Having some trouble shifting into Reverse
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ivan, Oct 10, 2011.
  1. Oct 10, 2011 at 8:48 PM
    Ivan
    Ivan [OP] Well-Known Member
    Ivan
    Western Mass
    06 Tacoma, 4x4 + SR5
    Whenever I start up my truck ( 2006 4 cylinder, 5 speed) and need to back out, I have trouble shifting into reverse, it seems like it almost shifts into the 'spot' but just not quite close far enough
    Not really sure how to explain it, but it goes in once I shift to first gear, then back to reverse......anyone have any clues?
  2. Oct 10, 2011 at 8:57 PM
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    It's not an uncommon issue really, I'm not sure what causes it but my civic with a 5spd used to do it as well. Let out your clutch a little while applying pressure and you should feel it pop in all the way
  3. Oct 10, 2011 at 9:26 PM
    wrxRome
    wrxRome Houston's Swamp Rat
    Brandon
    Covington, LA/Friendswood,TX
    06 SWB 4x4 trd off road
    If your in a driveway let it roll a couple inches to "line up" the gear
  4. Oct 10, 2011 at 9:26 PM
    Ivan
    Ivan
    Western Mass
    Anyone think this might be a bad thing?
  5. Oct 10, 2011 at 9:28 PM
    drewskie
    drewskie Well-Known Member
    Drew
    Burbank, CA.
    08 Prerunner 4 banger
    It's happened to me on every manual I have owned, shift into 3rd each time before going into reverse, I can gauarntee you won't have the problem ever again.
  6. Oct 11, 2011 at 7:33 PM
    Ivan
    Ivan
    Western Mass
    Alright awesome! thanks for the tips
  7. Oct 11, 2011 at 7:39 PM
    dayNnite4
    dayNnite4 We can't stop here, this is bat country.
    Nick
    Southern NH
    '11 4x4 5-speed AC
    i thought i was the only one haha. gets kind of annoying sometimes. g2 try shifting into 3rd first
