warrior / 50% highway 80mph
    avg 15 mpg
  18. Apr 21, 2015 at 11:03 PM
    #38
    TSJESME
    TSJESME Well-Known Member
    James
    Maui
    14 TRD SPORT A/C 4X4 M/T
    Oh no, not again. With thusual audience commentary.
    I'm happy with my 18ish mpg.
    Remember what happened last time.
  19. Apr 21, 2015 at 11:11 PM
    #39
    Nor7
    Eric
    Texas
    Right, '23 yrs' and no license? Gotta be doing something wrong there. Let me know when you're ready for a lesson on basic aerodynamics and force balance equations.
  20. Apr 21, 2015 at 11:15 PM
    #40
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    You get better mileage than my smaller liter 3.4 V6 so you should be happy. I get about 12 combined on any given day, but I drive pretty assertively too.
