Hazard button stuck in.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jp00714, Mar 11, 2017.
  1. Mar 11, 2017 at 5:52 AM
    Jp00714
    Jp00714 [OP] Active Member
    Jp
    06 pre-runner
    Hey guys. So I went to turn my hazards on last night and the button got stuck inside the panel and wouldn't push back out. I finally got it a little pushed out so that they turned off, but it still is stuck in. Any tips on what to do?
    Thanks.
  2. Mar 11, 2017 at 6:21 AM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    Pull off the radio bezel, and clean out around the button, there's probably some junk caught between the button, and bezel.
  3. Mar 11, 2017 at 6:24 AM
    Clearwater Bill
    Billy
    Largo Florida
    CRC electronic cleaner, small nozzle, spray around button. May do the trick w/o disassembly.
    Maticuno likes this.
  4. Mar 11, 2017 at 6:55 AM
    Silence9
    Silence9 Solve et Coagula
    Alberta, Canada
    SSS - Someone splashed soda.
    If you can find a small enough tool to clean the tolerance between the bezel and the button, it might save you disassembly. I always try and not take plastic apart, it will never quite be the same after.
