Having the same shifting problem with 2018 Tacoma. Help!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sjmtacoma18, Nov 8, 2018.
  1. Nov 8, 2018 at 6:42 AM
    Sjmtacoma18
    Sjmtacoma18 [OP] New Member
    2018 Tacoma TRD 4x4
    I purchased a 2018 TRD 4 x 4 off-road Tacoma about six weeks ago. It took only a few miles to realize the shifting was rather ridiculous, and reading forums on the issue makes it clear that this is a widespread issue for so many people. I have had five Tacoma’s and/or 4-runners during the past 30 years, And have always found them to be as good an Offroad ally as one could find.
    This new truck is very tight and I like it in general, except for the shifting nonsense. So if there is someway to improve the erratic shifting pattern it would be great. I took The truck in to Findlay Toyota in Flagstaff, where I purchased it, a couple of weeks ago And asked them to do any TSB that applied to The vehicle. They seemed to understand and theoretically did what they were supposed to. But it resulted in no discernible change to the shifting of the truck.
    So then I ran into another person with the identical truck a couple of days ago in San Diego, and he said to go to google and look up the TSB, print it out, then take it to Toyota and tell them to fix it. So I have now done that for the TSB0062-18 And plan on heading to the repair facility in Redlands California as soon as I have time to leave the truck for a couple of hours to see if this will effect any change. I have to say I am rather doubtful, but at the same time a little hopeful that this will actually fix the problem.
    If anyone out there with this widespread problem Has any suggestions beyond what I’ve stated above, I would love to hear from them.
  2. Nov 8, 2018 at 6:50 AM
    WZ00R2
    WZ00R2 Well-Known Member
    TN
    2020 Cement OR
    6112/5160, Deaver U402, 255/80r17, SCS BR6
    You have two options:
    1. Have either T-SB 0058-18 or 0062-18 applied to receive the updated calibration. The new calibration will improve the trucks drivability and throttle response.
    2. Purchase OV tune for improved performance and shifting if you are still not satisfied.
    That's about it. While it isn't perfect, the new calibration from Toyota will help a good bit over the cal you truck came with from the factory.
    taco abbo likes this.
  3. Nov 8, 2018 at 7:00 AM
    Wsteven
    Wsteven Well-Known Member
    2018 Tacoma TRD Pro
    Working on them
    wow mine shift near perfectly..... Manual transmission controlled by me :boink:
    Jh8473, 2016Tacoman, dnlskier and 2 others like this.
  4. Nov 8, 2018 at 7:32 AM
    1911tex
    1911tex Well-Known Member
    2018 Silver Metallic Limited
    Forget the TSB's...learn how to drive your 6 speed. There are 2 overdrives designed to give much better mileage. There is a "S" shift on your gear quadrant. Put it in gear 4 (shows up on your panel). Yours trans will then act as a 4 speed; i.e. from stop, it will go through 4 smooth shifts and no more. If you drive over 50, flick it into overdrive gear 5. Higher speed, overdrive gear 6. Works better and more efficient per gear than a stick shift.
    Sub_Par, jsinnard, boynoyce and 5 others like this.
  5. Nov 8, 2018 at 7:34 AM
    LivinOnEdge
    LivinOnEdge ¯\_(ツ)_/¯
    Land of The Lost
    Four wheels and a refrigerator
    This truck shines when you put your foot down. But shifting is and will forever be this Gens downfall.
    Gator352 and tcjacado like this.
  6. Nov 8, 2018 at 7:53 AM
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    OVTune Volk TE37XT 17x8.5 295/70r17 G003 Yukon 5.29 differential gears Cab Mount Relocate Icon Coilovers Icon AAL Uptop Overland Bed Rack Maxtrax Baja Designs Squadron Pro Ditch Lamps Rough Country Speedometer Calibrator
    Get the tune. It’s worth the $700.
    If not:
    You’ll try getting a pedal commander, then shift sense, then seeing they just mask the problem, trade in and lose a couple grand.
  7. Nov 8, 2018 at 8:23 AM
    skiploder
    skiploder Well-Known Member
    Somewhere NE of Kanab
    FZJ80/XJ LS swap
    This.
    All fucking day long.
  8. Nov 8, 2018 at 8:33 AM
    CRASHMAN50
    CRASHMAN50 Well-Known Member
    AA-ron
    Arkansas
    '24 Tundra Limited TRD Lift
    Never heard of people doing this. I'll have to try that in my city jaunts today.
  9. Nov 8, 2018 at 8:45 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Yuo havent even driven the truck long enough for the transmission to learn....
    JCT86 and 2016Tacoman like this.
  10. Nov 8, 2018 at 8:50 AM
    BSFord
    BSFord Well-Known Member
    2018 TRD Sport 4x4
    Clazzio PVC Seat Covers Dashcam install TRD Pro Grill MESO Total Tail Stage 1 Tailgate Lock vled total interior light upgrade TRD Pro Shift knob N2 Designs Autostart w/ smart phone module
    Here we go again....
    It's a small v6 designed to get the best MPGs.
    It will shift, let it.
  11. Nov 8, 2018 at 8:52 AM
    TacoTaco24
    TacoTaco24 Wet behind the ears.
    Patrick
    Flowery Branch, GA
    2017 MGM DCSB
    Do you shift back to four at speeds lower than fifty? I've been doing this my self lately but just wanted to check.
  12. Nov 8, 2018 at 8:56 AM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    while waiting to get it in the shop drive with ECT on. turn it on every time you drive it and see if it helps.
  13. Nov 8, 2018 at 8:59 AM
    1911tex
    Yes, it is simply a flick of the finger and no clutch! You will also get better MPG, I don't know why, but it did for me.
    mwaren likes this.
  14. Nov 8, 2018 at 9:01 AM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    For someone who's had "5 tacos for 30 years" and just come across TW I would agree. :rolleyes:
  15. Nov 8, 2018 at 9:02 AM
    TacoTaco24
    Patrick
    Flowery Branch, GA
    2017 MGM DCSB
    Right on.
  16. Nov 8, 2018 at 9:03 AM
    Enfield1
    Enfield1 Well-Known Member
    Brad
    Bryan, Tx
    '18 White DCSB OR 4wd auto
    S6 and leave it out of D
  17. Nov 8, 2018 at 9:04 AM
    MinookaBlues
    MinookaBlues Well-Known Member
    2022 Super White SR5 Access Cab
    Stock
    If it only took a FEW miles to realize you didn't like how it shifted......it was RIDICULOUS of YOU for not taking the truck for a longer test drive before buying it:spending:
    2016Tacoman likes this.
  18. Nov 8, 2018 at 9:10 AM
    MinookaBlues
    Stock
    LOL....yeah I was thinking the same thing...just didn't want to come right out and say TROLL:rolleyes:
    LV-TAC and 2016Tacoman[QUOTED] like this.
  19. Nov 8, 2018 at 9:10 AM
    2016Tacoman
    J
    Might I make a suggestion that we need a new graphic, a phonograph with a broken record on it.
    Dkurtz42 likes this.
  20. Nov 8, 2018 at 9:11 AM
    2016Tacoman
    J
    Did I say troll ? Me ? No way.
    Never crossed my mind.
    MinookaBlues[QUOTED] likes this.
