Hawaii Recon Information, Q&A Thread
Discussion in 'Hawaii' started by Kelson, Jun 22, 2010.
  1. Oct 16, 2014 at 5:08 PM
    #441
    BigIslandTRD
    BigIslandTRD beach bound
    rey
    Big Island (43)
    2013 TRD Sport DCSB
    stock-ish.........
    quick question, are front mud flaps needed to pass safety check??
  2. Oct 16, 2014 at 5:29 PM
    #442
    zboy
    zboy Well-Known Member
    Oahu808
    12 TRD OR
    No
  3. Oct 16, 2014 at 10:30 PM
    #443
    xmods
    xmods Super Member
    Nathaniel
    Kaneohe
    10' PRO-4X CC, modded..
    Too long to list :D
    No front. Rear has to cover full width of the tire and at least half way down the height of the tire.
  4. Oct 18, 2014 at 4:17 PM
    #444
    BigIslandTRD
    rey
    Big Island (43)
    2013 TRD Sport DCSB
    stock-ish.........
  5. Oct 21, 2014 at 10:55 PM
    #445
    87twentytwor
    87twentytwor Well-Known Member
    Jake
    Hawaii
    Sport
    none
    Dang I swear I read somewhere that LEDs were a no go.. LEDs I t is then!! Chee,
  6. Nov 8, 2014 at 12:25 AM
    #446
    hwnsupaman
    hwnsupaman Member
    OAHU,HAWAII
    1GEN BLACK DOUBLE CAB
    5100 BILSTIENS 883 OME
    I just bought a truck that has a recon sticker on it and i dont have the paperwork previous owner said truck is the same set up nothing has changed. Recon would still have records on it???? Am i able to just get new papers or do i need to get recon all over again????? Please HELP!!!
  7. Nov 8, 2014 at 12:47 AM
    #447
    cubiclesurfer
    cubiclesurfer Well-Known Member
    Kailua-Kona, HI
    hopefully I'm wrong, but I thought the inspector told me "you lose that (the paperwork), you gotta do it all over again." so, I assume if you lose it, you gotta redo it.
  8. Nov 8, 2014 at 11:09 AM
    #448
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    yup. it's on the owner to maintain the paperwork.
  9. Nov 8, 2014 at 11:43 AM
    #449
    xmods
    xmods Super Member
    Nathaniel
    Kaneohe
    Too long to list :D
    Yeah because you fill out the paper by hand, and a photo copy won't do, you have to fill out a whole new one.
  10. Nov 9, 2014 at 3:08 AM
    #450
    Koootch
    Koootch Well-Known Member
    Oahu
    2011 Prerunner
    Maxtrac Spindles, Bilstien 5100s @.85, OME Dakar, Fuel trophies w/ BFG AT KO 285/70/17
    I bought a truck used that had recon. I got new tires with a different size and figured I'd update the recon so safety check wouldnt be a big deal. Turns out the body lift exceeded the legal height and they failed me and ripped the sticker. It was a great adventure
  11. Nov 9, 2014 at 6:48 PM
    #451
    xurusaibobx
    xurusaibobx Well-Known Member
    a lot of people do that get recon with "legit RECON mods" then mod it more after getting recon.
  12. Nov 15, 2014 at 7:30 PM
    #452
    n.gardner
    n.gardner Spacer Hater
    Nick
    Hawaii
    '13 SR5 4x4
    OME 3" 887s + Dakars 1" 4 Crawler BL Pro-Comp Uniballs Nitrochargers + Super Bumps Diff Drop + Drive Shaft Drop
    How much of a body lift did you have?
  13. Nov 15, 2014 at 7:39 PM
    #453
    n.gardner
    Nick
    Hawaii
    '13 SR5 4x4
    And does anyone know if the pro-comp uni-ball UCAs will meet the "green" alignment specs? or should I recon before installing the new uca?
  14. Nov 15, 2014 at 11:40 PM
    #454
    Koootch
    Oahu
    2011 Prerunner
    It had a 3" body lift which is the max but the cab also has a .25" spacer which makes it 3.25" total. Thats what the inspector told me.
  15. Nov 15, 2014 at 11:47 PM
    #455
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    You can hit "green" specs with stock UCA's. You will get higher caster with a uniball UCA, the truck will feel alot more stable at highway speeds. That's what I noticed after I installed mine.
  16. Nov 16, 2014 at 1:48 AM
    #456
    n.gardner
    Nick
    Hawaii
    '13 SR5 4x4
    Did you pass recon with the uniballs though?
  17. Nov 16, 2014 at 1:57 AM
    #457
    n.gardner
    Nick
    Hawaii
    '13 SR5 4x4
    Here is my dilemma:
    Right now:
    1" Body lift
    2.5" strut spacer
    1" leaf block"
    Stock wheels and tires
    -no recon-
    In my garage:
    Dakar leaf pack
    OME 887s
    Procomp uniball UCAs
    285x75x16 Duratracs
    (shocks an all the other fun stuff)
    So, should I do recon with my set up NOW (with strut spacers, blocks, and BL/stock tires) because i can deffinately get proper allignment? OR will i be able to get allignment with the 887s, UCAs and 33"s ?
    I know they make note of the modifications but I doubt the dude there will note its strut spacer vs. OME
    just looking for some advice, THANKS
  18. Nov 17, 2014 at 11:05 PM
    #458
    xurusaibobx
    i would at least put the tires on because when it comes down to safety they going check and match tire specs. the other parts not so much unless it lifts the truck at more then current state
  19. Nov 17, 2014 at 11:22 PM
    #459
    luka
    Kailua, HI
    from my understaning, get recon because of the lift. how you do the lift is irrelevant. You don't list out everything installed, it will just say "lifted" or "lowered"
    if you can pass now, then it might be better to do it now and change the parts out. after you change the parts out, you will need an alignment, so it comes down to if you want to pay for 2 alignments or one, as you need one within 30 days of recon.
  20. Nov 17, 2014 at 11:49 PM
    #460
    xmods
    xmods Super Member
    Nathaniel
    Kaneohe
    Too long to list :D
    Technically you are required to list each lift component so the safety inspector can tell if you changed anything. But RECON is so jacked that they don't even care if you write it all out. They just want to get you in and out as quick as possible these days. When I did my first one 3 years ago they made sure I wrote out all of the suspension components. The inspector walked around my truck with the form looking at everything I listed.. I still did it this last time so my friend that does my safety is covered. And there can be no doubt if anyone tries to give me trouble over anything. Brands and part names for everything I have as far as engine, suspension, body, wheels/tires, and lights. Took me 15 mk it's and some tiny writing to get it all listed lol
    If it was me I would go ahead and do everything, get your alignment and book it to RECON. Just get it over with in one shot and be done with it. Most safety inspectors won't give you crap about not matching your RECON papers perfectly, but if they do and enter in the system that you failed, then any other shop can see that and won't give you a safety. They will make you go back to where you failed. Most inspectors won't put in the systems that you failed though, they just don't put in anything at all.
