Haze in Headlights after BHLM
Discussion in 'Lighting' started by SilverBullet07, Apr 5, 2011.
  1. Apr 5, 2011 at 12:04 AM
    SilverBullet07
    SilverBullet07 [OP] Silver Member
    Bryan
    Pleasanton, CA
    Silver 07 PreRunner Sport
    Tint, Grillcraft Grill, Leveling Kit, Retrofit Headlights.
    So I did the BHLM in January. Had no problems till I noticed on Friday that the top corners had a sort of haze on the inside lenses, thought nothing of it and then the following day it got worse. I'm guessing its from the heat since it was parked directly in the sun light and the temp reached 80ish degrees...
    Could anyone tell me why this is possibly happening?
    My only though was that I didn't let the bezel cure enough before I put it back in the light and sealed it up. So Saturday I took the light apart pre-burned the bezel again and let it sit over night, and then washed the lenses with soap and water and also let them sit over night and put everything back together.
    Any help would be appreciated.. if the problem continues I will take pictures next time.
  2. Apr 5, 2011 at 12:28 AM
    SilverBullet07
    Bryan
    Pleasanton, CA
    VHT Night shade for the Blinker/DTRL.
    All is sealed, never had water leak in them once.. Its frustrating, if it happens again I don't know what I'm gonna do.
    Thanks for the suggestions:)
  3. Apr 5, 2011 at 12:40 AM
    SilverBullet07
    Bryan
    Pleasanton, CA
    Thanks man... I was thinking about that since the heat needs somewhere to escape if its the heat making it haze up. Look forward to seeing the link!
    If you use the VHT just rub down everything your gonna spray with soapy water it worked the best and left no bubbles. If you live close to CA you can use mine... I have a full can basically.:D
  4. Apr 5, 2011 at 12:49 AM
    SilverBullet07
    Bryan
    Pleasanton, CA
    HAHA thanks but no thanks, I rather drill a hole behind the headlight or something not in the front lenses. Ill see how they look in a week.. and update on my solution.
  5. Apr 5, 2011 at 12:57 AM
    SilverBullet07
    Bryan
    Pleasanton, CA
    Hahaha do the write up and ill try it :bananadance:
    I know you PM'd me about the Signal/DTRL, but heres a picture to see the color difference between stock and tinted:
