Having the same shifting problem with 2018 Tacoma. Help!
Discussion in '3rd Gen. Tacomas (2016+)' started by Sjmtacoma18, Nov 8, 2018.
  1. Nov 8, 2018 at 9:24 AM
    boynoyce
    boynoyce .
    16 SR5 AC V6 4x4
    Anybody else remember any members who were knowledgeable and added value to TW permabanned for replying to a thread like this?
    I do ....
    Just saying
  2. Nov 8, 2018 at 10:39 AM
    jsinnard
    jsinnard Crawl Control and longbed? I has it
    Virginia
    04 DCAB 4X4, 16 QS DCLB OR 4X4
    You don't have to unless but it helps if you don't want the truck to shift 5th to conserve fuel to keep revs low.
  3. Nov 8, 2018 at 10:52 AM
    gla49
    gla49 New Member
    Greg
    17 TRD Quicksand 4d
    I hated mine at first also. Turns out it was low on oil from the factory (don't know if that was contributing factor) but oil was put in and the update done. Still was sketchy for a couple thousand miles but finally learned how I drive and now works great. No searching for gears ever. My advice would be to be patient, drive normally, and see if it improves. My bet is that it will. Good luck.
  4. Nov 8, 2018 at 12:56 PM
    Sjmtacoma18
    Sjmtacoma18 [OP] New Member
    2018 Tacoma TRD 4x4
    Thanks to all for your responses to my issue. Including I guess the snide remark’s from those who know so much about everything of Toyota origin. I was aware of the issue before I bought it but some of the other features on the truck, for example the crawl feature, is why I got the truck.
    I hear mention of the truck computer learning of my driving habits and wouldn’t that be nice if it actually got better over time. I have 2500 miles on the vehicle thank you. And yes I understand I can shift into the S range, but it still is shifting oddly .
    Thanks again. We shall see.
  5. Nov 8, 2018 at 1:05 PM
    jsinnard
    Virginia
    It shifts "oddly" because its geared differently than your previous trucks; It's a 6 speed with two OD gears instead of a 4 or 5 speed with one.
    Turning off one or both of the OD gears in S mode makes it similar to what you may be used too.
    Or you can just get used to what's different about it like most of the rest of us.
    BSFord, Lt. Dangle and boynoyce like this.
  6. Nov 8, 2018 at 2:00 PM
    Lt. Dangle
    Lt. Dangle Thinks skiploder needs a hug
    Ohio
    2017 TRDOR
    stuff
    For the love of all that is holy, drive it hard. If you pussyfoot around, it learns that behavior. If you drive like you need to be somewhere on time, it will learn that behavior.
    Baerskin likes this.
  7. Nov 8, 2018 at 2:44 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado, Africa, Europe, Asia, Middle-East,
    2017 DCSB TRD OR
    I think the consensus was to have about 5k on it though I think the transmissions adjusts every 500 miles.
  8. Nov 8, 2018 at 2:59 PM
    Baerskin
    Baerskin Rocking in the Free World
    Matty
    Winnipeg
    TRD Sport 4x4 DBLC V6 6A
    Stock.
    Get the ECU update. You will see. If not drive like an animal. Hitting 5-6000 RPM on this truck will not cause issue. It really picks up in the 6000 range
    Buuuuut you will see your gas go WAY down. Driving like a grandma I get super miles on a full tank.
  9. Nov 8, 2018 at 3:20 PM
    KVTaco
    KVTaco Well-Known Member
    Cant you just unplug the battery for the tranny to start learning again?
  10. Nov 8, 2018 at 3:29 PM
    Jaque8
    Jaque8 Well-Known Member
    2017 Inferno TRD OR
    Maybe this is why I never had problems with mine shifting. My #1 rule with any new engine is warm it up to full operating temp, then REDLINE THE SHIT OUT OF IT... even if it only has 5 miles on the odometer.
    Counter intuitive to "common knowledge" of a "break in period" but I was given this idea 10 years ago by a professional rally driver and since then I've done it on 4 vehicles of mine and every single one ended up dynoing higher than average when it came time to tune. IIRC in the "old days" you needed to seat the pistons, but modern manufacturing tolerances are so tight whats more important now is "cross hatching" the cylinder walls to get the best compression, and you can only do that by building cylinder temp near redline.
    Maybe it was a bunch of BS but its worked for me :)
  11. Nov 8, 2018 at 3:46 PM
    KVTaco
    That is counter-intuitive. You know I have read so much about break-in over the years. The most compelling argument however is that the engineers that built it and put the instructions in the manual probably are right. But I have read plenty of folks that believe, like you do, to drive it like you stole it. I may try that one time. The issue is you aren't just stressing the engine, you're stressing the differentials.
    Jaque8 likes this.
  12. Nov 8, 2018 at 3:55 PM
    Jaque8
    2017 Inferno TRD OR
    I’d agree in theory but I also know the engineers aren’t the ones writing the owners manuals (for the most part). There’s a ton of things the engineers would do differently if the bean counters and lawyers weren’t involved.
    Which is to say, if redlining the engine IS in fact the best way to break in a new engine (performance wise), do you think the lawyers would honestly allow the company to say that?? I can just imagine the liability from law suits once one dumb teenager wraps his new car around a tree because he was “following the manual”
  13. Nov 8, 2018 at 3:56 PM
    KVTaco
    Good point - so let's assume you were right, what about the driveline components needing to seat/go through heat cycles?
  14. Nov 8, 2018 at 3:59 PM
    Jaque8
    2017 Inferno TRD OR
    That’s also a very good point.
    I’m just talking out of my ass on this one but I’d imagine the same manufacturing tolerances that allow engines to not need breaking anymore. apply to gears as well? And as long as you’re not hard shifting is it really that stressful on gears? I’m honestly not sure just guessing.
    The only thing I am really nice on for any significant period of time is clutches for the first 500 miles because... I don’t even know why I just always have been
  15. Nov 8, 2018 at 4:01 PM
    #35
    wood714
    wood714 Active Member
    I'm use to my Nissan that kinda doesn't shift...at least you never feel it shift.
    My one week old V6 truck shifts kinda funky just like my dad's 2009 5.7 Tundra. I figure it's a Toyota thing, I have warranty, I'll worry not.
  16. Nov 8, 2018 at 4:07 PM
    #36
    Dkurtz42
    Dkurtz42 Well-Known Member
    David
    2018 Tacoma DCLB TRD SPORT 4x4
    4” rough country lift 20 x 9 fuel assault wheels 33x12.5x20 Nitto Trail Grapplers
    I thought 3rd Gen was CVT?
  17. Nov 8, 2018 at 11:13 PM
    #37
    Flash1034
    Flash1034 Well-Known Member
    Southern California
    2018 Toyota TRD Pro, Cavalry Blue, Automatic
    None
    Seriously my truck shifted like crap too until I got the TSB done. It drives like a new truck should now and I’m VERY happy with it.
  18. Nov 11, 2018 at 5:06 PM
    #38
    Pirate1975
    Pirate1975 “What do you do with a drunken sailor...?”
    Steven
    Statesville, NC
    2017 Silver TRD Off-road
    3rd bedrail.32” tires.CaliRaised bed stiffeners.sliders on order ready in the next several weeks.slow work in progress..
    I have finally accepted the on highway use of the transmission..
    My biggest beef now is the transmission while off road in lo range. Hi range doesn’t seem to be an issue.
    Can’t control the rpm rev or the lag in lo (4x4)
    Does the pedal commander or ovtune help on the trails,or is it mainly highway use?
