Hawaii Recon Information, Q&A Thread
Discussion in 'Hawaii' started by Kelson, Jun 22, 2010.
  1. Aug 25, 2013 at 5:12 PM
    #101
    raycie
    raycie Well-Known Member
    Oahu, HI
    2013 DCLB / 2016 4R Trail
    In need of $$$
    Or just get recon...
  2. Aug 28, 2013 at 12:24 AM
    #102
    xurusaibobx
    xurusaibobx Well-Known Member
    front windows are still going be measured at inspection stations rear windows can be as dark as you want. also whatever you listed on the paper such as tire size is what the inspector is going look for when you get a safety.
  3. Aug 28, 2013 at 2:20 AM
    #103
    WailuaTaco808
    WailuaTaco808 A.L.O.H.A. Member
    Phil
    Hawaiian Islands
    2010 Tacoma TRD SPORT Kauai Built
    Oh boy...
    everything is at home ready for as soon as i get my stickers updated. ^^^ the beauty of having more than one set of tires. going back and forth between the two is as simple as jack stands and impact gun and about 15 minutes
  4. Aug 29, 2013 at 9:28 AM
    #104
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    Saw your truck in the driveway while driving home yesterday, lookin good!
    traffic was so bad I took Likelike ugh.
  5. Aug 29, 2013 at 8:11 PM
    #105
    WailuaTaco808
    Phil
    Hawaiian Islands
    Oh boy...
    welcome back to shitty traffic haha... thanks yeah im stoked to finally be legal (and i say that very lightly)
  6. Sep 4, 2013 at 6:27 PM
    #106
    iRep8OH8
    iRep8OH8 "Lets Go Places!" Enthusiast
    Maui
    2015 Super White TRD Sport ACRB
    3" lift, 30" Light bar, Rear Pod Lights, & essentials.
    So I've heard some rumors that Recon is coming to Maui :( anybody know if this is foreal? I surely hope it isn't!
  7. Sep 4, 2013 at 8:13 PM
    #107
    WailuaTaco808
    Phil
    Hawaiian Islands
    Oh boy...
    they said that same shit about kauai.... still never made it. People on kauai (at least for now) still realize how effing stupid it is and shoot it down every year they try to bring it. Its supposedly a Hawaii state law required for islands with over 600,000 or more people i think. kauai only get maybe 100,000 give or take depending on tourism. It may be a bigger number or something around that number, thats just what the guy at recon explained to me when i was there.
    all u gotta know is... if u can fight it.... FIGHT IT. F#$% recon!
  8. Sep 19, 2013 at 10:14 PM
    #108
    batmobile
    batmobile Well-Known Member
    Honolulu, HI
    '13 PreRunner
    i have recon on my mustang and the tire size listed on my paperwork is different than what i run. I get my inspections with the bigger wheels (not listed on my recon paperwork). never had an issue. I was always under the impression that as long as the wheels are "legal" they cant mess with you. I even pass inspection with tinted taillights..
  9. Oct 27, 2013 at 3:48 AM
    #109
    souljah96786
    souljah96786 Member
    Hey guys im going to get recon but I have HID's.. Question is can I just swich back to stock bulbs or do I have to completely remove the balasts from under the hood? Do they even look under the hood? Thanks..
  10. Oct 27, 2013 at 6:05 AM
    #110
    808DAKINE
    808DAKINE Well-Known Member
    Kai
    Lahaina, Hawai'i
    01 Taco
    Cold air, Sounds, lift, lights, exhaust and a canoe!
    Theres a few threads on HiDs, projectors or not. Heres one for example: http://www.tacomaworld.com/forum/lighting/191480-hid-faq.html
    I do believe they look under the hood to check if the battery is securely mounted.
    Hope this helps!
  11. Nov 1, 2013 at 5:39 PM
    #111
    III
    III Active Member
    Kailua, HI
    2011 blk XR
    after reading through this i noticed a lotta guys saying u need mudflaps.. is that just for lifteds? looks like a lotta u guys went in with lifts... id be going in dropped, and i cant see why i'd need mudflaps, my xr didnt come with em or anything... ??
