Having trouble tuning "Little Wil"
Discussion in 'Audio & Video' started by bendbolden, Dec 28, 2011.
  1. Dec 28, 2011 at 12:51 PM
    bendbolden
    bendbolden [OP] Come and take them.
    Ben
    Moscow, TN
    07 FJ Cruiser
    None but soon......
    I have the Little Wil cb antenna installed on my roof and can't get the SWR below 1.5 at channel 20. 1 and 40 are above 2. What am I doing wrong? I had a 3ft firestik mounted on my bed before this and got it way lower than that. I know different antenna's mean different readings but I thought this was supposed to be the optimal setup.
    A little more info:
    I cut off maybe a foot of cable that came on it and used a Radioshack connector. It is also centered perfectly left to right on the roof but farther back and not in the middle. If I put it in the middle the curve of the roof made it stick forwards like a unicorn.:D Help!
  2. Dec 28, 2011 at 6:29 PM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    Try sliding the whip up from the base some. Just move it about a 1/8th of an inch at a time to see if that helps. If that doesnt work you may need to trim the whip some.
  3. Dec 28, 2011 at 6:31 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    coax cable on any mag mounted antenna is a predetermined length, and should not be cut to length. that is the problem i bet!
  4. Dec 28, 2011 at 6:36 PM
    bendbolden
    Ben
    Moscow, TN
    07 FJ Cruiser
    None but soon......
    Well it was barely any cut off. I measured it again and it was less than six inches I cut off. I had to cut it to get it through the firewall. Also I have cut some off to get it to where it is. The length is as good as it is going to get. I was just wondering if i am missing something. Maybe these mag mounts aren't the best option. It does work well enough to talk though.
  5. Dec 28, 2011 at 6:40 PM
    LUSETACO
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    I wouldnt worry too much about it. Your SWR is within acceptable range.
  6. Dec 28, 2011 at 6:41 PM
    bendbolden
    Ben
    Moscow, TN
    07 FJ Cruiser
    None but soon......
    Yeah that's what I am being told by others. Thanks
  7. Dec 28, 2011 at 6:42 PM
    MonkeyProof
    SoCal- SGV
    i have had my lil will for well over ten years and no problems yet..
    maybe you're getting some RF loss at the new connector, who knows. like what LUSETACO suggested..you can slide the whip up some at the base by loosen the set screw..moving up just by 1/8" can make a huge difference.
  8. Dec 28, 2011 at 6:44 PM
    bendbolden
    Ben
    Moscow, TN
    07 FJ Cruiser
    None but soon......
    Would that improve the swr overall or just change it. I had to cut some off to get it even on both ends.
  9. Dec 28, 2011 at 6:56 PM
    LUSETACO
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    So you've already trimmed the whip?
  10. Dec 28, 2011 at 7:10 PM
    bendbolden
    Ben
    Moscow, TN
    07 FJ Cruiser
    None but soon......
    Yes trimmed it about 1/2". Got it to 1.6 on channel 20
  11. Dec 28, 2011 at 7:13 PM
    LUSETACO
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    I would call it good and enjoy your setup.
  12. Dec 28, 2011 at 7:14 PM
    jandrews
    '09 FourDubDee TRD OR
    From the thread title I thought you were talking about your penis.
    So, at least you're better off than I thought.
  13. Dec 28, 2011 at 8:17 PM
    bendbolden
    Ben
    Moscow, TN
    07 FJ Cruiser
    None but soon......
    Haha thanks for all the info.
