Having OME installed. Is the diff drop kit needed?
Discussion in 'Suspension' started by Jakeybogg, Aug 26, 2015.
  1. Aug 26, 2015 at 4:27 PM
    Jakeybogg
    Jakeybogg [OP] Member
    Jake
    2013 Taco Double Cab 4x4
    I'm getting the OME suspension lift installed. Is the front end diff drop kit necessary? The dealer wants to know if I want the front end diff drop kit installed too to correct for angles they say. They say they recommend and would do it if it was theirs but that it's not dire and if I don't, it will ride fine and be okay. But it's not too much more to have the diff drop kit installed. Is it necessary? Anyone had the OME installed and done (or not done) the diff drop kit? Thanks!
  2. Aug 26, 2015 at 4:27 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Opinions vary, but the TW concensus is it's not as useful as you'd hope on the second gen.
    Personally, I don't have one.
    Jakeybogg[OP] likes this.
  3. Aug 26, 2015 at 4:49 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    I bought one when I ordered all my parts for an OME 3" lift. I did use TC upper control arms. And it became apparent I really did not meet the dif drop. Also, I didn't need the axle spacer.
    My alignment was done and is near perfect and have had no issues. Ended up giving those parts away. I'd say skip it.
  4. Aug 26, 2015 at 6:47 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    No
  5. Aug 26, 2015 at 6:50 PM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    If you're installing dakars think about using axle shims. rule of thumb, 1 degree per inch of lift.
    I installed 3 deg shims with Dakars with no bearing drop and don't have any vibes.
  6. Aug 26, 2015 at 6:53 PM
    OZ-T
    Peter North
    British Columbia
    I'm taking my axle shims back out
  7. Aug 27, 2015 at 3:37 PM
    neverstuck
    Guido
    Lebanon
    13 DCLB sport
    Did they cause you grief?
  8. Aug 27, 2015 at 3:38 PM
    OZ-T
    Peter North
    British Columbia
    Still have a vibration
  9. Aug 27, 2015 at 3:40 PM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    i have no shims in the leafs and zero vibrations
  10. Aug 27, 2015 at 3:44 PM
    OZ-T
    Peter North
    British Columbia
    I had no shims and had vibrations
    I added shims and have vibrations
  11. Aug 27, 2015 at 3:56 PM
    neverstuck
    Guido
    Lebanon
    13 DCLB sport
    Try the CB drop kit yet? I have one I'm not going to use.
    Sure it's not your hankooks? You could throw on some ST Maxx to be sure.
    edit: Sorry - disregard, It was a driveshaft spacer kit that I didn't use.
  12. Aug 27, 2015 at 3:59 PM
    OZ-T
    Peter North
    British Columbia
    Yep
    Yep
  13. Aug 30, 2015 at 10:34 AM
    kietdang28
    kietdang28 Member
    kiet
    Tucson
    2016 4Runner Trail KDSS
    I have 5100 bilstein and eibach 3in coil with 1.5in block in the rear on my 15 pre-runner.
    I have vibration on fast take off and a bit slowing down.
    Not sure if I should worry about it much.
  14. Sep 20, 2015 at 10:51 AM
    Jakeybogg
    Jake
    So, it's been a few days since I had the 2" OME installed and I definitely have vibrations going on. I emailed the shop but haven't heard back yet (bc it's the weekend). What causes the new vibration after OME installation?
  15. Sep 20, 2015 at 1:48 PM
    OZ-T
    Peter North
    British Columbia
    Altered driveline geometry
  16. Sep 20, 2015 at 1:51 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    Make sure you don't add a poorly designed skid plate to your diff drop.
    I've had my diff drop on for 4 years/60k miles no issues. CV boots look great.
  17. Sep 24, 2015 at 4:33 AM
    kietdang28
    kietdang28 Member
    kiet
    Tucson
    How much of a drop did you do on the diff? I dropped mine about half an inch and still have vibes.
  18. Sep 24, 2015 at 12:24 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    I have the Toytec differential drop. I think its 1"? The differential drop doesn't address vibrations. It specifically addresses CV angles. If you are having vibrations you need to check tire wear/balance, driveshaft angles, or needle bearing among other things.
  19. Sep 25, 2015 at 12:01 PM
    kietdang28
    kietdang28 Member
    kiet
    Tucson
    The truck is brand new, 3,000 mile on it. It's a driveline vibe.
  20. Sep 25, 2015 at 12:18 PM
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    2" lift isn't enough to have cv angle/driveline issues. Vibrations in the drivetrain from lifting are usually only at really slow speeds and go away at highway speeds. Most likely alignment problem, with 2" lift you should've done UCA also. Maybe some idiot put the wheels back on with an impact and warped the rotors?
