HawsFF59 Build
Discussion in '2nd Gen. Builds (2005-2015)' started by Haws, Dec 9, 2014.
  1. Sep 30, 2016 at 6:56 PM
    #141
    Haws
    Haws [OP] Well-Known Member
    Shawn
    Washington
    TRD Off Road
    Lot's of stuff (-;
    Well I finally got the crawlbox in :benchpress:
    hoverlover likes this.
  2. Sep 30, 2016 at 7:38 PM
    #142
    Haws
    Shawn
    Washington
    TRD Off Road
    Lot's of stuff (-;
  3. Oct 4, 2016 at 8:48 AM
    #143
    12thmanhawkfan
    12thmanhawkfan Well-Known Member
    Robby
    Bellingham, WA
    Access Cab 6-speed
    It's got some Mods
    You've got a sweet rig man. I'm excited to see some more progress pictures!
  4. Oct 4, 2016 at 4:51 PM
    #144
    Haws
    Shawn
    Washington
    TRD Off Road
    Lot's of stuff (-;
    Thanks!! Ill put up pics soon
  5. Oct 13, 2016 at 10:55 PM
    #145
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    hey! when you relocated the cab mounts (I am installing the redgoat fab mounts tomorrow) was there any concerns of fire or anthing then? I know you mentioned the fire when tubbing the wheel wells for 37s which I totally understand. I just wasnt sure if it was the same concern when just welding on the new mounts (or even cutting off the stock ones?). I was looking at draping a wet clothe over the thin break lines that run along the frame just to keep those things cooler than not.
    I want to make sure Ive thought through the important stuff that could go wrong (like fire haha). Thanks!
    Jeremy
  6. Oct 13, 2016 at 11:10 PM
    #146
    Haws
    Shawn
    Washington
    TRD Off Road
    Lot's of stuff (-;
    I used a cut off wheel for most of mine, and then finished with a grinding wheel. I just paid attention of where the sparks were being thrown. Wet towels are a good thing though. Good luck
    Skootter14[QUOTED] likes this.
  7. Oct 19, 2016 at 9:05 PM
    #147
    TheNatural
    TheNatural Well-Known Member
    Fort Nelson, BC
    '12 DCLB
    Lots of bolt on chrome stuff
    I just read through the whole build thread after seeing some of your posts in the cab mount relocation thread. Nice build! Are you still running stock diffs? (I know you did gears and I think I read air locker somewhere)
  8. Oct 20, 2016 at 9:35 AM
    #148
    Haws
    Shawn
    Washington
    TRD Off Road
    Lot's of stuff (-;
    Yes stock diffs 4:88's with ARB front and elocker rear
  9. Oct 20, 2016 at 10:34 AM
    #149
    TheNatural
    Fort Nelson, BC
    '12 DCLB
    No problems with the giant tires on the stock 8" diff? Sounds dangerous
  10. Oct 20, 2016 at 10:53 AM
    #150
    Haws
    Shawn
    Washington
    TRD Off Road
    Lot's of stuff (-;
    I run the 39.5's for winter wheeling then 35's the rest of the year. I primary snow wheel and have had no issues. I'm not a heavy pedal wheeler. I'm sure if I were on the rocks with good traction I'd be another story.
    The plan will be to do a SAS in the years to come.
  11. Oct 20, 2016 at 11:00 AM
    #151
    TheNatural
    Fort Nelson, BC
    '12 DCLB
    Gotcha. Thanks for the info. I'm still on 33s, eying 35s for the spring time. I was considering doing some extra cutting when I made room for the 35s in order to have room for a bigger snow wheeling tire. TW makes me nervous about the stock diff, but it's good to hear you haven't had issues in the snow. I are snow wheeling n00b
    hoverlover and Haws[QUOTED][OP] like this.
  12. Oct 31, 2016 at 1:43 PM
    #152
    TheNatural
    Fort Nelson, BC
    '12 DCLB
    Haws I have moar snow wheeling questions! I've been reading what I can find but apparently snow wheeling isn't as popular as I'd like it to be.
    It sounds like I should be running like 4psi, which makes me think beadlocks are needed. Buuut, lots of pictures I see do not look like guys are running beadlocks. what do you recommend ? on dirt/rocks I leave tires at like 18psi and I don't have any experience going lower for fear of losing a bead.
    What about tire choices and home mods? it looks like a lot of guys use a mud terrain with a soft sidewall then add a ton of siping with a grooving tool. Is that the best way to go?
  13. Nov 6, 2016 at 3:06 PM
    #153
    Haws
    Shawn
    Washington
    TRD Off Road
    Lot's of stuff (-;
    I run 39.5 Iroks and will drop as low as 4psi. Ive blown one bead after sliding 4 feet while side hilling. I normally run 6 in the front and 4 rear. I bought beadlocks this year even though in the last 3 years I've only blown one. I think tire choice as well as how stiff they are determine how low you can go.
  14. Mar 6, 2017 at 3:03 PM
    #154
    Haws
    Shawn
    Washington
    TRD Off Road
    Lot's of stuff (-;
    Well its time to swap in a beefier rear axle... Project 14 bolt swap has begun
    hoverlover and Taco Nation like this.
  15. Apr 5, 2017 at 2:12 PM
    #155
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Did you get enough snow wheelin' in this year? I was just up at Spout Springs, still 15' of snow in some spots.
  16. Apr 5, 2017 at 7:06 PM
    #156
    Haws
    Shawn
    Washington
    TRD Off Road
    Lot's of stuff (-;
    Yes I was up April 1st, it was a blast!!
    username[QUOTED] likes this.
  17. Jul 18, 2017 at 3:23 PM
    #157
    Jake.A
    Jake.A Well-Known Member
    California
    2014 Tacoma TRD Sport
    Sweet build man! Those 37's look mean!
    Sub'd :spy:
  18. Jun 28, 2018 at 7:12 AM
    #158
    Nimble9
    Nimble9 visit squareonecreations.com Vendor
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    any updates OP? love the build!
    hoverlover, rlx02 and Johnny DemonT like this.
  19. Feb 18, 2019 at 9:20 AM
    #159
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    I agree, hopefully we'll see some updates.
  20. Feb 18, 2019 at 9:45 AM
    #160
    Haws
    Shawn
    Washington
    TRD Off Road
    Lot's of stuff (-;
    I guess its time to post some newer pictures. I haven't done many new mods since swapping my rear axle out to a shaved 14 bolt however Im playing with the idea of doing something different with my IFS. SAS is so expensive and time consuming and Im not really sure its what I need for snow wheeling. Been eyeing Marlins setup
    hoverlover, deeezy and Nimble9 like this.