  12. Nov 1, 2013 at 6:12 PM
    #112
    WailuaTaco808
    Phil
    Hawaiian Islands
    Oh boy...
    only need to have half of your tires covered by mudflaps *(height wise) so if ur dropped... probaly not. and you do need the full width of the tire covered. thats why they are so anal about finders
  13. Nov 2, 2013 at 1:53 PM
    #113
    minahkine
    minahkine New Member
    cliff
    Oahu
    99 Tacoma
    Alohas my braddas, I just did an alignment and everything was within the tacoma's specs except for Steering Axis Inclination (SAI) and Included Angle. They were about 1.5 degrees less than the minimum specified range. I heard SAI was unadjustable and they use these numbers to diagnose bent or bad suspension. My suspension is in great condition, zero accidents, hardly off road.
    Anyone had this problem on their taco? You guys know of any good alignment shop for lifted trucks that would fudge, i mean, fix this ;P and print my alignment papers for recon?
  14. Nov 2, 2013 at 2:46 PM
    #114
    minahkine
    cliff
    Oahu
    99 Tacoma
    Another question, I've also heard from one of my friends that you can't stack lifts. For example, putting a 2" spacer with a 6" Fabtech. Do any of you know if this is true? Thx in advance
  15. Nov 2, 2013 at 5:03 PM
    #115
    WailuaTaco808
    Phil
    Hawaiian Islands
    Oh boy...
    True and false... you definitely cant put a 2 inch spacer with a 6 inch fab. Your UCA's will knock on ur coilovers (unless they are super skinny c/o's). i would know kuz i had a 1 inch spacer on my 6 inch pro comp and i was tapping the c/o's. So i ripped off the spacers and just cranked the c/o's to the max. Only way to be able to add the spacer is if you also got a long travel kit (long travel uca's lca's, etc.)
  16. Nov 3, 2013 at 10:47 AM
    #116
    minahkine
    cliff
    Oahu
    99 Tacoma
    Rajah. I actually just have a 1" Daystar Polyurethane Spacer. So they won't even pass that?! That blows man. I need to see their definition of "no stacking" lifts because putting lift blocks and add-a-leafs in the rear seems like stacking to me which is what some lift kits already offer.
  17. Nov 3, 2013 at 12:04 PM
    #117
    WailuaTaco808
    Phil
    Hawaiian Islands
    Oh boy...
    oh no that will be fine i think... im just saying some lifts cant even handle it as all... pretty sure that guy wont know shit about a spacer on a c/o.
  18. Nov 9, 2013 at 2:27 AM
    #118
    SR5808
    SR5808 Well-Known Member
    J10
    Honolulu,Hi
    Black Prerunner SR5
    Tint/ weathertech visors/ truxedo tonneau cover/ color matched front emblem and door emblems/ Clazzio Leather seat covers/debaged tail gate/depo black tail lights/color matched front grill/led headlights/ Pioneer Avh-5800/ Alpine Type R Front and Rear speakers/ Alpine Pdr-v75/ JL audio 10tw3/ Mr. Marv Custom sub box/amp rack/ Stealth Custom Series Stealth 6 17x8.5/ 265/70/17 Nitto terra grapplers...
    Planning to lift my taco soon. Anyone know if lr uca's can meet alignment specs?
  19. Nov 9, 2013 at 9:04 AM
    #119
    luka
    Kailua, HI
    yup, lots of adjustability in those.
  20. Nov 26, 2013 at 9:00 AM
    #120
    Riggins
    Riggins Member
    Tim
    Oahu
    '13 TRD Sport Tacoma 4WD
    OME 885s no spacers, Billstein 5100s, Icon 1.5" AAL, Cab Mount Chop, LR UCAs, 285/70/17 Duratracs on 17x9 Revolvers, NFab Nerfs, Aero 2525xl muffler, Wet Okoles, Thule Racks, Grillcraft, BHLM
    I have my Recon appointment set up for next month and was wondering if anyone had done it after doing a cab mount chop. I had a piece welded over but I don't know of they require any special paperwork for it. Any feedback would be appreciated.
