having trouble getting my front aligned
Discussion in 'New Members' started by RB87, Dec 21, 2010.
  1. Dec 21, 2010 at 6:44 AM
    RB87
    RB87 [OP] Active Member
    Ricky
    Stafford va
    05 Tacoma
    6" pro comp stage 1 lift
    My tie rods are maxed out and my wheels are still out alil bit what should i do??
  2. Dec 21, 2010 at 6:46 AM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner
    Stuff
    Welcome to TW first.
    :wave:
    Were did you get it aligned at? And when did you get it aligned?
  3. Dec 21, 2010 at 7:07 AM
    RB87
    Ricky
    Stafford va
    05 Tacoma
    i got it aligned at toyota a buddy of mine works there i also have a six pro comp lift on the truck as well
  4. Dec 21, 2010 at 7:09 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    If your Tie rods are maxed out, The lift wasnt installed correctly, or soemthing is bent.
  5. Dec 21, 2010 at 7:13 AM
    RB87
    Ricky
    Stafford va
    05 Tacoma
    how could it be installed wrong when you follow directions
  6. Dec 21, 2010 at 7:48 AM
    RB87
    Ricky
    Stafford va
    05 Tacoma
    this might sound kinda dumb but do you have to cut off some of the tie rod could that be the reason it doesnt line up
  7. Dec 21, 2010 at 8:14 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No. You only have to cut out, and replace a front cross member.
